Tip & How-To about Computers & Internet
DONT HIBERNATE !!!!!!
Don't hibernate because actually when it is done the whole ram is loaded in your hard disk and it affects the performance of your computer......
so dont hibernate very often
Computers & Internet Logo
slow opening of websites
How to Make Windows XP Startup Faster
Steps
1.Click on Start, then Run, and type "msconfig". Wait for a new window to pop up.
2.Look under the "BOOT.INI" tab. You will see a box labeled "Timeout:", and a numerical value. By default, it's 30, which means 30 seconds of wait time before boot. This can be changed, using 3 seconds. (Note: if you have more than one operating system, this means the wait time to startup to the highlighted OS. you might want a bit more than 3 seconds)
3.Delete the temporary files periodically from your computer to make the applications run faster. Type %Temp% in the run dialog box by clicking on Start -> Run, and click on "OK". You will see an open folder with many files. Click on the Edit menu and click on Select all and then click on the File menu and select Delete. Note: Always confirm that the folder which is opened has a temp on the top of menu bar and the folder indicates that it is a temporary folder.
4.Perform a scandisk to see that your computer hard drive is in healthy condition and it helps your computer run faster.
5.Always perform a disk defragmentation at least once in a month. start the disk defragmentation from the system tools available in the accessories from the start menu. it takes a longer time and it is advised not to run any applications in the computer including the screen savers, while running disk defragmentation.
Hibernation
After you have done all this, another method you can do is to allow the computer to hibernate. Hibernation closes and opens Windows faster than normally. However, Hibernation is a good long-term solution, as it does not waste electricity.
1.Go to Start->Control Panel->Power Options. Click on the Hibernate tab.
2.Click on the box that says "Enable hibernation" to check it.
3.Click on the Advanced tab and change the Power buttons options if you want to hibernate by pressing the sleep button or the power button. Otherwise, holding the Shift key while in the Turn Off Computer menu will give you the option to hibernate.
4.Restart your computer every week or so to clear your computer.
The power can then be completely turned off, even at the socket so that no power is wasted.
Prefetch
1.Simply browse to the windows folder (Ex: C:Windows) and under there you should see the prefetch folder. Go into the prefetch folder and delete all the files (Careful! It should look like this c:windowsprefetch). We need to edit a registry key to tweak it. Open regedit and browse to this key:
HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControlSession ManagerMemory ManagementPrefetchParameters
Under this key you should see a value named: EnablePrefetcher
It has 4 possible values:
0- Disabled : The prefetch system is turned off.
1- Application : The prefetch only caches applications.
2- Boot : The prefetch only caches boot system files.
3- All : The prefetch caches boot, and application files.
We don't want to disable it entirely. This would actually make boot times *longer*. This is because this feature is also used to speed up the loading of boot files. That is why we are going to pick the number 2 option. It allows us to keep the advantage of caching system files, without continually clogging the system up with applications.
Set the value to 2 and reboot.
The 2nd time you boot it should boot much faster. Remember that the side effect is that launching individual applications once windows has loaded will now be slightly slower.
Tips
When installing new software choose not to add the program to the startup folder.
. Regularly check to see what programs are running from your startup folder as malicious programs such as spyware may have installed itself without your knowledge.
. If you accidentally uncheck a program, just retrace the steps above and recheck the program and restart your computer.
. Adding more RAM to a Windows XP computer helps it boot faster, and since RAM prices are very low these days, it's an easy way to boot faster.
. uncheck system startup unnecessary startup programs*
Warnings
. Save any open work before making changes.
. Shut down all applications before making changes.
. Don't uncheck anything from Symantec or any other anti-virus or anti-malware software. Doing so may disable or hinder the protection of your PC.Remove all toolbar from add or remove program. From control panel. Reset web settings from internet option.
Apr 14, 2012 | Microsoft Windows XP Home Edition English...
my laptop is running slow
Steps
Hibernation
Prefetch
Tips
Warnings
Apr 05, 2012 | Lenovo Computers & Internet
How do you clean a laptop ram?
Hi there loverboyjero! :) here are the steps on how to clean a laptop ram :)
1.Log onto your laptop and click "Start." Go to the "Control Panel." Choose "Performance Information and Tools." The window lists data information such as calculations per second and memory operations per second. On the left is a list of tools for disk cleanup. The tools in this window can also be accessed in the "System Tools" folder inside "Accessories," which is also located at the "Start" menu.
2.Click on "Advanced tools." Choose "Open Disk Defragmenter." The window will list the last time the laptop was defragmented. If the "Last run" was over a month ago, click "Defragment now." Defragmenting your hard drive will rearrange files so that the laptop can better access them. Defragmenting may take an hour or longer, depending on the last time it was done.
3.Click back to return to "Performance Information and Tools." Click "Open Disk Cleanup." The window will prompt you to select a drive to cleanup. Select "C:" and if you have more than one hard drive, an external or a partitioned hard drive, do a disk cleanup of these drives as well. Wait for Disk Cleanup to calculate how much space you will be able to free up. This may take a few minutes to complete.
4.Select the items that you want to delete. These files will be permanently deleted. Delete "Temporary Internet Files," "Downloaded Program Files," and the "Recycle Bin." You may have an option that says "Hibernation File Cleaner." Removing this file will disable hibernation on your laptop. Do not remove this file if you use hibernation. Click "OK," then "Delete Files.
Sep 30, 2011 | Computers & Internet
RAM of 512 MB
look speed depends more on condition and cache of hard disk and size, and how much it is loaded with data and how fragmented are ur files ,
Ram does make a difference but only when booting OS and Loading different programs opening them after windows boot as ms word or other office application u will find smooth running of apps no waiting time and hangups in performance if u are enuff with ram like if u use XP 1 Gb is more than enuff but Vista needs 2 GB to work smoothly
but i will again say tell em ur problems in detail i mean where u are getting slow performance i can solve it for u anmd suggest later after diagnosis what is best for ur system i have experience in this
Pls rate me Fixya fo rhelp ! or ask for more help !
Apr 15, 2009 | Lenovo 3000 N100 0768 - Pentium Dual Core...
145 people viewed this tip
David Payne
David Payne
