Tip & How-To about Office Equipment & Supplies
How to Fix a Paper Jam in a Copy Machine
It seems inevitable that the copy machine will have a paper jam. You need the copies immediately, so how do you fix the jam? Luckily, ingenuity and a manual, can help you fix the problem yourself. Fixing a paper jam, can elevate you to hero status amongst your co-workers.
  1. Discover the location of the jam. Carefully open the cover of the copy machine and the paper tray to see exactly where the paper is jammed.
  2. Step 2 Turn off the copy machine before pulling out the paper.
  3. Step 3 Pull the page out, the opposite way it is fed into the copier. Pull the jammed sheet out gently. If you tug too hard, the paper may rip.
  4. Step 4 Check for any paper fragments and clean up any torn pieces.
  5. Step 5 Check the roller where the jam occurred to be sure none of the copier parts are loose or broken. The roller should be smooth all the way across with no possible snags.
  6. Step 6 Replace the cover and paper tray and turn the machine back on.
  7. Step 7 Press the button to cancel the paper jam message. This button will vary among copy machines. The display will tell you which button to push.
Canon IR 2016j, paper jams on every copy.How do i fix it?
Dear Abdullah
pl. check the machine base where it stay, it should be plain and firm.
Next check the left side door(test it by pushing inside while making copy). check the fixing assembly and paper path, may be toner clogged on its surface.
If your machine covered more than 200000 A4 copies, check the paper path (guide) at registration sensor and delivery guide at fixing unit.
If the paper jam at paper pickup tray, replace the pickup roller set (2nos.)
Since you have not mentioned the page counter and where paper jam occurs, its difficult to assume more.
thanks.
Mar 15, 2015 | Canon Office Equipment & Supplies
Code C00-00
This code means that the main drive motor is not turning. This is usually caused by something "locking up" the machine. This can be a paper jam or something else jammed in the machine. Also check and lubcricated the gears and drive system at the end of the machine where the paper exits. You will see gears at the back side where the paper exits. Sometimes these get sticky and overload the drive system.
Good Luck
Dec 09, 2009 | Office Equipment & Supplies
Savin 4035Esp - Functional Problem Message with Code SC863
Hello sir; SC 863 means your copier hard drive not good,you need to replace one. can't repair.
May 15, 2009 | Ricoh Office Equipment & Supplies
Ricoh copy machine 3025 paper jams every time we try to print
Make sure the paper that is in the drawer matches the orientation and size indicated on thje Op Panel Display, If NOT, MAKE IT MATCH.
Mar 31, 2009 | Ricoh Aficio 3025P Black and White Copier
copying
You should be able to open the machine up easily and see the jam. It is a very small unit and no plece for the paper to hide. Does the unit use a film ribbon to print from. If so, remove the ribbon to see the jam.
Aug 09, 2007 | Sharp UX P100 Plain Paper Thermal transfer...
321 people viewed this tip
k24674
