Tip & How-To about Cell Phones
Convert XviD to iPhone 4-Aunsoft XviD to iPhone 4 Converter Xvid is a MPEG-4 video codec for PC. Its purpose is to compress video in order to allow for faster transmission over computer networks or for more efficient storage on computer disks. Hence, Xvid can somewhat be seen as a ZIP for video. Xvid removes information from video that is not important for human perception in order to achieve very high compression rates while still keeping very good visual quality. However, XviD formats can not play on your Apple's iPhone 4. So If you have a lot of XviD files and want to play on iPhone 4, you should convert them. How to convert and watch XviD video on iPhone 4? This article will show you the way to convert XviD to iPhone 4 for enjoyment with Aunsoft iPhone 4 Video Converter (For Mac User: Aunsoft iPhone 4 Converter for Mac). And the whole process of XviD to iPhone 4 converting is as easy as pie for you. Step-by-step Guide: How to Play XviD Videos on iPhone 4? Step1: Download and install Aunsoft XviD to iPhone 4 Converter. It is a very safe and 100 % clean software and works very well for iPhone 4. So just run it. Step2: Load videos to this iPhone 4 video converter. Click "Add" button to load your XviD files to this best iPhone 4 video converter. Step3: Select output format for your iPhone 4. Here you can select "iPhone 4 MPEG-4 640*480 (*.mp4) or iPhone 4 H.264 720P (*.mp4)" as output video for iPhone 4. Step4: Start converting your XviD videos to iPhone 4 by hitting the "Convert" button. After conversion, please connect your iPhone 4 to PC and transfer those converted MP4 video to your iPhone 4 via iTunes. Then, you can enjoy and play XviD on iPhone 4.
Cell Phones Logo
i have g4 mac 9.2. i need saported softwer for braus & plye vediyu
Leawo Video Converter is an all-in-one best video converter for downloading to convert videos among popular formats like AVI, MPEG, WMV, MP4, FLV, RM, MOV, Xvid, 3GP, etc., transform audios between MP3, WMA, WAV, M4A, AAC and AC3 audios, and create fascinating photos from video files.
Oct 04, 2010 | FLVPlayer4Free
My Blu-Ray Ripper Reveiws Okay so I spent hours playing with different options for ripping blu-rays into a format that could be transferred to my Xoom and I would like to share what I have learned. The Rippers I started with some research and downloaded six or seven different programs designed for ripping blu-rays that were recommended some where on the web. I almost immediately discarded all but three rippers. Two were immediately ruled out after just examining the UI and noticing the lack of customization options. Another three were ruled out based on the fact they required a separate program called AnyDVD to run at all. This didn't bother me too much but further investigation found that AnyDVD costs $60+ in itself and does not offer the most user friendly experience. It's also worth noting I did not try out the beta of DVD Catalyst because it also requires AnyDVD or a similar program running in unison both of which would be added cost and added hassle. If your only looking to rip DVDs then DVD Catalyst for only $10 is the way to go from what I hear. What I ended up with were three blu-ray ripping trials. DVDFab Blu-ray Ripper - $60 Pavtube Blu-Ray Ripper - $49 Aunsoft Blu-Ray Ripper - $49 At first glance Pavtube and Aunsoft seemed almost identical in UI but they performed very different. Customization DVDFab was the first ripper I tried and I was very disappointed with the lack of control when ripping the blu-rays. There were nine different profiles to choose from when selecting .mp4 output format. Five of which had either 'ipad' or 'iphone' in the name and had very low max resolution outputs. In the end the only profile that was workable was the basic profile for h264 and for some reason did not support 1920x1080 resolution. Pavtube and Aunsoft had, like I mentioned, identical UIs and actually shared identical customization options. In addition to having many more built in profiles for everything from different Android phones and IPhones to gaming consoles and even power points, it also had basic profiles for common video formats. Where both Pavtube and Aunsoft set themselves apart from DVDFab was in the customization of these profiles. While DVDFab attempted to give me control of resolution, frame rate, bit rate, and audio, Pavtube and Aunsoft actually allowed me to change these to an assortment of options including 1920x1080 at multiple frame rates. Testing In order to get a good base line of these programs I popped in Avatar on blu-ray into my blu-ray rom and selected a chapter to use as testing so I didn't need to rip the entire movie every time. From here on you will see me post settings in the form: Codec: [codec used, file type always .mp4] Resolution: [resolution] Bit Rate: [bit rate] Size: [file size generated] Speed: [time it took to rip, in minutes] In DVDFab I was only able to make one good base test due to the lack of customization. I set the settings to: Codec: h264 Resolution: 1680x946 Bit Rate: 5000 Size: 130mb Speed: 9:33 This test led me to believe that DVDFab was a possibility because the picture looked phenomenal with good 3d depth and very little artifacting around moving objects. The problem was that it was laggy. It took 10-15 seconds for what appeared to be buffering before the clip would smooth out and then I would get bullet lag quiet often. I was confident this would be improved if I played with the settings but found that quality had to really be reduced in order for the clip to smooth out. DVDFab was essentially ruled out. I then put together some test batches for both Pavtube and Aunsoft. I chose to go with four different profiles for each program. h264 with HD standards, h264 base standards, MPEG 4 (xvid) with HD standards, and MPEG 4 (xvid) with base standards. These were the final settings and results: Note: The chapter I chose was 3:34 long and my computer is using an Nvidia GTX 570 paired with an Intel E6750 2.66GHz dual core processor. You can use this information to judge the speed it took to rip these files. CUDA acceleration was on for all but the first video, CUDA is an Nvidia technology that speeds up the encoding and decoding of h264 files which is the reason the h264 files were significantly faster than the xvid files. PavTube 4 files Codec: h264 HD Resolution: 1920x1080 Bit Rate: 9000 Size: 230mb Speed: 12:57 (CUDA acceleration was off) Codec: MPEG(xvid) HD Resolution: 1920x1080 Bit Rate: 12000 Size: 307mb Speed: 8:40 Codec: h264 Resolution: 1920x1080 Bit Rate: 9000 Size: 232mb Speed: 3:20 Codec: MPEG(xvid) Resolution: 1920x1080 Bit Rate: 12000 Size: 307mb Speed: 8:40 Aunsoft 4 files Codec: h264 HD Resolution: 1920x1080 Bit Rate: 9000 Size: 232mb Speed: 3:19 Codec: MPEG(xvid) HD Resolution: 1920x1080 Bit Rate: 12000 Size: 307mb Speed: 8:40 Codec: h264 Resolution: 1920x1080 Bit Rate: 9000 Size: 232mb Speed: 3:20 Codec: MPEG(xvid) Resolution: 1920x1080 Bit Rate: 12000 Size: 307mb Speed: 8:47 As you can see the file sizes and speeds were almost identical between Aunsoft and Pavtube. Except of course for the first one where I forgot to turn CUDA acceleration on for the ripping. Quality Now here is where it got difficult. I know right off the bat people would ask me why I even tried the xvid codecs and instead just accepted that h264 would be the better codec. But I actually found the quality of the xvid looked better than the h264. After watching these clips over and over again both on the Xoom and hooked up to my HD TV, I settled on either the h264 with the HD standard and the xvid with the base line standards. Don't ask me why these two because I couldn't tell ya. I like to think I have a pretty good eye for video quality, I currently sell HD TVs and can see the difference between 100k contrast and 120k contrast if that gives me any sort of justificaton. I eventually agreed (with my girlfriend who was helping me judge) that the MPEG 4 with the xvid codec ripped by Pavtube was the best quality of the bunch. The colors were much more vibrant on my 42 inch plasma while the edges of moving objects were not blurred at all. Results What was important to me: Quality of the Video Compatibility with the Xoom Usability of the program What was not important to me: Time to rip (I'm happy doing one movie overnight every night if need be) Size - to an extent (quality is more important) After reviewing every aspect of these programs that was important to me I can honestly say that Pavtube gave the best quality and also the best user experience. The reason it beat out Aunsoft is the fact that Aunsoft would convert some of my videos (the ones with the HD standards) to a 4:3 aspect ratio and also four tests made by Aunsoft failed to load on the Xoom while only one Pavtube test failed to load. So I will now begin ripping my entire blu-ray collection into MPEG 4 formats at 12000 bit rate. But note at these settings your probably looking at 10GBs per movie so these settings are for people who share what is and isn't important for me. Even if this is not what your looking for I would still recommend Pavtube as the ripper of choice but instead of the xvid codec at 12000 bit rate I would go with the h264 codec at 9000 bit rate because you won't sacrifice clarity, just color. Tips If you are looking to test video quality for yourself look for a chapter when under Title Mode (on the Pavtube UI) that is rather short but has a good display of colorful moving objects and rip that chapter into different formats and settings. When ripping the full movie switch the UI to File Mode and rip only the main file. The reason I recommend switching to File Mode is because if you rip both the title and all the chapters under Title Mode it will actually rip the movie twice. If you read my previous edits you will have seen how this doubled my file size. Manually set the frame rate to what your looking for, I recommend matching the source. But do not use original frame rate when ripping the full movie, for me it got it wrong and played my movie in what appeared to be fast forward. Epilogue I need to note that I'm in no way affiliated with any of the above programs and did this testing because I couldn't find any reviews that were not sponsored by the programs themselves. I'm entirely new to compression and ripping so this was a learning experience for me and hope that my terminology and assumptions of how the process works is accurate. As a CS major I'm looking to get familiar with technical writing and I hope this review was readable, informative, and to the point. Everything above is simply my opinions based on the time I spent with these programs
May 21, 2011 | Computers & Internet
Top-notch Aunsoft Software-Put and Play WMV Video on White iPhone 4 The White iPhone 4 hasn't been released yet. Apple states on its website that white models of Apple?s new iPhone 4 have proven more challenging to manufacture than expected, and as a result they will not be available until the second half of July. The availability of the more popular iPhone 4 black models is not affected. Don?t worry, people who loves white iPhone 4 just wait in patient till July 30th, the date that white Apple iPhone 4 probably released. Windows Media Video (WMV) is a compressed video compression format for several proprietary codecs developed by Microsoft. The original video format, known as WMV, was originally designed for Internet streaming applications.Now Windows Media Video (WMV) is the most recognized video format within the WMV family. Usage of the term WMV often refers to the Microsoft Windows Media Video codec only. Its main competitors are MPEG-4 AVC, AVS, RealVideo, DivX, and Xvid. (Microsoft claims that WMV 9 provides a compression ratio that is two times better than MPEG-4, and three times better than MPEG-2.) How to Put and Play Windows Media Videos to White iPhone 4? This guide will show you how to play Windows Media Videos (WMV) on White iPhone 4 with iPhone 4 Video Converter, which has renowned for its stable performance, excellent A/V sync, high video quality of iPhone 4 output videos as well as its advanced feature of joining/merging multiple WMV files into one iPhone 4 (*.mp4) video. 1. Download the iPhone 4 Video Converter for free and then install, start up it. (This free trial version will output video with Aunsoft watermark, if you don?t like it, please purchase the full version.) 2. Import Windows Media Videos (WMV) to the program. You can add more than one file and could also check ?Merge into one file to get a large one file. 3. Please select suitable format like iPhone 4 MPEG-4 640*480 (*.mp4) or iPhone 4 H.264 720P (*.mp4) for your iPhone 4 as the output format for conversion. Then click Convert to start the conversion of Windows Media Videos (WMV) to white iPhone 4 MP4 files. With this iPhone 4 Video Converter, you needn?t worry about how to play Windows Media Video (WMV) files on your white iPhone 4 now. And you can also trim, crop your Windows Media Videos (WMV) and set Brightness, Contrast and Saturation of the videos. Do you want to convert and play WMV files on white iPhone 4? Just do it now.
Jul 29, 2010 | Cameras
Aunsoft AVI to iPhone 4 Converter-How to Convert AVI to iPhone 4 HD videos Convert AVI to iPhone 4 HD & SD Videos Aunsoft updated with its full support to iPhone 4 SD and HD outputs. With plenty of compliments received from our customers, Aunsoft iPhone 4 Video Converter has renowned for its stable performance, high video quality of iPhone 4 720p MP4 output videos as well as its advanced feature of joining/merging multiple AVI files into one video. Source Video: AVI AVI (Audio Video Interleaved), developped and defined by Microsoft as the response to Apple's QuickTime, is the most common format for audio/video data on the computer. An AVI file can use different codecs and formats so there is no set format for an AVI file. DivX and XviD codes enable AVI files to have similar or even better quality than DVD. Convert to: iPhone 4 HD Videos iPhone's beautiful 3.5-inch widescreen display with 320x480 resolution is the ultimate way to watch movies, video clips, TV shows and play music, audiobooks. Just transfer the media from iTunes software on your PC or Mac to the iPhone, an excellent pocketable media player. File formats supported: iPhone MP4 (H.264, MPEG-4) video and MP3/AAC audio. How to Convert AVI to iPhone 4 HD videos 1. Click ?Add? button to browse source AVI file(s) to the program. Or simply drag and drop files into the app. 2.Choose output format for iPhone 4 720p output. Follow ?Format?> ?iPhone?> ?iphone H.264 720p(*.mp4)? to convert AVI files into iPhone 4 HD files. Or check out ?iPhone 4 MPEG-4 640*480(.mp4)? for SD output for iPhone 4. 3. Join AVI files(optional) and convert. Before you start AVI to iPhone 4 Converter HD conversion, you can tick the checkbox of ?Merge into one file? to join/combine all AVI files into one HD MP4 video for iPhone 4. Then click ?Convert? to start conversion.
Jul 28, 2010 | Cameras
106 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
