Tip & How-To about Computers & Internet
How to test performance of Flash Drive
Check Flashis a freebie program that helps user to test and format flash drives with the utmost ease. It is designed for maintenance operations as well. The interface is a simple with a single window available, which provides all the test-related settings while presenting the drive map, log and verification progress. The application is capable of running both read and write tests in order to determine the speed performance of the device and its health.
cheeckflash
Check Flash presents the settings in the right part of the screen in four different sections covering Access type, Action type, Test length and Test results. Of course, there is a section that lets you choose the flash drive to be evaluated and which features a refresh button, thus allowing adding multiple removable drives without having to restart the program.
The way the read/write tests are performed and the list of options available for the operation are set according to the way you provide access to the flash drive. You can choose between using a temporary file, access it as a logical drive or as physical device. The differences between these three types of drive access consist in the safety level of the procedure and the number of options enabled.
Using a temporary file for the test gives you a minimum of features but, on the other hand, it is totally safe for the evaluated device. Treating the flash as a logical drive will give Flash Check access on partition level and is the second safest alternative to use; plus more options will become available under the “Action type” section.
The most unsafe method to test the removable storage device is to treat it as a physical device during the evaluation. This method is not recommended as it is unsafe for all the partitions present on the selected device but, on the other hand, you benefit from the full set of features in the software.
In “Action type” you get to choose between six procedures to test the removable device, all of which being available depending on the access type specified. The list of options includes read stability test (reads all data a few times and verifies the CRC given on first pass), low-level initialization (available only if you treat the flash as a physical device), which lets you edit the partition information of the selected device, save image (saves full binary image of the chosen partition or device), load image (writes a previously saved binary image) and full erase (effaces all of the drive’s surface).
For 50% of the presented actions several tests can be performed, continuously or until you decide to stop the assessment. All options in the “Test length” section are pretty clear, but “Burn it!” is the one that is not self-explanatory. It actually sets a loop in the testing that requires your intervention to stop.
In the lower part of the screen the test results are displayed: number of completed cycles, error found, read and write speed. Also, there is a progress bar to give you a hint on the completion of the operation. Unfortunately, the application cannot estimate the finish time. Left hand side of the application window shows the drive map, log and legend.
Check Flash 1.08 supplies a fat set of features to test your flash disk and see exactly how fast it can read and write data. It is portable and flexible enough to let you choose from three different drive access methods as well as select between six tests to be performed and how many times to repeat them. It is a very handy instrument that can help you detect the fake flash memory drives.
Computers & Internet Logo
format fat32 64gb
You have to be the computers administrator to change any values on any hard drive on your computer.
Click start control panel user accounts on the users tab click the name of the computer administrator you must have full control
Click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options
select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box
then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
Click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
The Fat32 (FAT) format is used to format disk drives on Windows-based computers and can also be recognized by the Mac's OS X operating system.
You can format a flash drive with the FAT format so that it can be used on both PCs and Macs. The procedure is straightforward, if different depending upon the operating system being used to do the formatting.
You do not need to purchase any additional software to format the Flash drive in the FAT format.
http://www.supermediastore.com/article/u/how-to-format-usb-flash-memory
http://download.cnet.com/hp-usb-disk-storage/3000-2094_4-10974082.html
Format USB flash drives with FAT, FAT32, or NTFS partition types.
Plug the Flash drive into a USB port on the Mac.
Double-click the "Applications" folder inside of the Mac's hard drive. Scroll down to the "Utilities" folder.
Double-click the "Utilities" folder.
Scroll down to the Disk Utility program.
Double-click on the Disk Utility program to launch it.
Click once on the icon of the Flash drive that is in the left column of the Disk Utility program's main screen.
Click on the "Erase" tab at the top of the window of the Disk Utility program's main screen.
Name the Flash drive in the "Name" column at the center of the Disk Utility program's main screen. Select "MSDOS (FAT) from the "Format" menu beneath "Name."
Click the "Erase" button at the lower right corner of the Disk Utility program's main screen.
Click the "Erase" button in the pop-up confirmation window that appears.
Wait as a progress bar at the bottom of the Disk Utility program's main screen fills in from left to right.
Click the "Eject" button at the top of the Disk Utility program's main screen once the progress bar is completely filled in. Quit the Disk Utility program.
Remove the Flash drive from the USB port of the Mac.
Format Flash Drive in FAT on a PC
Plug the Flash drive into a USB port on the PC. Go to "start," "My Computer."
Right-click on the icon of the Flash drive in the center column of the window that appears below "Devices with Removable Storage."
Select "Format" from the pop-up menu.
Select "FAT32" from the "File System" drop-down menu in the window that appears.
Click the "Start" button at the bottom of the window.
Click the "OK" button in the confirmation pop-up window that appears.
Wait as a progress bar fills in from left to right at the bottom of the window where you had selected "Fat32." Click the "OK" button on the "Format Complete" pop-up window when it appears.
Right-click on the icon of the Flash drive that is on the desktop.
Select "Erase" from the pop-up menu.
Remove the Flash drive from the USB port of the PC.
Sep 15, 2013 | Transcend Electronics - Others
how to format Sony 4 GB USB in FAT or NTFS after fail to Format?
You should be able to by going to my computer, then right clicking your USB device and either FORMAT or go to properties and on the tabs select tools and error check. You may have the possibility to Format there as well. If that fails I suggest downloading a separate program in linux, such as Hirens Pack...They have Hard Drive/Memory specific program applications + plenty of DOS applications at your fingertips for just about everything else...just be very careful which ones you choose to mess with. Only for advanced users. Hope this helps
Feb 21, 2013 | Sony Micro Vault Classic 4GB USB 2.0 Flash...
downloading
The Designer 1 needs the design in an shv format in order to read it. The floppy disk for an older machine may be created using several different programs but the Husqvarna Viking module is known as Disk Manager. It is included with many of the HV software packages. With a newer USB Designer 1, the program is Disk Manager USB.
May 09, 2008 | Husqvarna Designer I
98 people viewed this tip
David Payne
David Payne
