Tip & How-To about Cell Phones
How to Pair or Connect the Plantronics 510 Bluetooth Headset to your Bluetooth phone
1. Turn on Bluetooth within your phone - Consult phone instruction booklet
2. Put phone into pairing mode - Consult phone instruction booklet
3. Put headset into pairing mode - With headset on, press and hold call button and the volume up simultaneously until the headset begins to flash red and blue.
4. Select "Add new device" on your phone.
5. Select the Plantronics headset when prompted. Enter "0000" as passcode.
6. Your 510 headset will now have a continuous blue light blinking.
7. Choose "Yes" if your phones asks if you want to bond to the 510 bluetooth headset.
8. Your phone is now paired with the Plantronics 510 headset and ready for use.
Cell Phones Logo
I have a plantonics headset that does not pair with my I phone 4s, I have pressed the button on it until the light comes up but no results, I have a plantonics 975
Turn on Bluetooth option within your phone - Consult phone instruction booklet
Put the 975 headset into pairing mode - With the 975 headset on, press and hold Call Control Button until the headset begins to flash red and white.
Select the Plantronics 975 headset when prompted. Enter "0000" as passcode.
Your 975 headset will now have a continuous white light blinking.
Choose "Yes" if your phones asks if you want to bond to the 975 bluetooth headset.
Your phone is now paired with the Plantronics 975 headset and ready for use.
Dec 22, 2012 | Cell Phones
Plantronics 925 Discovery won't connect with Droid 2
  • Turn on Bluetooth within your phone - Consult phone instruction booklet
  • Put phone into pairing mode - Consult phone instruction booklet
  • Put headset into pairing mode - With headset off, press and hold Call Control Button
  • Select "Add new device" on your phone.
  • Select the Plantronics headset when prompted. Enter "0000" as passcode.
  • Your 925 headset will now have a continuous blue light blinking.
  • Choose "Yes" if your phones asks if you want to bond to the 925 headset.
  • Your phone is now paired with the Plantronics 925 headset and ready for use.
  • Please leave me a good rating!
    Sep 04, 2010 | Plantronics Discovery 925 Bluetooth...
    how do I put it in discover mode?
    How to Pair Cardo S-800
    1.Turn on your phone and turn ON its Bluetooth function.
    2.Make sure the headset is turned OFF, then press and hold the Power Button for approximately 8 seconds until the LED status indicator begins alternating blue and red, indicating that the headset is in Pairing Mode.
    3.Set the phone to search for Bluetooth devices by following the instructions in the phone’s user guide. This is usually found in the phone’s Bluetooth menu and may be referred to as “discover” or “add” a device. (Settings > Connectivity > Bluetooth - turn ON - > Discover Devices)
    4.After a few seconds, the phone will list the “Cardo S-800” as a discovered device. Select it from the list and press “oK” or “yes”.
    5.When prompted, enter the passkey “0000” (4 zeros) and press “oK” to complete the pairing
    6. When the pairing pairing is successful the headset’s LED status indicator will begin flashing.
    You should now be able to make and receive calls using your headset. To initially connect the headset to your phone, you may need to tap the CTRL Button once on the headset. iMPortAnt: if pairing is not completed within 2 minutes while the Pairing Mode is activated, the headset will return to Standby mode, flashing blue once every three seconds and you must start the Pairing process again from Step 2 above.
    If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks.
    Feb 07, 2010 | Cardo S-800 Bluetooth Headset Wireless...
    My RAZR V3 won't pair with 2009 Chevrolet Silverado bluetooth
    http://www.gm.com/vc/bluetooth/index.jsp?brand=chevrolet&landing=true
    PAIRING A PHONE WITH YOUR 2009 Silverado
    Before you begin:
    To take advantage of the Bluetooth for Chevrolet functionality, you must first pair a Bluetooth-enabled phone to a Bluetooth-enabled vehicle.
    Note: If you do not pair a Bluetooth-enabled phone, all calls will be made using OnStar® Hands-Free Calling.3
    Some additional tips:
    1. You can pair up to five phones with your 2009 Silverado.
    2. Your system automatically recognizes the first phone you pair. To use a different paired phone, you must
    select it using the "Change Phone" command.
    3. Only one paired cell phone can be connected to your system at a time.
    4. When the vehicle is in motion, you cannot pair a phone.
    5. Pairing should only need to be completed once (unless changes to the pairing information have been made, or the
    phone is deleted).
    PAIR YOUR PHONE
    Set up phone - Turn Bluetooth 'ON':
    1. From the main screen, select "Menu"
    2. Select "Settings & Tools"
    3. Select "Connections"
    4. Select "Bluetooth"
    5. Select "Setup"
    6. Select "Power"
    7. Select "On"
    Set up vehicle - Enter 'Pairing' mode:
    1. Press and hold the Push to Talk button for two seconds
    2. Your system will respond with a "Ready" message followed by
    a tone
    3. Clearly say "Bluetooth"
    4. Your system will respond with a "Bluetooth ready" message
    followed by a tone
    5. Clearly say "Pair"
    6. Your system will respond with instructions and a four-digit
    Personal Identification Number (PIN); you will need to enter
    this PIN on your phone
    Begin the pairing process on your phone:
    5. Select "Hands free"
    6. Select "Look For Devices"
    7. Select "General Motors"
    8. Select "Yes" to bond with General Motors
    9. Enter the PIN code provided by the vehicle
    10. Select "OK"
    Finish the pairing process in your vehicle:
    1. The system will prompt you to give a name to your phone
    2. Say a name that best describes your phone (example: Corey's
    phone); this name will be used to indicate which phone is
    connected
    3. Your system will ask you to confirm your name
    4. If you confirm that name, the system will respond with the
    message: "'<Phone name>' has been successfully paired"
    Sep 04, 2009 | Motorola Mobility RAZR V3c Cellular Phone
    I need a instruction maual for a itrax bluetooth device
    Pairing With A Bluetooth Enabled Cell Phone
    1. The BTCK06 and the Bluetooth enabled cell phone should be within a distance of 3 feet
    (1 metre).
    2. With the BTCK06 OFF, press the MULTI-FUNCTION Button (The bottom button) for 6 seconds.
    The Red & Blue LED's will flash alternatley and the speaker will make a long BEEP sound.
    3. The Bluetooth cell phone will search for nearby Bluetooth devices. The cell phone will display the
    BTCK06 in the list of Bluetooth devices. If you are using a "dongle" type Bluetooth adaptor,
    follow the manufacturer's instructions for that device.
    4. Select BTCK06 to add this Bluetooth device into the list of the paired devices.
    5. Enter in the PIN Code "0000" and your mobile phone will show that pairing is complete.
    6. If Pairing is successful, user will hear a long BEEP and the Blue LED will flash about every
    3 seconds.
    Nov 24, 2008 | Cell Phones
    1,638 people viewed this tip
    Top Cell Phones Experts
    William Alequin
    Are you a Cell Phone Expert? Answer questions, earn points and help others
