Tip & How-To about Audio Players & Recorders
What To Do If Your iPhone Or iTouch Won't Turn On
Try to reboot the iPod, just in case it has crashed
  1. Hold the top button and the home button for about ten seconds.
  2. A bug can stop the screen from displaying, sometimes you can reverse the problem by doing the reboot. If you still see nothing on the screen, try to plug the iPhone in to the computer and try the reboot method again.
If you are still unsuccessful in turning on the iPod, but the iPod shows up in iTunes, try restoring from iTunes to fix any bugs causing the issue
  1. Plug the iPod in to your PC, go into iTunes and click the iPod's icon on the left side of the screen.
  2. In the iPod Summary Screen, click on the restore button and agree to the prompt asking if you really want to restore the iPhone's software.
If you are still unsuccessful in turning on the iPod, but the iPod doesn't show up in iTunes, try putting the iPod into recovery mode
  1. You can put the iPod into recovery mode if it has a charged battery.
  2. Start by holding down the home button before connecting it to iTunes, then continue to hold the button until iTunes recognizes that the iPod's in recovery mode.
  3. Recovery mode allows you to perform a restore when you're when an iPod fails to turn on or display anything on the screen.
2nd gen ipod shuffle non-responsive
Step 1:
Like all electronic devices, iPods sometimes freeze and become unresponsive. Sometimes iPods lock up when they're dropped on the ground or come in contact with water, but less destructive accidents may also cause them to stop working. All versions of the iPod have a way to reset their hardware should they stop playing music or refuse to turn off.
Check the "Hold" switch on the top case of your iPod to be sure it isn't activated. An iPod will appear frozen and unresponsive if this feature is activated. A lock symbol will appear on your iPod's screen if it is in Hold mode. Switch the "Hold" button on and off once. Place one finger on the "Menu" button and another on the center button. Press both buttons at the same time and hold them for up to 8 seconds. Release the "Menu" and center buttons once the Apple logo appears on your iPod's screen. Try releasing the buttons and pressing and holding them a second time if the logo does not appear, as it can sometimes take several tries to reset a severely frozen iPod. Press and hold the top button and the center "Home" button on a frozen and unresponsive iPod touch to reset it. Hold the buttons for at least 10 seconds and wait for the Apple logo to appear on the screen, then release the buttons. Connect your iPod to its powerblock or a computer if it is still frozen. Wait 5 minutes and then try to reset it. Sometimes an iPod can appear frozen when its battery runs out and just needs a few minutes of power to start working again.
Feb 19, 2013 | Apple iPod shuffle Second Gen. Silver (1...
my ipod touch is stuck on a screen that says "ipod is disabled, try again in 5,785,421 mintues"
Connect your iPod Touch to your computer. Turn your iPod Touch off (hold down the top button and slide the red off slider). Then hold down the top button and the home button for ten seconds then let go of the top button while still holding the home button and KEEP holding it for up to 30 seconds. If it doesn't work the first time, try it again - iTunes should pop up and say that it sees an iPod Touch in restore mode. Click restore and you'll be able to get it back up...
May 04, 2011 | Apple iPod touch
My iphone is not turning on. It is jail broken the problem is whenever the iphone goes off i have to jailbreak it each time. Now also i have dome the samething but its not working. Its not turning on.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jun 30, 2010 | Apple iPhone Smartphone
iTouch crashed and wont restart
try this
  1. Press and hold the Home button while reconnecting the USB cable to iPod. When you reconnect the USB to iPod, the device should then power on.
  2. Continue holding the Home button while iPod starts up. While starting up, you will see the Apple logo.
  3. When you see "Connect to iTunes" on the screen, you can release the Home button and iTunes will display the recovery mode message:
  4. Restore and it'll download ~240mb firmware and you're done
If step 1 shows no reaction on your screen,the screen may have got damaged.
Sep 02, 2009 | Apple iPod touch
814 people viewed this tip
 Grubhead
Grubhead
