Tip & How-To about Computers & Internet
Lexmark Printers for Vista
Most Lexmark printers are not compatable with the Windows Vista program
Go to Lexmark.com and click on the tab for DOWNLOADS to see if your is.
very few are
Computers & Internet Logo
I cant install it on windows 7
Try downloading the Vista driver. Make sure that you select the 32- or 64-bit version, as needed, from http://support.lexmark.com/index?locale=EN&page=product&userlocale=EN_US&productCode=LEXMARK_Z605&focusedTab=DOWNLOADS#4 . Click on filter to get the correct file. To check the version of Windows that you have, click Start > Control Panel > System and Security > System. If you see x64 after the OS version name, get the 64-bit driver. Otherwise you need the 32-bit driver.
Make sure to disconnect the data cable between the computer and the printer, if you have connected it. Uninstall any problem driver (generic from the Windows OS or a failed Lexmark driver install) before installing the new driver.
If you still have problems, uninstall the driver again. Then use the compatibility mode. Right click on the exe file that you downloaded from Lexmark and choose Properties. Under the Compatibility tab, check the box for "Run this program in the compatibility mode" and select Vista. Then right click again and choose "Run as Administrator".
I hope this helps.
Aug 11, 2011 | Lexmark JetPrinter Z605 Color InkJet...
compatibility
I would like to inform you that the Lexmark X4270 printer is compatible with Windows Vista.
Please follow the steps given below to download the driver for the Lexmark X4270 printer:
1. login to www.lexmark.com
2. click on Drivers and Downloads and click on Driver finder.
3. under "Choose Your Printer" type "Lexmark X4270" and click search.
4. Select "Windows Vista" from the drop down list.
5. click on "Download Now" and lcik on save and save it on to your desktop.
6.Next, follow the instructions to install the driver.
Apr 06, 2009 | Lexmark X4270 All-In-One InkJet Printer
cant find softwer
Hello there.
As this product is discontinued, you can see here that lexmark do not offer drivers for Windows Vista.
However, it is possible to install the Windows XP driver on Vista, to make your printer function. This is not supported but should get you printing again :-)
Please follow the steps here:
) Get the XP driver from Lexmark. It can be found at:
http://downloads.lexmark.com/cgi-perl/downloads.cgi?category=Drivers&ccs=229:1:0:204:0:0&searchLang=en&os_group=WinXP
2) Save it, don't run it.
3) Go to the folder called......whereever you saved it...then \Drivers\Win_XP2K\ENGLISH
4) Right-click on the file called Setup.exe, select Properties.
5) Go to the "Compatibility" Tab and check mark "Run this program in compatibility mode for: " Windows XP (Service Pack 2)
6) Run setup.
Hope this helps.
Jun 06, 2008 | Lexmark X75 All-In-One InkJet Printer
124 people viewed this tip
David Payne
David Payne
