Tip & How-To about Cell Phones
Blackberry PIN not accepted with desktop Manager
I recently plugged in my blackberry via USB to my computer and received a request to enter my password. If the password was incorrect 10 times then my blackberry would automatically wipe the data.
I had placed a security code to access my blackberry such as: 4404
When I tried typing this code on the BB desktop manager..on my computer. The code was not accepted. i tried over an over, until i realized the blackberrys number key also has a letter key.
Thus instead of typing the numbers 4404 on my computer, i typed the equivalent letter on the 4 key. if 4 is G then i typed gg0g
It worked !!
Cell Phones Logo
password was entered incorretly 3 times now it says wiping all data. now says scrubbing
As a security feature, the BlackBerry device is designed to allow a maximum of 10 attempts by the BlackBerry device user to type the correct password. After the tenth attempt, if the correct password has not been typed, all data is erased from the BlackBerry device in order to discourage its theft or misuse. If you are certain that the password you are typing into the BlackBerry device is correct, please complete the following steps.
  1. Deliberately type in an incorrect password five times on your BlackBerry device.
  2. Before the BlackBerry device allows a further attempt, you will be prompted to type the word blackberry in plain text.
  3. Instead of asterisks, the text you have been entering for the password will now show in plain text. Check to verify that it is correct
  4. If the password is still being rejected by your BlackBerry device as incorrect, connect the BlackBerry device to a computer that has BlackBerry Desktop Manager installed
  5. A prompt will appear in Desktop Manager to type the password for the BlackBerry device. Type in your password to rule out missed key strokes, incorrect symbols, or a problem with the BlackBerry device
  6. If the password you have given is still rejected, and your BlackBerry device is on a BlackBerry Enterprise Server that has software version 4.0 or greater, contact your BlackBerry Enterprise Server Administrator and request that your password be reset for you.
If you are not on a BlackBerry Enterprise Server and have forgotten your password, there is no way to have the password changed without wiping all data from your BlackBerry device.
Aug 04, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
i put a password on my blackberry and forgot it. now my phone is locked. how do i unlock it?
As a security feature, the BlackBerry device is designed to allow a maximum of 10 attempts by the BlackBerry device user to type the correct password. After the tenth attempt, if the correct password has not been typed, all data is erased from the BlackBerry device in order to discourage its theft or misuse.If you are certain that the password you are typing into the BlackBerry device is correct, please complete the following steps.
1) Deliberately type in an incorrect password five times on your BlackBerry device.
2) Before the BlackBerry device allows a further attempt, you will be prompted to type the word blackberry in plain text.
3) Instead of asterisks, the text you have been entering for the password will now show in plain text. Check to verify that it is correct
4) If the password is still being rejected by your BlackBerry device as incorrect, connect the BlackBerry device to a computer that has BlackBerry Desktop Manager installed
5) A prompt will appear in Desktop Manager to type the password for the BlackBerry device. Type in your password to rule out missed key strokes, incorrect symbols, or a problem with the BlackBerry device
6) If the password you have given is still rejected, and your BlackBerry device is on a BlackBerry Enterprise Server that has software version 4.0 or greater, contact your BlackBerry Enterprise Server Administrator and request that your password be reset for you. I
"enter blackberry"
As a security feature, the BlackBerry device is designed to allow a maximum of 10 attempts by the BlackBerry device user to type the correct password. After the tenth attempt, if the correct password has not been typed, all data is erased from the BlackBerry device in order to discourage its theft or misuse.If u r a blackberry enterprise user then contact ur BES administrator and request to reset the password.If u r not a blackberry enterprise user then there is no way to have the password changed without wiping all data from your BlackBerry device.
Jul 29, 2009 | RIM Blackberry Curve 8300
Keypad is locked on a blackberry storm i bought on craiglist
the only thing you can do is enter in the password incorrectly 10 times. This will reset the device and all of the data on it is wiped off. Your only option is to connect it to your computer and start over.
Jun 15, 2009 | RIM BlackBerry Storm 9530 Smartphone
I have a password lock on my black berry and whenever i try to enter my password in the password space, letters and numbers show up instead of the secrecy stars, and im on my 8/10 attempt and my passwords bank will be erased its 6/9/2009, help quick. how do i get it back to normal.
This is directly from RIM: Cause As a security feature, the BlackBerry device is designed to allow a maximum of 10 attempts by the BlackBerry device user to type the correct password. After the tenth attempt, if the correct password has not been typed, all data is erased from the BlackBerry device in order to discourage its theft or misuse. ------------------------------------------------- Resolution If you are certain that the password you are typing into the BlackBerry device is correct, please complete the following steps. 1. Deliberately type in an incorrect password five times on your BlackBerry device. Before the BlackBerry device allows a further attempt, you will be prompted to type the word blackberry in plain text. 2. Instead of asterisks, the text you have been entering for the password will now show in plain text. Check to verify that it is correct. 3. If the password is still being rejected by your BlackBerry device as incorrect, connect the BlackBerry device to a computer that has BlackBerry Desktop Manager installed. A prompt will appear in Desktop Manager to type the password for the BlackBerry device. Type in your password to rule out missed key strokes, incorrect symbols, or a problem with the BlackBerry device. 4. If the password you have given is still rejected, and your BlackBerry device is on a BlackBerry Enterprise Server that has software version 4.0 or greater, contact your BlackBerry Enterprise Server Administrator and request that your password be reset for you.
Jun 09, 2009 | AT&T Blackberry Curve 8300 Smartphone
155 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
