Tip & How-To about Cell Phones
How to get the most out of your cellphone battery. It is always a hassle when your cellphone battery is flat and you can't charge it right away. So get the most out of your battery. Before you put your phone on charge, switch it off first. that way it does not used any energy when it's on charge. Also you can charge it during the night when you are sleeping. Most cellphones have the ability to let the alarm go off even though the phone is switched off. So your phone is fully charged at the end of the night. And you can enjoy your day without any worries.
Cell Phones Logo
Hai,im using nokia x3.if im charging it, it doesnot get full and it always saying *BATTRY LOW*.If im using this phone i have to charg it while im using it and this thing is stressing because if im going somewhere else i have to bring a charger so that i can use my phone
HERE'S THE ANSWER TO YOUR PROBLEM:
I believe that the main culprit is your battery itself - its capacity to hold and supply power to your cellphone. These are some of the causes why cellphone battery life are shortened:
1. Bluetooth - it quickly drains battery life
2. Programs running in the background
3. Wi-fi and Data Connections
4. Backlit Screens
Nokia x3 batteries have only 11 hours life when used for calls. So, if in case your battery does not work well, do not think twice to buy a new one. Your battery might have been used up or burn out. Do waste your time bringing charger and charging it always whenever you have calls. Try to think.
I love answering your question. Thanks...
Jul 17, 2011 | Nokia Cell Phones
will not charge when plugged in
What is the unit of your cellphone? It can be the charger but try to use other chargers suited for your handset model.
usually the reason why the cellular phones will not charge up when plugged in is that the terminal in the connector from cellphone - charger is broken.
Let a technician check it and replace when necessary. Otherwise you need to use universal charger which is a bit "hassle" for you.
Have a nice day ahead!
Feb 07, 2011 | Cell Phones
3110c is blinking
Try doing a power cycle by turning it off and then remove the battery. After that just press the power button and hold it for 20 secs. Then put the battery back in and turn it on. Usually this solves the problem right away. If it doesn't, try putting the charger while the unit is off and let it charge for 30 mins. You should be able to at least see it charging on the screen. If you donot see anything on the screen while it's charging, try using a different battery. And then while it's charging, turn it on after 30 mins with the charger still plugged in. You can also try removing the battery while it is blinking.
If the above steps did not work, you would need to have it repaired by a cellphone technician. There's basically no other way to repair it other than opening it. If the unit is still in warranty, save yourself the hassle and just have it repaired by the store where you bought it or thru any authorized service repair depot.
Hope this helps.
Oct 25, 2010 | Nokia Cell Phones
charged battery.showed charged right away.bike wont start unless
Hi and welcome to FixYa,
The description "...series of clicks..." is significant. The battery is not putting out enough current to turn the starter motor. The best way to determine the battery condition is to have it load tested. However, considering eveything else, it would almost always be a failed or about to fail battery.
Incidentally, the alarm has been designed to have minimal current drain when in standby.
Good luck and thank you for asking FixYa.
Jan 06, 2010 | 2006 Suzuki SV 650 S
229 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
