Tip & How-To about Refrigerators
Refrigerator not cold enough?
  • Always keep the condenser coils on bottom of unit clean.
  • Keep food away from airflow vents getting air from from freezer section.
Refrigerators Logo
freezer working, refrigerator not
Hello Georgia Peterson - Do you hear anything running in the machine compartment and what type of airflow is the condenser fan providing (try removing the toe grille, located above the drain pain on the bottom right-hand side)? If you do not hear the compressor and unit is providing room temperature, it usually means that the unit has a faulty compressor or a sealed system leak. Also there is a vent towards the back of the freezer that circulates air from the freezer section to the fresh food section. If this vent is blocked by too many items in the freezer it will cause the unit to work harder making it colder in the freezer and keeps the air from flowing down to the refrigerated section. If you would, make sure that the vent is not blocked so that air can travel from the vent down to the refrigerated part. This will decrease the temperature in the freezer, allowing for ice cream to be pliable and the fresh food section to become colder. Should you find these suggestions unsuccessful I would recommend contacting a professional to move forward accurately.
Jan 13, 2013 | Frigidaire FRT21H8 Top Freezer...
what would cause my frigidaire refrigerator to not get cool p/n 240508000
Hello - If I may suggest, as it is a Top Mount; there is a vent towards the back of the freezer that circulates air from the freezer section to the fresh food section. If this vent is blocked by too many items in the freezer it will cause the unit to work harder making it colder in the freezer and keeps the air from flowing down to the refrigerated section. If you would, make sure that the vent is not blocked so that air can travel from the vent down to the refrigerated part. This will decrease the temperature in the freezer, allowing for ice cream to be pliable and the fresh food section to become colder. Do you hear anything running in the machine compartment and what type of airflow is the condenser fan providing (try removing the toe grille, located above the drain pain on the bottom right-hand side)? If you do not hear the compressor and unit is providing room temperature, it usually means the unit may have a faulty compressor or a sealed system leak. Should you find these suggestions unsuccessful I would recommend contacting a professional to move forward accurately.
Nov 04, 2012 | Refrigerators
Bottom not cool at all
Greetings,
The first thing to check is are all the fans running? there is one in the freezer and usually one in the rear compressor compartment...the next thing to check if fans are operating is: remove rear freezer panel and see if ice or frost is blocking the air thru the freezer coil...if there is ice blocking the airflow. defrost the coil using a hair dryer.. the fresh food section gets cold air from the freezer..its blown over into top of refrigeration via a fan...it goes thru a baffle into refrigerator...this baffle sometimes will not open...This is one place you check for air coming into refrigerator...so, check here also before you take it apart. there should be a noticable amount of airflow....if not, remove the cover and work a small wooden dowel or skewer into the slot and open the vent..this will allow air to go into refrig section...the skewer can be left in there to keep it working if this is it...getting back to a frosted evap...if it is froze up..there is a derfost problem and defrosting will give you temp service until you can get it repaired......Bruce Denton
Jan 09, 2011 | Whirlpool ED2SHAXM Side by Side...
Refrigerator is not cold (50);freezer is working; vents not blocked. What can I do? Fan is working, & compressor does kick on.
Nine out of ten times it turns out to be a defrost issue. What most people dont understand is the refrigerator gets its cool air from the freezer. If the evaporator coil in the freezer becomes a block of ice then the airflow from freezer to fridge section is blocked. The block of ice along with already frozen foods in the freezer compartment help to keep those foods frozen. Therefore you assume the freezer section is fine. However, the lack of cool airflow to the fridge side quickly turns that 38 degree air into 50 degree air. You could try unplugging the fridge and leaving doors open for 24 hours, this will thatw the evap coil. Plug it back in after the 24 hours, and within 12-24 hrs everything should be cool. If the fridge continutes to cool for about 3-6 days and then fails again, you certainly have a defrost problem. This is long winded, but hope it helps
Mar 01, 2010 | Refrigerators
fridge won't cool?
I had to finally call for service. He cleaned the coils which were plugged with dust and cat hair. It didn't fix the problem completely so I called them back out. This time I was told I had the opening in the back of the refrigerator blocked by tall bottles. That was what controlled the amount of airflow from the freezer section to the fridge part. You're not supposed to keep anything directly under it. The higher you set the fridge, the more the vent opens to allow the flow of cold air in. I also moved the food in my freezer away from the air openings. Nobody had ever mentioned this to me before. The combination of the two (Vacuuming coils and Freeing up the airflow) actually worked.
Jun 02, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
268 people viewed this tip
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
