Tip & How-To about Computers & Internet
Setting up WPA and WPA2 Network security
If you have any questions on which network security to use, please see my tip, about wireless network security, also see, a word on passwords.
Note: these instructions are generalized for most common routers, if you are having trouble with your router, please post a question providing your routers model and what you are trying to set up, thank you.
First you must log into your router to change the settings. To do this, you need to user your web browser and type in the IP address of your router in the address bar like this: http://192.168.2.1/Note, the numbers I used in the example are the most common default IP address for routers, look in the user manual for your router for your IP address, if it is 67.73.736.93 for example (I dont think any routers use that but its an example) then you would use: http://67.73.736.93/
Also please use the user manual for your router for information on how to change your routers default administrator password, this will prevent others from changing your network settings.
Now you will be at the main page for your router. There should be a column on the left or at the top of the page with options.
find and click on "security" or "wireless security"click on the "security type" drop down box and select, WPA, click on "authentication" drop down box, and select either WPA or WPA-2, some have an option to use both, this is good for networks that are running some older machines as well as new.
enter a passkey in the box, write it down.
if there is a checkbox that says "obscure psk" make sure it is checked.
when you click "done" or "save" your router will restart,then go to your computer and connect to your network, it will as you for your password that you just created, type it in, and select "remember this network".
congradulaions, you are done!!
Computers & Internet Logo
how do i hook my mi-fi internet to the xbox 360? i have purchased an adapter and can not figure out how to get the internet working
Here's how to configure your wireless settings:
  1. On the console, go to My Xbox, and then select System Settings.
  2. Select Network Settings.
  3. If you are prompted to select a wireless network, complete these steps, otherwise skip to step 4.
    1. Select the name of your wireless network.
    2. Enter your wireless network password and select Done.
    3. The console will automatically try connecting to Xbox LIVE. If you get an error message, go to the following webpage for help: support.xbox.com/pages/xbox-live/troubleshoot/connection-issues/connect-xbox-live.aspx (http://support.xbox.com/pages/xbox-live/troubleshoot/connection-issues/connect-xbox-live.aspx)
    Note If you do not see the name of your wireless network, select Advanced Options. Then select Specify Unlisted Network and enter your wireless network name. Select your wireless security type (WEP, WPA, WPA, or No Security). This security type needs to match the security of your wireless network.
  4. Select Configure Network.
  5. On the Basic Settings tab, select Wireless Mode.
    Note If wireless mode is not available and you are using the black Wireless N Networking Adapter, try using the software installation disc included with the adapter. For more information about how to do this, please see the following article: 977641 (http://support.microsoft.com/kb/977641/ ) How to set up the Xbox 360 Wireless N Networking Adapter
  6. Select Scan for Networks.
  7. Select your wireless network name.
    If your network is not listed, try the following:
    1. Select Specify Unlisted Network, and enter your wireless network name (also referred to as your Service Set Identifier [SSID]).
    2. Select your wireless security: WEP, WPA, WPA2, or No Security (if your network doesn't have a password).
      If you can't connect to your wireless network, try improving your wireless signal using the tips in the following article: 909336 (http://support.microsoft.com/kb/909336/ ) Your Xbox 360 console receives a weak wireless signal
  8. Enter your wireless network password, and then select Done.
    Note Make sure that you have entered the correct password. An incorrect password might allow your console to connect to your wireless network, but you might receive an IP address error when you test your Xbox LIVE connection.
  9. Press B on your controller, and then select Test Xbox LIVE Connection.
Mar 07, 2011 | Microsoft Xbox 360 Console
router password
>If you're trying to put password for the Router, then type "http://192.168.0.1" into the address bar, then hit "Enter."
>Use "Admin" as the username and leave the password blank when the login screen appears.
>Please click on Administrator settings and change the User Name and Password.
If you're trying to put a password/secure the Wireless network, then follow the steps:
>In the Router setup page, click on Wireless Settings.
>Under Wireless Security Mode, select Security Mode: WEP/WPA/WPA2.
>Enter the Security Key manually or enter the Phrase to generate the Security key automatically (only in WPA/WPA2) and save the settings.
>Please note the Security Key to connect to the Wireless Networ.
>The Wireless is secured now.
Good Luck!!!!
Jul 02, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
how to get my wep
A. Checking the Wireless Settings of the Router
Note: You need to use a computer hardwired to the router to check the wireless settings.
1. Open any web browser like Internet Explorer or Mozilla Firefox.
2. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
3. A window will prompt for a username and password. The default username is "admin" and the default password is "password".
Note: Username and password are case sensitive. If it does not take password as the password, you might have changed it when you ran the NETGEAR Setup CD so please try other passwords.
4. When the setup page opens, click on the Wireless Settings under Setup and take note of the SSID.
5. You may also change the wireless channel here. We suggest channels 1, 6 and 11.
6. At the bottom of the page, look for the Security Options. If in case that the security is set to WEP or WPA-PSK, we have to enter the same wireless security on all wireless PCs. To make sure of the key, we can try modifying the security. Please refer to the following:
For WEP: Select Key 1 and enter 10 hexadecimal digits (0-9 and A-F) on the empty box beside it. Then, click on Apply.
For WPA-PSK: Enter an alphanumeric key (minimum of 8 characters) on the Passphrase box and click on Apply.
Note: The Key and Passphrase are case-sensitive.
7. On the left pane, please scroll down and click on Wireless Settings under Advanced. Please make sure that the boxes for Enable Wireless Router Radio and Enable SSID Broadcast are checked.
8. Click on the Setup Access List button and uncheck the box Turn Access Control On.
9. Click the Apply button.
B. Connecting to the Wireless Network
For Windows XP Service Pack 1:
1. Please right click on the Wireless icon on the right lower end portion of your computer. Then click on View Available Wireless Networks.
2. Click on the Advanced tab.
3. Please delete all the preferred networks then click on OK.
4. Right click on the Wireless icon again and click on View Available Wireless Networks.
5. Please select your network and click on Connect. If you have Wired Equivalent Privacy (WEP) or Wi-fi Protected Access (WPA) enabled on the router, it will ask you for the network key. Please type in the Network Key and then confirm it.
6. Make sure not to enable IEEE and then click on Connect.
For Windows XP Service Pack 2:
2. Click on the Change Advanced Settings.
3. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
4. Right click on the Wireless icon then click on View Available Wireless Networks.
5. Select your network and click on Connect.
6. If you have Wired Equivalent Privacy (WEP) or Wi-Fi Protected Access (WPA) enabled on the router, it will ask you for the network key. Type in the network key and confirm it. Then click on Connect.
For Windows Vista:
1. Click Start then select Connect To.
2. Connect to a network window will show up.
3. Select your wireless network and click Connect.
4. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
Note: You may use the wireless utility of your wireless adapter in connecting to the wireless network but you need to clear "Use Windows to configure my wireless networks" on the Wireless Networks tab.
However, if this does not resolve the issue we will need to get some additional details from you to be able to assist you further. I have summarized my questions below:
1. Can your computer go online when it is hardwired to the router?
2. What wireless adapter are you using?
3. What is the operating system of your computer?
Apr 26, 2010 | NetGear RangeMax WPN824 Router
its not transmitting the wireless signal to my laptop. i'm being asked for a security key. where do i find it?
o Wireless Connection Found in Range
1. Please open any web browser like Internet Explorer or Netscape Navigator.
3. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
Note: If it does not take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the Setup CD to reconfigure it.
4. Click the Wireless Settings under Advanced tab.
5. Check the box under Enable Wireless Router Radio and Enable Wireless SSID Broadcast.
6. Click the Wireless Settings under Setup.
7. Change Channel (recommended are 1, 6 and 11).
8. Change the SSID to uniquely identify your network. You might have a similar SSID with your neighbor.
Note: Do not change the SSID if there are already other wireless computers that can connect to the network.
Other factors that you may consider when you are not able to view any available wireless network:
a. Switch for the wireless adapter is turned off
b. Distance between the wireless router and computer
c. Possible wireless interferences
1. Open any web browser like Internet Explorer or Netscape Navigator.
Note: If it does not take password as the password, you might have changed it when you ran the NETGEAR Setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the Setup CD to reconfigure it.
For Windows Vista:
Jul 12, 2009 | NetGear WGR614 54 Mbps Wireless Router -...
2,086 people viewed this tip
David Payne
David Payne
