Tip & How-To about Cell Phones
Easy way to pushfix iphone, wifi,youtube problem
Download these file from google, pushfix.deb file, and total comander, T-PoT.wfx,
i tried many ways here is the clear solution, at first srep you must download total comander from google, install the total comander after installation you must go to configuration and select plugins and you must configur (.wfx) and then you must add the t-pot file and click ok. here you finished the instalation
now connect the iphone to your pc and open total comander and select neighborhood>t-pot>private>var>root past the pushfix file here you can drag and drop the file.
in iphone you must go to cydia and search for ifile and install the file after install go to ifile go to var and select root there you can see the pushfix select the file and install and reboot your device and the problem of youtube will be fixed
Cell Phones Logo
Failed to fetch http://security.ubuntu.com/ubuntu/pool/main/t/thunderbird/thunderbird-locale-en-gb_31.0+build1-0ubuntu0.12.04.1_all.deb 404 Not Found [IP: 91.189.91.13 80]
The file you are looking for does not exist on the server the correct file is http://security.ubuntu.com/ubuntu/pool/main/t/thunderbird/thunderbird-locale-en-gb_31.2.0+build2-0ubuntu0.12.04.1_all.deb
I did notice that there is a newer version available and it is located here http://security.ubuntu.com/ubuntu/pool/main/t/thunderbird/thunderbird-locale-en-gb_31.2.0+build2-0ubuntu0.14.10.1_all.deb
If in the future you run into this problem here is an easy way to find what you are looking for. In the hyperlink delete the file name that failed from the hyperlink to go to the level of the repository that houses that file, in your case that would be http://security.ubuntu.com/ubuntu/pool/main/t/thunderbird/ this will show you list of files available, scroll down tell you find the file you are looking for and select it to download. Although the hyperlink is an http link it is an ftp site which has a directory structural you normally can get to find the file you are looking for. Some sites restrict the ability to browse the directory but most allow you to do this.
Oct 07, 2014 | Computers & Internet
when i try to open facebook it gets stuck loading this just started happening yesterday it totally freezes up my whole computer
download ccleaner search it from google download and install then run the program
in that u find an option run analyser this will clear the cookies and temp files
Jan 01, 2010 | Computers & Internet
i have a 32 bit install cd and 64 bit computer.. every time i try to download drivers from the tascam website they are saved as itunes files. whats going on??
you probebly set that file to open with itunes go if you have total comander -association- and select whitch program you want to open with , apply and you're done.
Dec 03, 2009 | Tascam US-122L USB 2.0 Audio/MIDI...
how to install packages in ubuntu
-best is to get help from u;re local ubuntu forum ...
-U can install with the Synaptic (System - administration - synaptic)
- or from the Aplication - Install/uninstall (the one on the bottom)
-with comands in a terminal : sudo apt-get install "program name"
- or by downloading .deb packages (the equivalent ofr an .exe in windows) and double clicking on it
Jan 08, 2009 | Computers & Internet
297 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
