Tip & How-To about Computers & Internet
How to Erase a Burned CD
CD-RW stands for CD re-writeable. This type of disc can be written on or "burned" multiple times. However, in order to burn music or data onto a CD-RW that already has something on it, you must first erase the current contents of the disc. No special software is needed to do this, as you can do it with the Windows Media Player program, which already comes installed on all computers with the Windows operating system. Regular CD-R discs cannot be erased or reused--the discs must be labeled as CD-RW.
Instructions
Step 1.
Click on the "Start" menu button in the lower left-hand corner of the screen. Select "Windows Media Player" from the pop-up menu.
Step 2.
Select the "Library" tab in the main Windows Media Player screen.
Step 3.
Insert the CD-RW that you want to erase in the CD-ROM drive. Close the "AutoPlay" window if it appears.
Step 4.
Right-click the CD-ROM drive in the "Navigation" pane on the left side of Windows Media Player. Select "Erase disc" from the drop-down menu. This will automatically erase the contents of the disc.
Computers & Internet Logo
How do I remove the write protection on a burnable music CD? I am trying to reformat a burnable CD and i keep getting a message saying the disc is write protected and wont let me continue.
Hi
You do not say which operating system you are using.
I always advise askers (and answerers too) to use ordinary language to describe and identify things, devices, situations and problems and to avoid technical jargon as much as possible. Where jargon is unavoidable, I advise that care is taken to use technical terms as accurately as possible and that alternative terms, definitions and clarifications are always added in order to aid understanding and minimize confusion.
Your expression "reformat" is unclear.
To wipe the entire storage area or Partition (structured division of a storage area) of storage devices or media that previously contained data is to 'format'.
To "reformat" means, in ordinary language, to return something to its original condition. The term "reformat" is not conventionally used in computer terminology, probably because no storage area, once written in, can ever truly be restored to a virgin state. Formatting does not really wipe data; it just merely instructs and enables the operating system to ignore, or 'be blind' to it. All data written to a storage area can technically be recovered and read, if the right tools, software and techniques are applied. This is why law enforcement agencies and commercial forensic Data Recovery laboratories are able to recover and access lost or deleted data.
So please avoid the word "reformat", which can be confusing because it is sometimes loosely (but wrongly) used as an alternative term for 'Restoration' (restoring a computer to its Factory Settings).
Your expression "burnable music CD" is also unclear.
The term "burnable" (or the more commonly used term, 'writable') is usually used to describe a disc on which it is possible to burn data (information, documents, music, pictures, spreadsheets, designs, drawings, web designs, templates etc.), but onto which no data has yet been burned.
If data already exists on a writable disc, then the disc is usually described as a 'burned'.
Therefore, by definition, a writable "music CD" is a 'burned' rather than a "burnable" CD.
There are 2 types of writable CDs.
CD-R, which can be burned only once and on which any data burned is permanent and cannot be erased, overwritten or added to.
CD-RW can be burned multiple times, can have data burned on it, additional data added to it, can have the data on it overwritten by new data and can have some or all data deleted from it.
Write protection is a security tool to prevent data being deleted unwittingly and can be applied to any device (Internal and External Hard Drives, USB Flash Drives [often called Memory Sticks or Pen Drives], Flash Memory Cards) or writable Media (writable CDs, VCDs [Video CDs], or DVDs).
The Write Protection function for writable CDs or DVDs is usually controlled in the Tools Tab of specialist software used to burn the data onto the discs (such as Nero).
If you are trying to format a burned CD-R or a Write Protection enabled CD-RW (both impossible), this would explain your "This Disc is Write Protected" error message.
If you want to delete data from a CD-RW, you do not need to format it. You can just overwrite it or delete the data from it using the Tools option in your burning software.
The much criticized, built-in CD Burning Tool in Windows is very limited in terms function and controllability. If you a fair to large amount of burning, a full, function dedicated Burning Program such as the various versions of Nero or Ashampoo Burning, would give you much more flexibility and control over your burning operations.
If you currently burn using the simple, built-in CD Burning Tool in Windows, your flexibility and control is severely limited.
I hope this helps.
If this answer does help you, please take the time to rate it. This helps answerers better understand the needs and the point of view of the asker and guides us in exploring the best ways to provide useful, high quality answers.
If you need further help, please feel free to post another question or add a comment to this question.
Thanks for using FixYa.
Sep 01, 2011 | Computers & Internet
how to copy anything else on finalised DVD or - to HDD on samsung HR 755
If the disk is finalized you can't normally write anything else.
The words "Finalizing" and "Closing" are used interchangeably by most recording applications. To "Finalize" or "Close" a disc means that no additional data can be written to it. This is done when the last session's lead-in is written. The option to close a disc is usually selected after all of the data that will be written has been placed in the project window, and the user knows that no more data will be added to the disc in subsequent recording sessions. The next writable address on the disc is not recorded in that lead-in, so the CD recorder, in subsequent attempts to write, has no way of knowing where to begin writing.
Mar 09, 2008 | Televison & Video
I cant burn my music onto CDs and my computer tells me i dont have a cd burning software when i should have one
you could use this burnaware its totally free if you dont like it just uninstall it also there are plenty of free burning sofware cnetdownload.com or majorgeeks
http://www.majorgeeks.com/BurnAware_Free_d5839.html
BurnAware Free is one of the most popular free CD, DVD, Blu-ray Disc burning software available for Windows.
Using this program you can easily create and burn Audio and MP3 CD, Data and DVD-Video disc, ISO and Cue Image,
erase or format rewritable disc, copy your CD or DVD to ISO image.
http://www.majorgeeks.com/CDBurnerXP_d4242.html
http://download.cnet.com/active-iso-burner/3000-2646_4-10602452.html
Active ISO Burner will allow you to burn an ISO image file to CD-R, CD-RW, DVD-R, DVD+R, DVD+R DL(Dual Layer), DVD-RW and DVD+RW (including double layer, DL). Active@ ISO Burner software accepts command line parameters to automate ISO images burning process.
http://download.cnet.com/instant-cd-dvd-burner/3000-2646_4-10393316.html
Burn audio, video, and data CDs/DVDs and create and burn ISO files. Instant CD & DVD Burner is the ideal choice for anyone looking for a simple but full featured CD/DVD burner. Build and burn ISO files on the fly and compile all kinds of audio, video, and data CDs and DVDs from any kind of file (MP3, WAV, AVI, MPEG, DIVX, XVID). Instant CD & DVD Burner supports all major drives including CD-R, CD-RW, DVD-R, DVD+R, DVD-RW, DVD+RW, and DVD-RAM (SCSI, IDE, EIDE, and USB 1.0 and 2.0).
http://download.cnet.com/burn4free-cd-and-dvd/3000-2646_4-10217894.html
Burn4Free CD and DVD is a burning solution that's compatible with more than 3,000 DVD, Blu-ray and CD burners. Burn data and audio from different file types (WAV, WMA, MP3, OGG, FLAC, WavPack, and CDA). Burn and save ISO files, open and save your project to disk, verify content, print compilations, copy DVD, copy BLU RAY and import your audio compilation from M3U and ASX playlists. The drives supported include dual-layer DVD, CD-R, CD-RW, DVD-R, DVD+R, DVD-RW, DVD+RW, and DVD-RAM, BD-R, BD-RE (SCSI, IDE, EIDE, and USB 1.0 and 2.0).
http://download.cnet.com/burnaware-free/3000-2646_4-10878661.html?tag=mncol;8
BurnAware Free is a full-fledged disc burning tool - fast, lightweight, feature-packed and, most importantly, 100% free. The program burns all types of CD, DVD and Blu-Ray discs containing data, digital photos, music and video. With BurnAware Free, you will be able to create bootable or multi session CDs and DVDs, high-quality audio CDs from your collection of MP3, WAV, WMA, OGG, M4A, AAC and FLAC files, burn disc images, copy discs to backup ISO images and do a whole lot more.
http://download.cnet.com/Ashampoo-Burning-Studio-Free/3000-2646_4-10776287.html
Multi-disc file backup and restore on CDs, DVDs and Blu-ray discs; create compressed backup archives with powerful password protection; split archives automatically across multiple CDs, DVDs or Blu-ray discs; restore archive contents to their original locations; integrated Audio CD ripper store your audio tracks as WMA or WAV files; new option for setting the number of copies you want to burn (available for all disc formats); discs can now be verified immediately without being ejected first (if the drive supports this feature); numerous other small improvements that make the program easier to use and more effective; burn files and folders on data CDs/DVDs/Blu-ray discs; burn Audio CDs from WAV, MP3, FLAC, WMA and Ogg Vorbis files; burn MP3-CDs from your MP3 files; burn Video DVD, Video CD (VCD) or Super Video CD (S-VCD); create and burn CD/DVD/Blu-ray disc images; burn speed and other options can all be set automatically.
http://download.cnet.com/Macrium-Reflect-Free/3000-2242_4-10845728.html
Macrium Reflect Free Edition. An award winning disk imaging solution for free. A complete disaster recovery solution for your home and office. Protect your personal documents, photos, music and e-mails. Upgrade your hard disk or try new operating systems in the safe knowledge that everything is securely saved in an easily recovered backup file. Macrium Reflect supports backup to local, network and USB drives as well as burning to all DVD formats. This version is for non-commercial home use.
http://download.cnet.com/ImgBurn/3000-2646_4-10847481.html
ImgBurn is a lightweight CD/DVD/HD-DVD/Blu-ray burning application that has several modes, each for performing a different task: Read - read a disc to an image file; Build - creates an image file from files on your computer or network (you also can write the files directly to a disc); Write - write an image file to a disc; Verify - ensure that a disc is 100% readable (you can also have ImgBurn compare it against a given image file to ensure the actual data is correct); and Discovery - used in combination with DVDInfoPro, you can check the quality of the burns your drive is producing.
Apr 19, 2011 | HP Computers & Internet
I cannot burn a music CD from Napster. My blank CD is a CD-R. Do I need RW?
No you do not need RW. With the CD-R you can only burn to it once. With RW you can burn to it multiple times plus erase it.
Most cd burners work with CD+R and CD-R but it is best to be sure.
Be sure to try more than one of your CD-R discs. I've brought out a new cd burner on a warranty repair in the past and found that the customers cd burner was fine and when a different CD-R was tried they were able to burn onto a cd without a problem.
Sep 06, 2008 | Computers & Internet
DVD+RW problem
When burning CD/DVD use a lower burning method... as not to rush data to burn and make sure that before burning the let it verify or test the data burned on the CD/DVD... it takes time, but be patient, after all it is your data.
Dec 10, 2007 | LaCie d2 DVD-RW Burner
192 people viewed this tip
David Payne
David Payne
