Tip & How-To about Panasonic 900 MHz Cordless Phone
How to fix problem with screen clicking on BlackBerry Storm
If you're having problems with clicking, like the edges are hard to click, or the screen in general is hard to click, the following is how to remedy it.
Tools:
  • Torx T6 screw driver
  • Small needle
Steps to follow:
  • Take off back cover
  • Locate red sticker (water detection sticker)
  • There is a t6 screw under the sticker and directly across from it
  • The problem is that sometimes these screws are too tight
  • Start by loosening the exposed screw a tiny bit, then check the clicking on the screen - if this doesn't work, loosen a little more. If the clicking still doesn't work correctly, move on to next step
  • Remove the sticker with the small needle (this will not void your warranty) - loosen the screw as you did with the first screw -
  • Check the clicking to see if it works better - if not loosen screws more
  • Replace the sticker
  • Replace back cover
Your screen should now be clicking better. Thanks
Panasonic 900 MHz Cordless Phone Logo
How to defrag my laptop?
I would download Advanced System Care from iobit.com. It is a free programme and works.
Oct 15, 2014 | Dell Inspiron Computers & Internet
how to safemood in asus x200m
Normally on start up screen bottom left should say press f2 for bios you should press f8
Jul 22, 2014 | ASUS NB X200MA-QSP2T-CB 11.6 Pentium N3520...
does my floor have to be level to put in tranquility click flooring over it?
Wood flooring manufactures state the floor must be level within 3/16" every 10 feet. That means if you have a straight edge at least 6 - 8 ft long and you lay the skinny edge on the floor and look for light under the edge that contacts the floor...or gaps, must not be greater than 3/16" if they are, a simple floor patch from Home Depot or Lowes that you trowel on will remedy those voids. You need to check for high spots as well by placing the straight edge on the floor and looking for a distinct rocking of the SE from the high side to the low side.
All this pertains to my experience with concrete slabs. If you have a wood subfloor let me know
May 02, 2014 | Tranquility 5mm Venetian Cream Click...
blackberry 8220 hard reset code
To perform a hard reset ON your blackberry 8220, follow the steps below:
On the Home screen, click the Options icon.
Click Security Options.
Click General Settings.
Press the Menu key.
Click Wipe Handheld.
Regards
Jun 29, 2011 | RIM BlackBerry Pearl Flip 8220 Cellular...
My system is workin properly but the screen resolution is very dim it seems to be very light ..... even we can't read any thing on that. i checked my monitor with another cpu its working properly can any say remedy for this problem.
IT IS NOT HARDWARE PROBLEM
Change screen resolution
Screen resolution refers to the clarity of the text and images on your screen. At higher resolutions, items appear sharper. They also appear smaller, so more items fit on the screen. At lower resolutions, fewer items fit on the screen, but they are larger and easier to see. At very low resolutions, however, images might have jagged edges.
For example, 640 × 480 is a lower screen resolution, and 1600 × 1200 is a higher one. CRT monitors generally display a resolution of 800 × 600 or 1024 × 768. LCD monitors can better support the higher resolutions. Whether you can increase your screen resolution depends on the size and capability of your monitor and the type of video card you have.
21b7b862-a70d-43aa-a281-e00c38a8078d.pngText and images are sharper and smaller at high screen resolutions
2aca9658-0ee7-4b8d-a582-cac335550f26.pngText is larger and easier to read at low screen resolutions, but images are blocky and fewer items fit on the screen
  1. Open Display Settings by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking Control Panel, clicking Appearance and Personalization, clicking Personalization, and then clicking Display Settings.
  2. Under Resolution, move the slider to the resolution you want, and then click Apply.
Nov 13, 2010 | Intel D945GCCR Motherboard
1,707 people viewed this tip
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
