Tip & How-To about Enlight Interactive Warlords BattleCry 3 for Windows
Running Warlords 2/3 on Vista or Windows 7
After noticing a sharp increase in request for help on the matter I decided to write this.
These are the most common problems with both Warlords games.
Problems:
1. Wont install on either OS
2. Installs but wont run.
3. Installs, runs, but doesn't display properly
Solutions:
1. Is your OS 64-bit? then your fresh out of luck as neither game is designed to run on a 64bit system and if it does run, is probably going to be highly unstable.
If not then you could try one or all of the following;
-Right-click the setup and run as administrator
-change the compatibility to XP or Windows 2000
-Copy the entire CD's contents to a folder on the desktop then run the setup.
-All of the above at once.
2. Once again you can try all the above instead applying them to the shortcut or exe for the game. You should as a matter of course ensure that your drivers are up to date if you have problems running the game.
3. If you get around the above two problems and run the game only to find that graphics are missing (generally the biggest problem), then there is only two real solutions to the problem:
-1: Try reinstalling the game, or use a friends copy.
-2: run the Direct X setup off the Warlords Cd, as this contains Direct X files designed for games run on this engine.
Hopefully the above helps someone to make one of these awesome games run.
Over and out,
Katnap_Devikat
Enlight Interactive Warlords BattleCry 3 for Windows Logo
Dead Pixels on Sharp Aquos 70" LED TV
If pixels are gone on all channels - Exchange it
Can't fix it yourself unless you are tv technician
It is quite common for few pixels to be dead but that is usualy not noticable
Feb 06, 2012 | Sharp LC70LE732U LCD TV
dear sir, i am a prepaid customer(9910345463), today i have noticed that Airtel is charging higher call charges against the actual usage. Today i have talked to cell no.9278862229 which lasted for 30 seconds,but Airtel has deducted 37 paise for the call. i request you plz look into the matter and inform the reseaon rajesh daga
Hello Rajesh
OK, unfortunately this is a matter which can only be sorted out by your service provider. You can call them on the toll free number, inform them on the increased charges. They will be able to correct it, or explain to you what the problem is.
Kind regards
Andrea
Nov 25, 2010 | Cell Phones
cd key? Warlords Battlecry 3
hey there welcome to fixya
Try warez-bb.org. Register, confirm your email and sign in. Go to appz requests and trades forum. Ask there they should have it. Good luck!
please remember to rate this solution
regards
magical ink
Jun 26, 2010 | Enlight Interactive Warlords BattleCry 3...
4,656 people viewed this tip
Top Enlight Interactive Video Game Consoles & Games Experts
James Wishart
Are you an Enlight Interactive Video Game Console and Game Expert? Answer questions, earn points and help others
