Tip & How-To about Cameras
Canon EOS Rebel T2i Digital SLR Camera + 28-80mm Zoom Lens + 70-300mm Zoom
Canon EOS Rebel T2i Digital SLR Camera + 28-80mm Zoom Lens + 70-300mm Zoom Lens + 16GB Memory Card + LP-E8 Battery + Case + Accessory Kit Reviews
Other products by Canon Ratting Out of 5.0 Special Offer Total New 1 Total Use 0
Read More From Here Now
Kit includes:
♦ 1) Canon EOS Rebel T2i Digital SLR Camera
♦ 2) Tamron 28-80mm Zoom Lens
♦ 3) Tamron 70-300mm Di LD Macro Zoom Lens
♦ 4) Transcend 16GB SecureDigital (SDHC) Card
♦ 5) Precision Design 1000 Deluxe SLR Pro Carrying Case
♦ 6) Spare LP-E8 High-Capacity Lithium-Ion Battery Pack
♦ 7) Precision Design USB 2.0 SD/SDHC Card Reader
♦ 8) Image Recall Digital Image Recovery Software
♦ 9) Precision Design Memory Card Storage Wallet
♦ 10) Precision Design Deluxe 6-Piece Cleaning Kit
The Canon EOS Rebel T2i features a class-leading 18.0 Megapixel Image Sensor and increased light sensitivity for low light photography, as well as an advanced HD Movie mode for gorgeous Full HD movies. Able to capture up to 3.7 frames per second, it's ready to go the minute it's picked up. Advanced Live View, a new wide-area screen, plus features like Canon's brilliant Auto Lighting Optimizer and Highlight Tone ensure brilliant photos and movies.
This set of Tamron lenses includes a 28-80mm standard zoom lens, and a 70-300mm Di LD macro zoom lens.
Take more high-resolution pictures faster with this 16GB High-Capacity SecureDigital (SDHC) memory card.
Increase your shooting capacity with this powerful LP-E8 Lithium-ion rechargeable battery.
Made from durable nylon, and outfitted with a leather reinforced handle, this multi-compartment case will easily hold your camera, lenses, flash, and accessories.
Transfer files quickly and easily with this convenient USB 2.0 SecureDigital (SD) Card Reader.
Retrieve lost or deleted images from your memory card with Image Recall Digital Image Recovery Software.
Keep multiple memory cards protected and organized with this durable storage wallet.
Technical Details - KIT INCLUDES 10 PRODUCTS -- All Brand New Items with all Manufacturer-supplied Accessories + Full USA Warranties:
- <#1> Canon EOS Rebel T2i Digital SLR Camera PLUS + <#2> Tamron 28-80mm Zoom Lens + <#3> Tamron 70-300mm Di LD Macro Zoom Lens +
- <#4> Transcend 16GB High-Capacity SecureDigital (SDHC) Card + <#5> Precision Design 1000 Deluxe SLR Pro Carrying Case +
- <#6> Spare LP-E8 High-Capacity Lithium-Ion Battery Pack + <#7> Precision Design USB 2.0 High Speed SecureDigital (SD/SDHC) Card Reader + <#8> Image Recall Digital Image Recovery Software +
- <#9> Precision Design Memory Card Storage Wallet + <#10> Precision Design Deluxe 6-Piece Lens & Digital SLR Camera Cleaning Kit
See more technical details
Images Product
Read more Canon EOS Rebel T2i Digital SLR Camera + 28-80mm Zoom Lens + 70-300mm Zoom Lens + 16GB Memory Card + LP-E8 Battery + Case + Accessory Kit
Cameras Logo
I have a canon t3i. The menu doesn't turn on when you turn on the camera.
The menu doesn't display when you switch on. You should get the settings screen appear. Once powered up just hit the MENU button
Mar 02, 2015 | Canon EOS Rebel T3i 600D SLR Digital...
My Canon EOS Rebel T2i EF-S 18-55 IS Kit 18MP Digital SLR 4462B003 USA Model will not come on. What is the possible problem?
It's probably coming on but the button has been pushed to activate the viewfinder so all information gose there and the LCD screen remains black OR because this camera has an interesting feature just under the viewfinder that scenes the photographer looking into the viewfinder automatically shuts off the rear LCD screen. If this sensor is blacked then the LCD screen will not come on.
May 12, 2011 | Canon EOS 550D EOS REBEL T2i Digital...
i just bought a battery grip for my canon camera. but the grip ceases when i am using it for work. please help find solution
Is this battery grip a Canon or aftermarket accessory? Have you mounted the camera to a tripod if so what lens do you have on the camera? Are you using the adapter for the use of AA's or are you using the LP-E8 battery pack? Are you using the camera in portrait position or landscape?
Here is why Canon has had in the past some problems with battery grips but I thought it was a solved issue maybe not on the entry level DSLR's. What happens is there is enough flex between the body and the grip to break connection and yes it seizes up. Most Rebels will have a plastic lens mounting flange which will also flex with the weight of a lens (longer focal lengths). Also with the longer focal length lens it has more a tendency to flex the battery grip if mounted on a tripod. Holding in the portrait position the weight of the camera is actually pulling away from the contacts so there is a whole series of little possibilities. If it's a Canon accessory then it's a warranty thing if it's aftermarket Humm not sure should have something on it but, the quick fix is to keep tightening the mounting screw/wheel. I know that wasn't the fix you wanted but hey just telling the way it is.
Jan 17, 2011 | Canon Battery Grip (BG-E8) for Canon EOS...
EOS Rebel T2i Digital SLR is stuck on Sensor Cleaning
If you bought this camera new, return to the store and get help, or some dealer. You may also call Canon support for this model and get help there. Canon has great support, and will surely help.
Hope it works.
Apr 18, 2010 | Cameras
201 people viewed this tip
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
