Tip & How-To about Computers & Internet
How to Make your Desktop/Notebook run Smoothly and Safely
  1. Always keep 30-50% free space in the drive where your OS is installed to have a better performance and less defragmentation.
  2. Have the best antivirus software thats very lite and which uses smaller resources of your system ram and scans quickly and powerfully.(recommended : ESET NOD32)
  3. Have your system defragemented once in a week to avoid larger fragmentation of your files which could affect the file and software to process slowly.
  4. Have your system scanned for all the software, system and registry errors to rectify and run your system so smoothly and error free.(Recommended: AUSLOGICS BOOSTSPEED)
  5. Do not have many startup process which could make a heavy usage of your ram and affect the perfomance of your system 50% down.
  6. Try not downloading any free version of softwares through internet which could harm your system and can also leak out your personal data/information.
  7. Avoid using the laptop so much in current and use it completely in battery unless the battery is fully drained to get a better life of your notebook battery.
  8. Avoid customizing or modifying the sytem files which can cause system crash or get any error in the process of your OS.
  9. Do not use any different software that doesn't suite your OS version which can cause malfunctioning of that particular software.
  10. Do not shutdown your system improperly which can cause you to loose any unsaved data or information and also cause damage to the system files.
  11. Do not format your system many times which can reduce the life of your Hard disk.
  12. Do not use any cracked version of OS in your computer which can cause you piracy problem.
  13. Always try to have the GENUINE version of any OS or Software to have a genuine system with all warranty and be a part of ANTI-PIRACY.
Computers & Internet Logo
Drive C shows low disc space but is only half full
This could be caused by a virus, or you could simply have a small HDD with a newer version of your OS. Certainly I recommend running a full scan with the free version of Ad-Aware Anti-Virus from Ad Aware Free Antivirus and Antispyware by Lavasoft Protection from... to start with. Also, if you have a smaller hard drive, something around 40GB or less, newer versions of the Windows OS will not consider the percentage of the drive's storage space in use, but only the raw amount of free space available on said drive.
Another possibility involves the paging file and its size, something which would be a concern on any modern OS. If your paging file, or virtual memory allocation, is too large, you can receive warnings about low disk space because even when it is not in use that storage space is counted as "in use" by your OS.
Finally, in general these types of problems can result from not performing routine maintenance on your HDD and its partition(s) and file system(s). Running a file-system integrity scan and a thorough defragmentation operation on your drive is a good idea just on principle alone.
Apr 29, 2014 | Computers & Internet
have problem? if so pls fix it
Possible that PC is hanging up as there is fault on the OS ( operating system) or a virus in the OS. Also it is possible that the back up( CMOS) has low voltage or the memory card is a suspect. In this case you need to check the voltage and also try and swap a memory card. If not the OS is a suspect.
It is best to go for a paid antivirus software which you can get in a package. Personally we are not recommending any particular company but you can try with Avira, Antivir, AVG, Kaspersky. It is always best to install the antivirus when the installation of the OS is done.
Now before this you can open the internet options in the browser and clean all the cookies, temporary internet files, defragment the drives and RESTORE the PC to an earlier set date.
You can use a registry cleaner like Advanced system care. Download from the site and check you system for corrupt files. Also use a good antivirus software which is active to keep your system performing without an attack on the OS. Remove all unnecessary programs installed which you do not use all the time and clean up the drives. This will free up the space and make your system faster.
If there is no response but the PC tends to work slower and occasionally hanging when a program is being executed then you might have to install the OS once again. Install the OS and then an antivirus before the drivers of the PC is installed.
Thank You for using Fixya
Sep 15, 2011 | Computers & Internet
What to do if laptop hangs continously?
Sep 13, 2011 | Computers & Internet
The screen on my Dell Inspiron Mini 1018 Netbook is flickering, freezing and refreshing, it sometimes renders my netbook unusable.
There is strip that connects the LCD with the mother board. That strip might be damaged or loose. You better take it to a service centre to get it checked before it gets worse or make the pixels in LCD dead.
Aug 16, 2011 | Computers & Internet
how can i delete viruses in my laptop?? what should i install? i already installed antivir but the other viruses can't be deleted :( please help
Possible that PC is hanging up as there is fault on the OS ( operating system) or a virus in the OS.It is best to go for a paid antivirus software which you can get in a package. Personally we are not recommending any particular company but you can try with Avira, Antivir, AVG, Kaspersky. It is always best to install the antivirus when the installation of the OS is done.
Aug 11, 2011 | Computers & Internet
167 people viewed this tip
David Payne
David Payne
