Tip & How-To about Electrical Supplies
Generator Not Producing Power - Field Winding
There are 4 requirements that have to be met before a generator is able to produce power. Due to number of questions that have been asked, a Coleman PowerMate 1500-1850 with a Briggs and Stratton Engine will be used here.
1) The Engine has to be turning at correct speed
2) Field Winding (Rotor) on the alternator must be energized
3) AC Winding (Stator) must create a voltage in presence of magnetic field
4) Output passes through Safety Devices before it reaches an outlet.
This Tip will cover the Field Winding.
The alternator of the generator is similar to the alternator in your vehicle. A current flows through the field winding, and creates a magnetic field. This magnetic field is rotated (by the engine), and the magnetic lines of force cut through the many coils of wire that are located in the stator.
First things first though. Lets see if the field winding (aka rotor) is any good. You will first have to disassemble the generator / alternator to get to the brushes. The brushes are how the current flows from the regulator, and into the rotor while it is spinning. Look closely, and you will see 2 rings on the rotor. Each ring is the end of the coil of wire that makes up the rotor. Using a multimeter, check for resistance between the rings, but make sure that you don't scratch or gouge them. You should have some kind of continuity here, compare your readings against what is published in the service manual. Also check each ring to the core or rod of the rotor as well. There should NOT be any continuity at all. If there is, this indicates a grounded rotor, and will have to be rewound (starter / alternator shop) or replaced.
Look at the brushes and brush holder assembly. Take a measurement of the length of each brush, and compare it to the minimum length in the service manual. If the brush is too short, or shows signs of overheating, shock, or otherwise, replace the brushes. If the brush holder is also darkened or burnt, it will also need to be replaces as well.
From the brush holder, follow the wires to the voltage regulator. In most low end generators, this is merely a capacitor that samples output voltage, and feeds it back into the rotor. There should also be a diode here as well. Again, using your multimeter, check the diode to see if it is open or shorted. If your meter has a diode check function, use it. Otherwise, check the diode using the resistance scale. You should have a resistance in direction, and infinite (open) in the other. If you have resistance in both directions, or infinite in both directions, then the diode is bad and will need to be replaced. Some meters will have a capacitor check, but the capacitor in the generator will likely be too large for this to work. Look for signs that the capacitor may be bad. Bulging, leaking, damaged terminals all indicate replacement is needed.
On generators that have an actual voltage regulator, you will need to consult the service manual for steps to check the regulator. Usually, regulators are not easily tested, and are replaced when other potential problems have been ruled out.
If a generator has sat for a long time, it may have lost its residual magnetism. When the engine is not turning, there remains a small magnetic field due to the properties of the iron / steel rotor core. It is possible that this field has dissipated over time. You can temporarily reestablish this field through a process called "Flashing." Basically, it involves connecting a lantern-type of battery between one of the brushes, and the core of the rotor. Consult your owners manual for the exact and recommended procedure.
If the field winding is testing good, its time to move onto the next tip:
Stator Winding.
Electrical Supplies Logo
power cord does not retract immediately
Coleman Powermate Generator 5000 Watts / 6250 Watts ...
? 3:27
https://www.youtube.com/watch?v=IROa5QfPqkU
Nov 8, 2012 - Uploaded by Carlos Roman
This 5000 watt generator is great for backup power at home or forpower ... Coleman Powermate Generator 5000 Watts / 6250 Watts ... This feature is not available right now. ... folding handle, 1 quart, of oil, and 25ft generator convenience cord. ... How to convert a generator recoil starter to an electric starter!
pull cord won t retract Power Generators Questions ... - Fixya
www.fixya.com > Forum > Tags > pull cord won t retract
Power Generators pull cord won t retract questions and answers. Ask your pull cordwon t ... Question about Powermate Powermate 5000W Generator. 2 Answers ยท I was running my coleman powermate 6250 gen power ... cord 6250 trips out ... The pullcord does not rewind onto the pulley when pulled. At first I thought it was ...
Best Portable Generator Reviews
Feb 03, 2016 | Coleman Powermate Powermate 5000W...
The generator hasn't, been used in a while and is not cranking. Gas is getting to the spark plug and the plug is clean. What could be the issue?
Coleman starter not cranking Power Generators Questions ...
www.fixya.com > Forum > Tags > starter not cranking > Power Generators
Coleman power generators starter not cranking related questions and answers. Ask your ... Ad. Question about Powermate Powermate 5000W Generator.
Powermate coleman 5000 gen. with subaru engine ... - faqqq
www.faqqq.com/.../powermate-coleman-5000-gen-with-subaru-engine-col...
Question Product: Coleman Powermate Powermate 5000W Generator Question ... it would crank for a second, then i open the choke, it would die, would not stay ...
Fixing Electrical Problems in Coleman Powermate Generators
www.alpharubicon.com/altenergy/colemanpenwu.htm
*Fixing Electrical Problems in Coleman Powermate Generators* By: Penwu 29 April 2006. All of Coleman's portable Powermate line of generators use brushes ...
Coleman 5000 watt generator cold start - YouTube
? 4:35
https://www.youtube.com/watch?v=pcT989l0rm0
Nov 3, 2011 - Uploaded by stevenpturcheck
well im starting to cycle though my equipment before winter so more cold ... How To Change Oil On Coleman Powermate Generator / Yearly ...
Jan 21, 2016 | Coleman Powermate Powermate 5000W...
coleman generator not putting out enough volts
What can happen with these generators is there is a shield built into them to devert the heat that is produced but it is still released into the surrounding components and causes a plastic rain guard to melt slightly around the edges and the melted plastic fuses to the armature and causes voltage drop through the brushes due to lack of contact. It is a relatively simple fix but it requires a rebuild kit that can be purchased aftermarket through your local generator dealer. It provides instructions for the rebuild but are often times confusing and it is usually cheaper in the long run and less hassel to let the dealer install the rebuild kit for you. If you do decide to attempt this yourself there is an 800 number provided where it can be registered and it will allow you to access schematics online for this rebuild. Hope this helps, good luck!
Sep 01, 2009 | Coleman Powermate Premium Plus 6250W...
Replacing engine on Powermate 5000W Generator
I would say, yes (given everything bolts up okay), but I wouldn't connect a full 5000-watt load to it.
May 30, 2009 | Coleman Powermate Portable Generator...
I have a coleman 5000 that runs fine but it stops producing power after it runs for a couple of minutes.
Same answer as the last time you asked, likely a flying open. If the rotor test proves that your rotor isn't opening up, test the capacitor on brushless models or the voltage regulator board on brush generators.
Regards,
Carl
Feb 23, 2009 | Coleman Powermate Premium Plus 6250W...
3,480 people viewed this tip
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
