Tip & How-To about Skil 2336 02 3.6V 120V Mini Drill/Driver Usa
Skil Driver 2336 - how to replace the battery 18650 3.6V
I owned my Skil 2336 driver for a year or two and it appeared to be dead; no power, no charge light. The red LED would come on when you pulled the trigger. I figured it was the battery, but could be the charger. New driver at Sears is $30. I found the battery on Ebay for $8 delivered (actually, the price was for two batteries). OK, let's blow $8 and see what happens. It was an easy fix.
You'll need a small, flat blade screw driver and a solder gun (with flux and solder, of course). The screws look like a small, special Torx drive, but the flat end screwdriver will work fine. Use the screwdriver to remove the four screws, and wiggle the "Skil" cover off (Maybe the other cover comes off just as easy... whatever!). It should look like this:
The battery is exposed. I checked it with a (cheap) volt meter and it reads about 5V DC. Strange, the new battery reads 5V. And by the way, the charger reads 14V DC. Just for the record, I could not get any voltage reading off the two charging connectors at the bottom of the handle, with either the good or bad battery.
Anyway, the battery has TABS. So it's a lot easier to solder in the new battery if you get a battery with tabs. The holes in the tabs are nice, too. The new battery I got was identified as GTL 18650 3.7V 2800mAh and don't forget "tabs".
The Pink wire is connected to the Positive (+) side. The Blue wire is connected to the Negative (-) side. I marked the battery as shown in the next picture:
The tabs on my new battery were longer than the original, so after I soldered the new battery in, I folded the tabs up on each end.
(In hind sight, the new tabs were covered with a black cover. I could have slid the cover off, snipped off the end and slid it back on before soldering.)
Before you put it together, you can try it out. My new battery came with a charge on it. There are two switches; one for the drive motor, and the other for the LED flashlight:
Check for any loose parts laying around and put the cover back on. It can be a little tricky, but it goes back on. Tighten the screws, and put on the charger.... Green light!
Speaking of "Green", please safely recycle your battery, and screw"drive" safely.
Skil 2336 02 3.6V 120V Mini Drill/Driver Usa Logo
18V Litiom Batteries (Skil)
I would return it and tell them that the battery wont work.
Mar 02, 2010 | Skil 18V Lithium Ion Drill/Driver Model #...
Charged it and it stopped working
Here is the link to Skil. http://www.skiltools.com/en/CustomerService/ServiceCenters/
Call them and see what they recommend that you do. They will want to keep you as a valued customer. Regards, Joe
Jan 25, 2010 | Skil 2362 02 7.2 Volt Lithium Ion...
Skil charger & batteries won't charge
The only thing I suggest is taking your Skil driver to a Bosch service center (Skil is now owned by Bosch) and they will replace the charger under warranty if the driver is less than a yr old. If not those chargers are not that expensive. Either way you need a new charger because they are not repairable.
Jun 10, 2009 | Skil 2362-01 Factory-Reconditioned 7.2V...
skil cordless drill model 2362 - won't charge
I have the same problem. The guys at Batterries Plus told me that 7.2 volt battereis are not easily replaced and definately not through them. If you left it charging for to long (ie over a week when you were gone like me) then the battery is never gonna charge again. You might as well find the same model of dril at skil's reconditioned site for around $40 or buy a brand new one for $60 or $70
Mar 30, 2009 | Skil 2362-01 Factory-Reconditioned 7.2V...
I have a Skil 2362 7.2v drill that goes dead when charged
Sounds like the trigger switch is bad. If you know the charger is good and it is charging the battery, then it must be the switch. I suggest you take the charged battery and test it with a multimeter for the 7.2V. If the battery is dead, then check the charger.
Take it back to Lowes and get a different brand.
Jan 19, 2009 | Bosch Skil Drill / Driver Kit
3,917 people viewed this tip
Top Skil Drills Experts
epangan29
Are you a Skil Drill Expert? Answer questions, earn points and help others
