Tip & How-To about Computers & Internet
Setting up WEP Network Security
If you have any questions on which network security to use, please see my tip, about wireless network security, also see, a word on passwords.
Note: these instructions are generalized for most common routers, if you are having trouble with your router, please post a question providing your routers model and what you are trying to set up, thank you.
First you must log into your router to change the settings. To do this, you need to user your web browser and type in the IP address of your router in the address bar like this: http://192.168.2.1/ Note, the numbers I used in the example are the most common default IP address for routers, look in the user manual for your router for your IP address, if it is 67.73.736.93 for example (I dont think any routers use that but its an example) then you would use: http://67.73.736.93/
Also please use the user manual for your router for information on how to change your routers default administrator password, this will prevent others from changing your network settings.
Now you will be at the main page for your router. There should be a column on the left or at the top of the page with options.
find and click on "security" or "wireless security" click on the "security type" drop down box and select, WEP, if there are multiple options for WEP, select the one with the biggest number at the end, this is just to select the depth of the encryption.
enter a passkey in the box or boxes, write it down.
when you click "done" or "save" your router will restart, then go to your computer and connect to your network, it will as you for your password that you just created, type it in, and select "remember this network".
congradulaions, you are done!!
Computers & Internet Logo
trying to secure wireless network
Welcome to Fixya. If you want to secure the network you all you need to do is to access the router settings page and put a security either WEP, WPA or WPA2 and a Network Key or Passphrase.
To access the router page you need a working computer that is connected to the router. To access the router page just open a browser then type 192.168.2.1, the Default password is blank
Click on Security under Wireless, Select WEP, WPA or WPA2 and personalize a Security Key or Network Key (Passphrase). Security Key serves as a password on the network.
If you have questions please let me know. Thanks for using Fixya.
Mar 25, 2011 | Belkin (F5D7633UK4A) Wireless Router
How do I change the ssid and reset security
Welcome to Fixya. If you need the to change the SSID and Network Key you need to access the Wireless Settings Page.
To access the router page just open a browser then type 192.168.1.1, the Default username is blank and the password is admin. Go to the Wireless Tab select Wireless Security you will see the SSID you can personalize it and under the Security Mode you will see there Network Key or Security Key. The Network Key or Security Key serves as a password or security code on your network to make it secure.
You can also reset the router by pressing the Reset button at the back of it for 15-30 seconds using a Pen and a Paper Clip.
Mar 05, 2011 | Linksys Wireless-G WRT54G Router
At&t installed a new modem, now my linksys wrt54g doesn't work. Do I need to reset it? My network password has changed. What steps do I take?
Hi. Thanks for your question.
  1. First thing to try would be to unplug power connectors on both router and modem. Once you connect them together right with ethernet cable power modem first and then router
  2. If first thing don't work I would advice to reset router to it's factory settings by pressing reset button on the back of it (you will need to do that with some pin, or tip of the pen)
  3. Once router is restarted repeat step 1.
  • Your network may come up unsecured on your PC, so you will need to secure it.
Please see this link for informations on how to get into your routers settings.------->http://www.fixya.com/support/r4695161-change_wireless_network_password_forgott
Please ignore the part about cable in it because you can connect to yours wireless.
  1. Once your on settings page go to wireless tab and then security. Choose your new password and remember to save it before you leave the page.
  2. Once all this is done please reconnect your PC to the network using your new password.
Good luck and please do not hesitate to ask more questions if in need. Thank You for using FixYa
Dec 17, 2010 | Linksys Wireless-G WRT54G Router
router password
>If you're trying to put password for the Router, then type "http://192.168.0.1" into the address bar, then hit "Enter."
>Use "Admin" as the username and leave the password blank when the login screen appears.
>Please click on Administrator settings and change the User Name and Password.
If you're trying to put a password/secure the Wireless network, then follow the steps:
>In the Router setup page, click on Wireless Settings.
>Under Wireless Security Mode, select Security Mode: WEP/WPA/WPA2.
>Enter the Security Key manually or enter the Phrase to generate the Security key automatically (only in WPA/WPA2) and save the settings.
>Please note the Security Key to connect to the Wireless Networ.
>The Wireless is secured now.
Good Luck!!!!
Jul 02, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
628 people viewed this tip
David Payne
David Payne
