Tip & How-To about Creative Labs Zen Touch MP3 Player
How To Install A Battery In A Creative Labs Zen Touch Mp3 Player
1) Using a small Philps screwdriver, remove the two screws from the top of the back case cover (near the head phone jack) and unscrew the two remaining screws at the bottom of the back case cover.
2) Carefully wedge a guitar pick, or a small Flat Head screwdriver from the side of the unit, in between the two housings in the middle, unclipping the case clips, using your fingers, carefully pry open the back case cover.
3) Disconnect the power cable by gently pulling on the cable, if needed use the Flat Head screwdriver or needle nose pliers to carefully pull the connector out.
4) Using your finger or the tip of the screwdriver, carefully remove the battery from the glue inside the case cover.
5) Plug in the new battery by pushing the connector into the socket; use the tip of the screw driver if needed. Make sure the battery fits within the guide brackets and does not get in the way of the screw holes. Snap the cover back with the rest of the device, and reinstall the four screws. Charge the new battery for a minimum of 3 hours before the first use.
Creative Labs Zen Touch MP3 Player Logo
how to open the box of the treadmill
You have to lift up the back of the treadmill a little to access 2 phillips head screws that keep the motor cover on, (note that you will also have to unscrew a few phillips head screws on the bottom front of the cover as well in order to remove it completely). Before you begin lifting the back of the treadmill platform off the ground to access the screws underneath make sure the treadmill is on a zero incline setting and it helps to find a sturdy object you can rest the tail end off the treadmill on about 1 to 2 feet above the ground giving you enough room to access the screws underneath. Another option is to lift the treadmill platform all the way up and lock it in an upright position using the locking mechanism and lock handle that is located underneath the machine. I find this route to be unnecessary and cumbersome for what you want to do. Once you lift the treadmill up you will see the 2 small Phillips head screws near the front of the treadmill running platform that you need to unscrew in order to take off the motor cover. You also need to unscrew a couple small screws under the machine located on each side of the wood running board. These screw fasten the top inner plastic side covers onto the top of the running platform which needs to be taken off in order to access the back rollers. Make sure you collect the screws in a way that you will remember where they go later when you reassemble as this is your first time taking them out and you might forget later. Now with the bottom screws out, lower the back of the treadmill down level on the ground and pull off the motor cover, and the Left and Right INNER plastic running platform covers. With the inner covers removed you will find yet another small set of screws fasting the main plastic side covers to the running board which require an allen wrench to unscrew. Use the small wrench that came with the machine if you have it handy. With those off you can pull the main Left and Right plastic running board covers off, just make sure to carefully unsnap them from their snap points near the bottom rear of the machine. With all the covers removed you can now access the bolts that hold your treadmill rollers in place and the drive belt which you will have to slip on and off the motors drive pulley and the front roller using a pull and turn technique. The back rollers are simple and can be removed by unscrewing the tension bolts at the back of the treadmill and pulling the roller through and out of the belt. With drive belt set aside and all roller bolts removed you can take out the front roller in the same way you removed the back roller. Replace the treadmill belt and reassemble the machines components in the reverse fashion you disassembled them using these instructions. Doing this yourself will save you hundreds of dollars service man visits in the future.
Jun 27, 2014 | Epic View 550 Treadmill
I want to replace the battery. How do I open the unit? Jim
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jul 18, 2010 | Creative Labs Zen Touch MP3 Player
replace lcd screen
How to replace LCD Screen on a Zinc II
1. Take out the battery
2. unscrew the four torx4/torx5 screws including the one under warning label but no need to touch the phone idenity label ;)
3. unscrew the two side screws located near top
4. take out pen and any card in device
5. carefully remove back (now you will be able to see the circuit board)
6. looking at the phone LCD down so you see the circuit board remove screws (small Phillips/ cross-heads silver in color).
1.top left.
2. top right.
3. middle right near small cable.
Now you should be able to move the circuit board (do not force apart).
The LCD cable and keyboard cable are attached to the underside of the board.
1. Slide the phone 50% open (but keep phone LCD face down so you are look at the board phone the (keyboard being closest to you than main speaker).
2. Carefully lift left side of board (you should see the cables) using a small screwdriver Very Carefully pry them off the board (the should pop off with no force needed).
3. Slide phone fully open and now you are able to see all 4 torx screws that hold the front part of the phone on just under the circuit board.
* Bottom 2 are in small cut out boxes just under to circuit board you may need to slide the front up or down to align with the screws.
*The top 2 you should have notice when you fully opened the phone in normal use and looked at the back of the LCD at top behind speaker.
4. The front surround and LCD and buttons will come off. Carefully remove from bottom near the navigation buttons.
5. The phone should now be able to divide into the two sections with cables.
6. Unscrew the the LCD and the cable 2 top 2 bottom for LCD - but you have to also remove the button ribbon cable.
replace LCD and reverse process
*the LCD cable needs to be pushed into the socket on the underside of the circuit board (this can be tricky so take your time).
*Note: the keyboard cable is similar to the LCD cable but it has a smaller socket.
Feb 02, 2010 | O2 Xda Zinc Cellular Phone
info
  1. Using a small phillips head screwdriver, remove the six small screws off the back. Be careful not to lose the small screws.
  2. Using a small straight head screwdriver, insert it into one of the two slots at the top of the calculator and twist. The top of the calculator should pop open.
  3. Remove the back of the calculator.
  4. Using the straight screwdriver, insert it below the bottom of the two silver batteries and pop the batteries out.
  5. Replace the batteries with two new GPA76 batteries.
  6. Replace the cover and isert the screws.
Mar 26, 2008 | Texas Instruments TI-30XA Calculator
front cover change
hi there
this is the procdure...
First remove the back cover, the battery and the SIM card.
Now remove the top part of the back cover (the part above the camera). Do this by inserting a small flat bladed screwdriver between the white and black parts of the phone, and lever the screwdriver up like a small crowbar on either side of the lens. The black cover should slide up and off the phone.
Looking at the top of the phone, remove the small on/off button and put it in safe place. Also remember to remove the little mirror or rubber grommit from beside the camera lens and put that in the same safe place as the on/off button. Losing these little bits will cause you no end of pain as they are not available as spare parts.
The next bit to remove is a small green plastic bit of circuit board. It's clipped in and sprung against some data pins. Again using the flat bladed screwdriver, pop it off in the direction of the top of the phone.
The whole rear of the phone should now be exposed. Using a T6 torx screwdriver, unscrew the four small screws indicated. Put these screws in that safe place.
Once the screws are out, hold the phone like so, and squeeze gently on the sides and lower edge of the phone case, the pressure should be enough to create a small gap between the fascia and the sides, using a fingernail or thin plastic (like a credit card) make the gap bigger until the fascia pops off. Repeat on the opposite side of the phone if required.
The fascia should now lift off completely, exposing the front of the phone.
Push your replacement fascia on until it clicks into place, and reassemble the phone. if all has gone well, you should have a T310 that looks as nice as the one shown above.
All the Best.
Was this solution helpful? Show your Appreciation by rating it:
Feb 15, 2008 | Sony Ericsson T310 Cellular Phone
1,270 people viewed this tip
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
