Tip & How-To about Computers & Internet
Cold Weather Tips - Ruggedized Laptops
Normally the LAPTOPS have been designed to work within a safe temperature range - normally 50 to 95 degrees F (10 - 35 degrees C). It is necessary to safeguard your laptop from cold weather Protect yourself and your laptop from the damage cold weather can cause.One solution to it is buying Ruggedized LaptopsIf your budget permits, purchase or lease a ruggedized laptop if you will be outside in cold temperatures for extended periods of time. Ruggedized laptops have been designed to work under extreme weather conditions. Most ruggedized laptops come tested according to MIL-STD-810F standards.
Computers & Internet Logo
The cooling fan comes on five minutes after starting
Unless you have the A/C on, that may be normal. The cooling fans only run once the coolant temperature exceeds about 215 degrees. It runs until the temp is down to about 200 degrees. The fans will cycle on and off as necessary to keep the coolant within that range. When the car is in motion, the airflow thru the radiator is normally sufficient to keep the coolant stable and the fans do not run. Only if you turn on the A/C will the fans runs constantly, since the A/C system needs constant airflow thru the evaporator.
Nov 03, 2016 | Cars & Trucks
My oven does not heat to the correct temperature. If I set it for 325 degrees it will heat to 390 or so degrees. It always seems to be about 70 degrees too high. Accross all ranges of temperatures from 180 degree settings to 425 degree settings.... It was manufactured in October, 2008, if that helps at all.
The thermostat is the cause of the problem, normally the the only cure is to replace the oven thermostat,completely, or alternatively, compensate by setting a lower temperature when cooking.
this will work o/k if it is always the same variation in temperature across the range .
Dec 25, 2010 | Electrolux 30" Built-In Single Electric...
Is there an ambient temperature range outside of which the freezer won't work well? Will it go down to zero degrees?
It seem ambient temperature will not affect so much inside temperature since any freezer has good insulation. Normally freezer will go down to below zero degree
Oct 10, 2010 | Frigidaire 5 cu. ft. / 142 liter Chest...
maytag mgr5765dqd temperature problems
Unfortunately, Maytag is now a division of Whirlpool, just one of many. I don't know your range but if it does not have electronic controls, the adjustment is located within the shaft of the oven temperature setting knob. The slotted screw is fairly deep in the shaft and you will need a small flat-blade screw driver with a slim and long blade. If the oven has control electronics, this adjustment will be located on the main board with the rest of the controls and this is normally located in the upright top section of the range.
May 01, 2009 | Maytag MGR5765QDQ CleanDesign Gas Kitchen...
174 people viewed this tip
David Payne
David Payne
