Tip & How-To about Video Game Consoles & Games
How To Turn On Recovery Mode On PS3
To turn on recovery mode on your PS3 make sure you have your PS3 off,an controller charger and a controller (Does not matter what kind. EX:Afterglow,Dualshock 3 etc.). Next hold the on button on the PS3 till it turns off again. Then hold the power button on the PS3 again and when you hear two beeps really fast let go. Then it well ask you to plug your charger in and put your Dualshock 3 controller on it. It does not have to be Dualshock 3. After you have done that the recovery menu should appear. There you go your PS3 is now in recovery mode!
Video Game Consoles & Games Logo
ps3 keeps freezing during mw2
You need to RESTORE FILE SYSTEM on your ps3.
Follow this guide.
HOW TO GO TO THE RECOVERY MENU OF PS3 SYSTEM
1. Make sure the ps3 is plugged in (stand by mode).
2. Put out your usb cable for the controller and the controller itself (do not connect yet).
3. Hold down power firmly, ps3 will turn on and then turn off, release power button when it turns off.
4. Hold down power again, you will hear a beep and then a double beep, when you hear that double beep release the power button.
5. Now you should be seeing something in your monitor that say "Connect usb controller", do just that.
6. After connecting the controller press PS button.
7. You are now in the recovery menu.
8. To fix the problem of corrupt data you can choose #3.
9. If you want to format your hard drive choose #5. Be aware that this option will delete everything that is in your hard drive.
10. Remember that doing #3 and #5 is not 100% to fix the problem of corrupt data, I say about 70%.
Jan 19, 2010 | Sony Playstation 3 (PS3) Console
PS3 turns on and wave keeps going across screen. will not load game or home menu
Try to restore file system on your ps3 or restore ps3 system.
Here is how.
3. Hold down power firmly, ps3 will turn on and then turn off, release power button when t turns off.
Jan 18, 2010 | Sony Playstation 3 (PS3) Console
My Ps3 is sending off a sequence of colored lights blinking and shut off.
Try to do #3 or #5 option of the recovery menu. Follow this guide.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} HOW TO GO TO THE RECOVERY MENU OF PS3 SYSTEM
Jan 16, 2010 | Sony PS3 40GB Best Sellers Bundle Console
wont show anything
Try to restore your ps3 system in the recovery menu.
Here is how.
Hope this will help you.
Jan 16, 2010 | Sony Playstation 3 (PS3) Console
rebuilding database
Go to the recovery menu of your ps3and do it manually.
Follow this guide.
8. To rebuild data base choose #4.
9. If that do not fix the problem choose #3. Your last option is #5 if everything fails. But t will delete all the data in your hard drive.
463 people viewed this tip
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
