Tip & How-To about Computers & Internet
How to fix "Operating System Not Found" error when you start your Windows XP-based computer
When you try to start a Windows XP-Based computer, you may receive an error message that the operating system is not found.
APPLIES TO
Microsoft Windows XP Home Edition
Microsoft Windows XP Professional
Symptoms
When you start a Windows XP-Based computer, you may receive one of the following error messages.
Error message 1
Operating system not found.
Error message 2
Missing Operating System
When you start your computer to the Recovery Console to recover functionality, you may receive an error message that resembles the following error message:
Setup did not find any hard drives installed on your computer.
CausesThis issue may occur if one or more of the following conditions are true:
The basic input/output system (BIOS) does not detect the hard disk.
The hard disk is damaged.
Sector 0 of the physical hard disk drive has an incorrect or malformed master boot record (MBR).
Note Some third-party programs or disk corruption can damage an MBR.
An incompatible partition is marked as Active.
A partition that contains the MBR is no longer active.
Resolution To resolve this issue, use one of the following methods, depending on your situation.
Contact your hardware manufacturer
Your best bet may be to contact the manufacturer of your computer or your hard disk. The manufacturer may have a utility that you can use to perform a more detailed scan for damaged areas of the disk and help verify the correct BIOS settings. However, be aware that the damage to your hard disk may be serious. Sometimes this means that your only solution is to replace your hard disk.
If a fix or workaround is not available, you can use the "Advanced Troubleshooting" section to try to resolve this issue.
Advanced troubleshooting
This section is intended for advanced computer users. If you are not comfortable with advanced troubleshooting, you might want to ask someone for help or contact support. For information about how to contact Microsoft support, visit the following Microsoft Web site:
http://support.microsoft.com/contactus/
Method 1: Verify the BIOS settings
Verify the computer's BIOS settings to make sure that BIOS lists and recognizes the hard disk. See the computer documentation or contact the hardware manufacturer for information about how to verify the BIOS settings.
After you verify that the computer's BIOS detects the hard disk, restart the computer, and then test to determine whether the issue is resolved. If the issue is not resolved, or if the computer's BIOS cannot detect the hard disk, you may have issues with your hardware. Contact the hardware manufacturer to inquire about how to resolve this issue. You may have to replace the hard disk.
For information about how to contact hardware manufacturers, click the appropriate article number in the following list to view the article in the Microsoft Knowledge Base:
65416 Hardware and software vendor contact information, A-K
60781 Hardware and software vendor contact information, L-P
60782
Hardware and software vendor contact information, Q-Z
Method 2: Use Recovery Console
Use the fixmbr command in the Windows XP Recovery Console to repair the MBR of the startup partition.
Warning This command can damage your partition table if a virus is present or if a hardware problem exists. If you use this command, you may create inaccessible partitions. We recommend that you run antivirus software before you use this command. We also recommend that you backup your data before you use this command. If the fixmbr command detects an invalid or non-standard partition table signature, the fixmbr command prompts you for permission before rewriting the MBR. The fixmbr command is supported only on x86-based computers.
For more information about Recovery Console, click the following article numbers to view the articles in the Microsoft Knowledge Base:
314058 Description of the Windows XP Recovery Console 307654 How to install and use the Recovery Console in Windows XP
Computers & Internet Logo
error on windows xp desktop page_fault_in_nonpage_area
You receive "Stop error code 0x00000050 (PAGE_FAULT_IN_NONPAGED_AREA)" or "Stop error code 0x0000008E (KERNEL_MODE_EXCEPTION_NOT_HANDLED)" when you restart a Windows XP-based computer uparrow.gifBack to the top ' Give Feedback 20x20_grey_minus.png954211 MS08-061: Vulnerabilities in Windows kernel could allow elevation of privilege
  • 959252 Error message when you switch the operating system from a dual monitor setting to a single monitor setting on a Windows XP-based computer or on a Windows Server 2003-based computer that has the security update 954211 installed: "Stop 0x0000008E"
  • Note Update 959252 addresses a known issue that was introduced by update 954211.uparrow.gifBack to the top ' Give Feedback 20x20_grey_minus.pnguparrow.gifBack to the top ' Give Feedback 20x20_grey_minus.png824684 Description of the standard terminology that is used to describe Microsoft software updates
    Jan 06, 2014 | HP Computers & Internet
    error 0xc0150002
    Hi There,
    When you start an Office 2003 program on a Microsoft Windows XP Professional-based computer, you may receive the following error message:
    "The application failed to initialize properly (0xc0150002). Click on OK to terminate the application."
    To resolve this issue :
    • You upgrade your Windows XP Service Pack 1a (SP1a) Home-based computer to Windows XP Professional.
    • You reinstall Windows XP on your computer.
    • You perform a repair of Windows XP on your computer.
    These steps would resolve this issue.
    Oct 22, 2010 | Computers & Internet
    Generic Host Process for Win32 Services has encountered a problem
    1. Uninstall KB873333 microsoft update (Control panel> AddRemove program> check show hidden microsoft updates then uninstall it)
    2. Scan the computer with free SuperAntiSpyware. download from http://www.superantispyware.com/download.html
    3. To resolve this problem, follow these steps:
    1. Turn off the computer and the printer or the scanner.
    2. Disconnect the printer or the scanner from the computer.
    3. Restart the computer.
    4. Install the compatible drivers and software for the printer or the scanner, and then reconnect the printer or the scanner to the computer.
    4.
    931852 (http://support.microsoft.com/kb/931852/ ) Error messages when you start a Windows XP-based computer and then try to download Windows Updates 894391 (http://support.microsoft.com/kb/894391/ ) You receive a "Generic Host Process" error message after you start the computer, or DBCS attachment file names are not displayed in Rich Text e-mail messages 819017 (http://support.microsoft.com/kb/819017/ ) Long delay before files appear in My Computer in Windows XP
    Nov 23, 2008 | Microsoft Windows XP Home Edition
    generic host process for win32 services encountered
    1. Uninstall KB873333 microsoft update (Control panel> Add\Remove program> check show hidden microsoft updates then uninstall it)
    4.
    generic host process win32 services
    4.
    Nov 23, 2008 | Microsoft Windows XP Professional With...
    309 people viewed this tip
    David Payne
    David Payne
