Tip & How-To about Irons
Electric Iron not Heating Up or not Working Right
If you go to use your Electric Iron and it does not work you may be wondering what could have gone wrong. Actually there are only a few things that can go wrong with this handy little appliance.
The first thing to check is to make sure that you actually have electric power getting to the steam iron. Many times the problem is simply caused by a tripped circuit breaker, a faulty outlet, a worn or broken plug on the end of the cord, or in some cases, a fuse that is in the plug. Another common problem is for the cord of the clothing iron to break at the point where it enters the handle of the iron. By checking that you have power actually getting to the internal parts of the electric iron, you eliminate one set of common problems.
Next you need to check that the power is getting to the heating element. For the power to get to the heating elements of the iron it needs to go through the power switch and the thermostat. On some irons the power switch will be included in the iron thermostat and on others the on/off switch will be a separate switch. In either case you will need to make sure that there is continuity, or the ability for the power to flow through the switch and thermostat to get to the heating part of the iron. The thermostat is just an on/off switch that works on the temperature of the base of the iron. So whenever the iron is cold the thermostat should be closed, allowing the power to flow through it.
If the power can get to the heating element of the iron, then it should get hot. If it is not, then the heating part has failed. Sometimes, when this happens it will short out and cause the fuse to blow or the circuit breaker to trip. Many times though, the element will just simply burn out or break so that the circuit is open and the electricity cannot flow through to make the element produce heat.
If your iron is getting too hot or not hot enough then the problem will almost always be in the thermostat. Sometimes it may be a simple thermostat calibration problem, but it also can be that the thermostat simply will not work properly anymore.
This should give you a basic troubleshooting guide for home electric irons and steam irons. As you can see, there are not many parts that can fail and troubleshooting the few parts that can fail, is relatively simple with a basic electric meter.
Irons Logo
Just stop working. seems as if no electric power is reaching wherever it is suppose to. Iron is about 2 years old.
Those types of problems are usually one of two things... the cord where is enters the iron, the wires are broken. Or the thermostat has gone bad...
The iron will need to be taken apart and the wiring checked witha meter to find the problem for sure...
heatman101
Sep 27, 2011 | Euro-Pro Shark GI490 Iron
I have a 4045 model iron, extremely happy with it. Recently, when I plug in the iron the light goes on but it does not heat up at all. Any way to fix it or is it busted. Suggestions would be appreciated.
Heatman101 posted this on the site......
"If you go to use your Electric Iron and it does not work you may be wondering what could have gone wrong. Actually there are only a few things that can go wrong with this handy little appliance.
This should give you a basic troubleshooting guide for home electric irons and steam irons. As you can see, there are not many parts that can fail and troubleshooting the few parts that can fail, is relatively simple with a basic electric meter."
Sounds like either power isn't getting to the heating element, or the element is bad.
Good Luck
--HomeGrown
Dec 29, 2010 | Sunbeam Euro Press 4045 Iron
Iron keep shutting off while ironing
The cord is broken...
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Jun 21, 2010 | Black & Decker Steam Xpress AS250 Iron...
Iron won't heat up.
heatman101
Nov 02, 2009 | Panasonic NI-A57SR Iron with Auto Shut-off
62,993 people viewed this tip
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
