Tip & How-To about Computers & Internet
How to Solve Internet Explorer Error : object doesn't support this property or method
This could be an error related with:
  • Web page: Internal Source Code - We cannot troubleshoot.
  • ActiveX/Scripting, Java are blocked on your Computer: BySettings on IE or by your Firewall or Antivirus Program
  • Internet Related Files or Folders are facing Problems
  • Script Engine is either Corrupted or Obsolete
  • Video Adapter Drivers are either Corrupted or Obsolete
  • DirectX components are either Corrupted or Obsolete
The following Warning message will be shown in the Task Bar as well."Done, but with errors on the page"
Solution will be quite long. First solution contains 5 methods for Normal Users. Second solution is for Advanced Users. If one method doesn't solve you have to go to next method.
First method: Disable Script Debugging
  • For IE6:
  • Click on "Tools" menu and get "Internet Options"
  • Click on "Advanced" tab
  • Click on "Disable Script Debugging" check box if the box isNOT checked and Click "OK".
  • For IE7:
  • In the "Advanced" Tab, click to CLEAR the "Display a notification about every script error" and click "OK"
  • If the problem persists, go to next method.
Method 2:
  • If the problem persists, use all the below mentioned methods.
  • Use another Browser, User Account, Computer to verify that the page returns the same error every time.
  • If returns, it is a problem with that Web Page.
  • If the error doesn't occur while using another Browser or While in another User Account or on Another Computer, you have toAdjust some settings on your Computer.
  • Go to Method 3 to continue Troubleshooting.
Method 3:
  • We will Reset the settings (security) on ActiveX, Active Scripting and Java.
  • On the "Tools" menu, click on "Internet Options"
  • Click on "Security" tab
  • Click on the "Default Level" and Click on "OK".
  • Load the page again and check.
Method 4:
  • IE6:
  • On the "Internet Options" click on the "General" tab
  • Under the "Temporary Internet Files", click "Settings"
  • Click on "Delete Files" and lick "OK"
  • Click on "Delete Cookies" and click "OK"
  • Under "History", click on "Clear History" and click "Yes"
  • Click "OK"
  • IE7:
  • Under "Browsing History", click "Delete", and when you are prompted, click "Yes" to confirm
  • In the "Delete Browsing History" dialog box, under "Temporary Internet Files", click on "Delete Files", and when you are prompted, click "Yes" to confirm
  • Under "Cookies", click on "Delete Cookies", and when you are prompted, click "Yes" to confirm.
  • Under "History", click on "Delete History", and when you are prompted, click "Yes" to confirm
  • Click "Close", and then click "OK" to close the "Internet Options" dialog box.
Method 5: Advanced Troubleshooting for skilled users:
  • First step it to check and verify your Antivirus Suite or Firewalldo not Block ActiveX, Active Scripting and Java.
  • Check the AV or Firewall Settings.
  • If the problem persists, go to the next step.
  • Second Step is to check whether your AV is not set to SCANthe "Temporary Internet Files" (this might have been set for some AV sites by default) and/or the "Downloaded Program Files" folder.
  • Third Step is to Turn Off "Smooth Scrolling"
  • On the "Advanced" tab in the "Internet Options", click to Clearthe above mentioned option.
  • Click "OK".
  • On IE7, the Setting is Under "Browsing" on the "Advanced" tab.
  • Turn off "Hardware Acceleration" as the 5th Step.
  • Right click on the Desktop
  • Go to "Properties"
  • Go to "Settings" and click on "Advanced"
  • In the Next Window, click on "Troubleshooting"
  • Drag the "Hardware Acceleration" slider to "None"
  • This step Solves a Problem Related to your Video Adapter
  • Next step if the solution didn't work is to Update the current of DirectX
  • Microsoft DirectX
If you have further problems, use one of these links which are from Microsoft Help and Support
Try Microsoft Fix it to Automate the Troubleshooting Process. That will solve problems which I have not mentioned above.
Please contact Microsoft if the Issue Persists:Contact Us
Please kindly RATE this tip to encourage the Provider!
Have a good day!
Thanks for Using Fixya!
Computers & Internet Logo
script error while going to yahoo chat room
First try to enable scripting through Internet Explorer
Go to Internet Explorer,
Click "Tools"
Click "Internet Options."
Click "Security" tab.
Click "Custom Level" button.
Scroll down to "Script ActiveX.controls marked safe for scripting"- enable
Scroll down to "Scripting - Active scripting" - enable
Scroll down to "Scripting of Java applets" - enable
Click OK
Click OK
I hope it will work.
Please let me know.
Thanks.
Mar 31, 2012 | Yahoo Messenger
when i enter the chat room i got the notice... a error has occured in the script on this page line:7 char:2888 error:permision denied code:o url: http://yui.yahooapis.com/2.4.1/build/con... min.js
You may not have Internet Explorer as your default browser but it is coded with Yahoo Messenger
For this reason you must keep it up to date and the support software as well. You do not have to set it as default but you need to keep itclean.
Flashplayer FOR IE
Shockwaveplayer FOR IE
Java
Check out the Yahoo Messenger Scripting Help page
1) Visit this page and select your product version (Messenger version) using the drop box
http://help.yahoo.com/kb/index?page=prod...
2) Type into the search bar: ......... script error...........and hit 'Search'
3) Browse the section for your problem and your OS and click on the link
To enable scripting:Internet Explorer8
Click "Tools"
Click OK
Click OK
Restart IE Source(s):
Aug 18, 2011 | Yahoo Messenger
running script error
Method 1: Disable script debugging loadTOCNode(3, 'whattotry'); If the only sign of a problem is the error message, and Web sites are working, you can probably ignore the error. Also, if the problem only happens on one or two Web pages, it might be a problem with those pages. If you decide to ignore the errors, you can disable script debugging.
Note If this problem occurs on more than one or two sites, do not disable script debugging. Go to method 2 now.
To turn off the Scripting Debugger in Internet Explorer 6, follow these steps:
  1. On the Tools menu, click Internet Options.
  2. On the Advanced tab, click to select the Disable script debugging check box. and then click OK .
To turn off notification about every script error in Internet Explorer 7, follow these steps:
  2. On the Advanced tab, click to clear the Display a notification about every script error check box, and then click OK.
Method 2: Test a Web page from another user account, another browser, and another computer loadTOCNode(3, 'whattotry'); Use another user account, another browser, or another computer to view the Web pages that triggered a script error to determine whether the problem persists. If the script error persists, there may be a problem with the way the Web page is written. You can probably ignore the error and disable script debugging as described in method 1.
If the script error does not occur when you view the Web page from another user account, browser, or computer, the problem may be caused by files or by settings on your computer. Go to method 3 to continue to troubleshoot. Method 3: Verify that Active Scripting, ActiveX, and Java are not being blocked by Internet Explorer loadTOCNode(3, 'whattotry'); Active scripting, ActiveX, and Java are all involved in shaping the way information displays on a Web page. If these are blocked on your computer, it may disrupt the display of the Web page. Reset the Internet Explorer security settings to make sure these are not blocked. To do this, follow these steps:
  1. Start Internet Explorer.
  2. On the Tools menu, click Internet Options.
  3. In the Internet Options dialog box, click the Security tab.
  4. Click Default Level.
  5. Click OK.
Note ActiveX controls and Java programs are turned off at the High security level in Internet Explorer.
Try to open a Web page where you previously received a scripting error. If you do not receive the error, the issue is resolved. If the issue persists, go to Method 4. Method 4: Remove all the temporary Internet-related files loadTOCNode(3, 'whattotry'); Every time that you open a browser to view a Web page, your computer stores a local copy of that Web page in a temporary file. If the size of the temporary Internet files folder becomes too large, some display problems may occur when you open Web pages. Periodically clearing the folder might help resolve the issue.
To remove all the temporary Internet-related files from your computer when you use Internet Explorer 6, follow these steps:
  3. Click the General tab.
  4. Under Temporary Internet files, click Settings.
  5. Click Delete Files, and then click OK.
  6. Click Delete Cookies, and then click OK.
  7. Under History, click Clear History, and then click Yes.
  8. Click OK.
To remove all the temporary Internet-related files from your computer when you use Internet Explorer 7, follow these steps:
  4. Under Browsing History, click Delete, and when you are prompted, click Yes to confirm.
  5. In the Delete Browsing History dialog box, under Temporary Internet Files, click Delete Files, and when you are prompted, click Yes to confirm.
  6. Under Cookies, click Delete Cookies, and when you are prompted, click Yes to confirm.
  7. Under History, click Delete History, and when you are prompted, click Yes to confirm.
  8. Click Close, and then click OK to close the Internet Options dialog box.
Try to open a Web page where you previously received a scripting error. If you do not receive the error, the issue is resolved. If the issue persists, go to method 5. Method 5: Install the latest service pack and software updates for Internet Explorer 6 or Internet Explorer 7 loadTOCNode(3, 'whattotry'); If you do not have the latest service pack or software upgrades for Internet Explorer 6 or 7, download and install them. They may contain updates that can help resolve the issue.
Jul 06, 2010 | Computers & Internet
windows int. explorer keeps closing saying java script error
This article offers five methods that you can try to resolve the issue, and also presents some advanced troubleshooting tips that you can try. Try each method in the order presented until you resolve the issue. If one method does not work, try the next.
This article is intended for a beginning to intermediate computer user. You may find it easier to follow the steps if you print this article first.
  5. Click OK.
  8. Click OK.
To install Internet Explorer 6 Service Pack 1, visit the following Microsoft Web site:
http://www.microsoft.com/downloads/details.aspx?FamilyID=1e1550cb-5e5d-48f5-b02b-20b602228de6&displaylang=en (http://www.microsoft.com/downloads/details.aspx?FamilyID=1e1550cb-5e5d-48f5-b02b-20b602228de6&displaylang=en) Note Internet Explorer 6 Service Pack 1 is recommended for systems that are running versions of Windows earlier than Windows XP.
To install the most current software updates for Internet Explorer 6 or for Internet Explorer 7, visit the following Microsoft Web site:
http://windowsupdate.microsoft.com (http://windowsupdate.microsoft.com) Please leave me comment, if you need further assistance Thanks for using Fixya Please rate this solution Rnj VinodKumar
Dec 15, 2009 | Sun Java Desktop System
i already tried a new accnt but still my messages disappear when i press enter to send
This error is most likely from yahoo. Their system has been acting up recently. Try using their messenger for the web instead. www.messenger.yahoo.com/web
Oct 11, 2009 | Yahoo Messenger
1,501 people viewed this tip
David Payne
David Payne
