Tip & How-To about Computers & Internet
Fix Windows 7 Error ?Windows is Not Genuine? Error code 0×80070005
Those users running genuine version of Windows 7 provided with their hardware platform reported that immediately after log on they were presented with following error message. “Windows is not genuine. Your computer might not be running a counterfeit copy of Windows. 0×80070005.”
Some other symptoms of associated with this issue are,
The computer desktop background is black, and you receive the following error message on the bottom right corner of the screen:
“This copy of Windows is not genuine”
You receive the following error message when you view the System Properties: (Control Panel / System and Security / System)
“You must activate today. Activate Windows now”
If you try to use slmgr.vbs /dlv to view the licensing status, you receive the following message:
Error: 0×80070005 Access denied: the requested action requires elevated privileges
Microsoft is fully aware of this issue and provided following explanation for the issue,
There is a lack of permissions in the registry key HKU\S-1-5-20. The Network Service account must have full control and read permissions over that registry key.
This situation may be the result of applying a Plug and Play Group Policy object (GPO).
To resolve this issue, you can either disable the policy setting (Method A), or edit the permissions to provide the Licensing Service the required permissions (Method B).
Method A: Disable the Plug and Play Policy
1. Determine the source of the policy . To do this, follow these steps:
a. On the client experiencing the Activation error, run the Resultant Set of Policy wizard by clicking Start, Run and entering rsop.msc as the command.
b. Visit the following location:
Computer Configuration / Policies / Windows Settings /Security Settings / System Services /
If the Plug and Play service is configured through a Group Policy setting, you see it here with settings other than Not Defined. Additionally, you can see which Group Policy is applying this setting.
2. Disable the Group Policy settings and force the Group Policy to be reapplied.
a. Edit the Group Policy that is identified in Step 1 and change the setting to “Not Defined.” Or, follow the section below to add the required permissions for the Network Service account.
b. Force the Group Policy setting to reapply: gpupdate /force (a restart of the client is sometimes required)
Method B: Edit the permissions of the Group Policy:
1. Open the Group Policy that is identified in Method A, Step 1 above, and open the corresponding Group Policy setting.
2. Click the Edit Security button, and then click the Advanced button.
3. In the Advanced Security Settings for Plug and Play window click Add and then add the SERVICE account. Then, click OK
4. Select the following permissions in the Allow section and then click OK:
Query template, Query status, Enumerate dependents, Interrogate, User-defined control, Read permissions
Note: The Previous rights are the minimum required permissions.
5. Run gpupdate /force after you apply the previous permissions to the Group Policy setting.
6. Verify that the appropriate permissions are applied with the following command:
sc sdshow plugplay
The following are the rights applied to the Plug and Play service in SDDL:
D:(A;;CCDCLCSWRPWPDTLOCRSDRCWDWO;;;SY)
(A;;CCDCLCSWRPWPDTLOCRSDRCWDWO;;;BA)
(A;;CCLCSWLOCRRC;;;IU)
(A;;CCLCSWLOCRRC;;;SU)
S:(AU;FA;CCDCLCSWRPWPDTLOCRSDRCWDWO;;;WD)
(A;;CC LC SW LO CR RC ;;;SU is an Access Control Entry (ACE) that allows the following rights to “SU” (SDDL_SERVICE – Service logon user)
A: Access Allowed
CC: Create Child
LC: List Children
SW: Self Write
LO: List Object
CR: Control Access
RC: Read Control
SU: Service Logon User
Note: If there are no GPO’s in place, then another activity may have changed the default registry permissions. To work around this issue, perform the following steps:
1. On the computer that is out of tolerance, start Registry Editor.
2. Right-click the registry key HKEY_USERS\S-1-5-20, and select Permissions…
3. If the NETWORK SERVICE is not present, click Add…
4. In Enter the object names to select type Network Service and then click Check Names and OK.
5. Select the NETWORK SERVICE and Grant Full Control and Read permissions.
6. Restart the computer.
7. After the restart, the system may require activation. Complete the activation.
Computers & Internet Logo
system requirement to run crystal report v9 professional
System Requirements
  • PC with AMD or Intel based processors, Dual Core CPU, 2 GB RAM.
  • 3.5GB available hard drive space (for English only, 7.5 GB for all languages)
  • DVD drive (for DVD install only)
  • Microsoft Windows 7 SP1, Windows 8, Windows Server 2008 SP2, Windows Server 2008 R2 SP1, Windows Server 2012
  • Languages: Chinese simplified, Chinese traditional, Czech, Danish, Dutch, English, Finnish, French, German, Hungarian, Italian, Japanese, Korean, Norwegian, Polish, Portuguese, Romanian, Russian, Slovakian, Slovenian, Spanish, Swedish, Thai, Turkish
Technical Specs
  • Hardware Requirements: Intel Pentium III or equivalent processor, 256 MB RAM, 512 MB Recommended
  • Disk Space: 2 GB for default installation with English language, 4 GB for default installation with all languages installed
Dec 23, 2013 | Crystal Decisions Crystal Reports V9...
Administrator password to login not working
Microsoft's latest operating system, Windows 7, and its predecessor, Vista, offer a new layer of security that is different from previous releases, such as XP or 2000.
The earlier Windows versions treated all users as system administrators by default. With Windows Vista and 7, all accounts are treated as limited users.
The User Account Control utility provides elevated permissions when required and prompts users for those permissions.
You can control UAC behavior in Windows 7 so it does not prompt you for these permissions.
Start your computer with Windows 7 and log in as you normally would. Your desktop should appear, and any background applications should be closed.
Click the Windows "Start" orb at the lower left corner of your screen.
Click your account picture at the top right of the menu.
You will be presented with a window that allows you to make changes to your user account.
Click the link that says "Change User Account Control Settings."
Look for the User Account Control options slider.
The default option of User Account Control is to notify you only when programs try to make changes to your computer or you install new programs.
The option directly below that does the same thing but does not dim your desktop.
The "Never Notify" option at the bottom of the list eliminates the prompts for permissions.
Move the slider to the bottom of the options window.
Click "OK."
You may be prompted one last time from User Account Control to confirm your settings and reboot your computer.
or
Log in as an Administrator on Windows 7
If you've recently upgraded from Windows XP to Windows 7, you're probably wondering how to log in as an administrator. In Windows XP, the administrator account was clearly visible from the log-on page, but it's no longer there in Windows 7.
Although there is an administrator account, it must first be enabled with the Windows command prompt before you're able to use it. Enabling the administrator account lets you troubleshoot problems with programs on your computer.
Click on the "Start" button, and then type "command" into the search bar.
Right-click "Command Prompt" when the results appear.
Click "Run as Administrator."
The command prompt opens.
Type "net user administrator /active:yes," excluding the quotation marks.
Hit "Enter."
Click "Start," and then click "Switch User." Click the "Administrator" icon to log in.
Aug 04, 2013 | Computers & Internet
Windows Genuine Advantage Notifications Options Display Windows Genuine Advantage Notifications messages how to get this off my computer
either you have to install an original copy of windows or you can activate it by installing a software too.i can provide you the software but before that i want to say you that i cant upload it here because here is no way to upload.you can better give me your email address. my email address is mosiurrehman9@hotmail.com .also write in the email about which version of windows 7 you are using.email me as immediately as possible because i wont be online for the next one month from monday onwards.
Apr 07, 2012 | Microsoft Get Genuine Kit for Windows XP...
need product key for windows 7 ultimate
You can run your windows 7 with Administrator log in, where you can get your data and also can remove the password for your user a/c.
Jan 08, 2012 | Microsoft Computers & Internet
I am running Windows XP as a virtual PC under windows 7. I find that Mathcad 11 will not install. It will install directly under windows 7 but will not run. Mathcad 11 did run just fine under XP but apparently will not even install under the virtual XP set up. What can I do?
The software don,t support Win 7.See this chart form portal:
Platform Support Platform Version Supported CPU ODBC Driver Support
Windows XP Professional x64 Edition
Base OS
Intel Pentium/Xeon family with EM64T
AMD64 family
32-bit
Windows XP Professional Edition
Service Release 2
Intel Celeron family
AMD Opteron family
Windows XP Home Edition
Windows 2000
Service Pack 4
Dec 20, 2010 | Mathsoft Mathcad 11 Full Version for PC
487 people viewed this tip
David Payne
David Payne
