Tip & How-To about Computers & Internet
THERMAL PASTE helps
Maybe you have encountered problems like your computer freezes suddenly and you try to find solutions to it by troubleshooting your hardware or software installed. And after troubleshooting for hours and you are 100% sure that all your hardware and software are working just fine.
But you have never tried to look or never guess that between the Heat Sink or CPU has a solution that is put between them to be able to cool the processors/components. It is called Thermal Paste (other names: thermal grease, heat sink paste and etc.).
Thermal Paste helps the cooling off of components and draws heat away from heat sink/cpu. It is really a big help and can increase efficiency in your computer systems.
If you haven't try or see Thermal paste in your computer, try opening your system it is found between your heat sink and cpu, the substance that is applied between them.
It solves computer freezes.
Computers & Internet Logo
I keep getting an 'encountered problem, must exit' error when I go to edit pics or try to upload to shutterfly! very frustrating
Update your flash player, clear cookies and cache, and maybe update your Java. These are usually the things you will need to try to troubleshoot for these photo websites
Jun 26, 2011 | Computers & Internet
HELP! Cannot start my laptop.
This is a classic BSOD caused by a bad hardware driver. Until you can boot in safe mode, you're screwed. Keep trying F8.
Dec 23, 2009 | Acer Aspire 5500 5570-2609 Laptop
my game is moving slow...
first solution: go to run-->dxdiag--->select hardware acceleration to standard and save it
or
second solution: right click in the desktop and select the properties and select the setting--> advanced and select hardware acceleration to medium and check the display properties and check the texture level
May 03, 2009 | EA Sports Cricket 07 for Windows
Computer beeps and won't startup
try to open your cpu, and fix some hardware inside, maybe theres something lose there like video card or your RAM, i encountered also that problem. try to do this.maybe it can help.
Jan 21, 2009 | Computers & Internet
pctv hardware failed to initialized
contact pinnacle as it is a driver conflict and download uniblue driver scanner from http://www.liutilities.com/products/driverscanner/
Jan 11, 2009 | Pinnacle VIDEO CAPTURE| PCTV PRO (PCTVPRO)
179 people viewed this tip
David Payne
David Payne
