Tip & How-To about Computers & Internet
XP's UNIVERSAL KEY
If you are installing the windows xp in your computer, in the middle of the process, you need to enter the 25 digit licence key.
for different copies, we have different keys,..
Instead, you can have the UNIVERSAL KEY to enter here which works for all copies. this helps when you dont have the key or have a wrong key or mis spelt..
the key is..
K2KB2 - BDBGV - KP686 - D8T7X - HDMQ8
Computers & Internet Logo
After system recovery using recovery discs of "PowerSpec" error message "NTLDR is compressed PressCtrl Alt Del to restart" appears .How to fix it
When NTLDR is missing from your operating system it means that there is a problem with your boot loader, a bootstrap process that begins when you turn on the computer. A missing NTLDR means that your computer cannot boot to the operating system. This issue is only a problem on computers running Windows XP or previous operating systems as Windows 7 and Vista don't utilize NTLDR. Loose or Faulty IDE/EIDE hard disk drive cable. Failing to enable USB keyboard support in the BIOS. Many times this error is caused when the computer is attempting to boot from a non-bootable floppy disk or CD ROM First verify that no Floppy Diskette or CD is in the computer, unless you are attempting to boot from a diskette. Fixing the missing NTLDR is relatively easy so long as you have your installation disc.
Locate your Windows XP/2000 installation disc and place it in your CD/DVD ROM drive. If you don't have this disk, then you cannot proceed further. Restart your computer. When the computer restarts press any key on your keyboard when you are prompted, "Press any key to enter setup." Most computers are configured to boot to another device other than a hard drive. Since the Windows XP/2000 installation disk is bootable, you should see the prompt. However, if you don't see the prompt you may need to change your boot priority in your BIOS. To do so, enter the system BIOS by following the onscreen instructions upon startup. Then navigate to the Boot Priority menu and modify another device, such as a CD-ROM to boot prior to the hard drive. Then reboot your computer. After you have pressed any key, the Windows XP/2000 setup screen will appear. After loading, press the "R" key to repair the Windows installation. The screen will appear black. The computer requests which installation you would like to log in. Generally speaking, press "1" and "Enter." If you have more than one hard drive or more than one partition, the procedure may be different. You must know which hard drive or partition your Windows operating system is installed in. You are subsequently prompted for a password. If you haven't set up one up, you can just leave the query blank and press "Enter." The phrase "c:\WINDOWS>" and a blinking cursor subsequently appear. Type "copy d:\i386\ntldr c:\windows" (without quotes), where "D" is the letter of your CD/DVD ROM drive (your optical drive may be different, especially if you have more than one). Eject the CD from the drive and type "Exit" (without quotes) to restart your computer. The NTLDR file will be copied from the installation disc to your hard drive.
or If you've started your Windows XP computer and you see an error message to the effect that the "NTLDR" file is missing or corrupted, you've probably also noticed that the computer refuses to boot any further. This is because the NTLDR file is an integral part of the boot process and needs to be restored before the boot process can proceed normally.
Insert your Windows XP disc into your computer. Restart the computer and press any key on your keyboard when the message prompting you to do so appears. Press the "R" key to open the Recovery Console and then press "1" and "Enter" in order to select your operating system. Type in your Administrator password (if needed) and press "Enter." Type "copy d:\i386\ntldr c:\" and press "Enter" and then type "copy d:\i386\ntdetect.com c:\" and press "Enter." Restart your computer and let it boot up normally. Since the NTLDR is freshly restored, the computer boots up properly. Hope this helps.
Jan 16, 2013 | Computers & Internet
Error message "NTLDR is compressed" how to fix it
Jan 16, 2013 | Micro Electronics PowerSpec 6236 PC...
A problem occurred when windows tried to activate. Error Code 0xC004F063. the Software Licensing servies reported that the computer BIOS is missing a required license.
I can tell you why you are getting this error. How to fix it depends on the reason you are getting this error.
Windows software licensing means that a copy of Windows is only valid for a Single PC. As part of the installation process the Licence key is linked to the motherboard of the PC.
The error is telling you that the Licence key you have for Windows has been activated and linked to a specific Computer B IOS. You can re-activate it on that computer, you cannot install it on another computer.
There are 3 reasons you can be getting this error
  • You have changed the motherboard or the BIOS chip in your machine and you are re-installing Windows. The Licence will not be accepted and this breaks MS licensing agreement.
  • You are trying to re-use an existing Windows Licence on a different machine - Not allowed using a OEM (operator installed) version of Windows.
  • You have reinstalled Windows on your machine using a different installation disc - this can cause confusion when re-installing an OEM version of the software. e.g. Dell branded OEM Windows will only install to Dell machines.
Assuming the licence is valid for the machine and the Motherboard you need to Contact your machine provider to get a valid installation disc - they may well charge for this service.
Jan 23, 2011 | Computers & Internet
Installation
If you have a genuine version of Windows with a licence key, then download and install XP Service Pack 2 from the Microsoft website. You can also request a CD copy.
If you do not have a genuine copy with a licence key, then you will not be able to re-activate Windows XP once Sevice Pack 2 has installed.
Feb 20, 2008 | Philips GOGEAR SA6045 MP3 Player
175 people viewed this tip
David Payne
David Payne
