Tip & How-To about Computers & Internet
Treating Windows BSOD error NTOSKRNL.EXE missing!
This is a common problem to Windows. Occurs when the System was unstable while shutting down or a Hard Disk Failure (most probably after a Power Failure).
Here is what you have to do. Please follow the steps carefully.
What resources you need:
  • Windows XP Bootable CD with Recovery Console.
  • Basic knowledge of Dos Commands.
Steps:
  1. Restart your computer and go into BIOS. Use the key which will be shown during the booting process (Default keys are Del, F2, F1, Esc and F11)
  2. Set the Boot Order to boot from CD/DVD.
  3. Insert the Windows CD.
  4. Boot the machine.
  5. Press any key when you are prompted: " Press any key to Boot from CD"
  6. Let the components load. After loading you will be asked whether you want to Install or Repair.
  7. Press R to start the Recovery Console.
  8. Let the components load.
  9. You will be asked which Windows Installation you want to access. If you have only one Press 1. If you have more than one, use the number their. It will be shown.
  10. Enter the Administrator Password to continue (If you have prompted). If you have a blank password, just press Enter.
  11. Now you will be in C:\Windows\>
  12. Now you have to find the Drive Letter for your CD Rom which has the Windows CD in it.
  13. If you cannot remember:
  14. You have to check one by one to locate the I386 folder. Its in the Root of the Windows CD. Type this command and hit enter.
  15. Driveletter:
  16. Example: D:
  17. Hit enter. Now you are in D:\>
  18. Type this command and hit enter.
  19. dir
  20. Now you will see each and every directory (and file), Do this for each until you locate the Windows CD. It has a folder named I386.
  21. When yo are their, remember the Drive Letter.
  22. Go back to C:. Type this command and hit enter.
  23. C:
  24. Type this and hit enter again. Note the space between cd and \.
  25. cd \
  26. Now your are in C:\>
  27. Type this and hit enter.
  28. cd Windows
  29. Type this again and hit enter.
  30. cd System32
  31. Now you are in System32.
  32. Note: If you were restricted to access Windows folder you have to reboot and come back to the Recovery console again.
  33. Now type this command and hit enter. I am assuming your Drive Letter (CD\DVD ROM) as E:.
  34. copy E:\I386\ntoskrnl.exe
  35. Now you will be shown "One file copied". If so you have successfully completed the Recovery Procedure.
  36. Type Exit an hit enter.
  37. Now your machine will be booted properly.
Hope you enjoy the tip.
Thanks for using Fixya!
Computers & Internet Logo
why can't the automatic repair option fix my acer aspire v5 can't repair pc
I assume you are talking about startup repair which fails no matter how many times you run it.
The most common cause for this problem is file system issues on the hard drive. This usually occurs due to an improper shutdown (by holding the power button down to shut it off or if the AC is unplugged or fails without the battery installed or when the batter has failed completely). The solution to this is to either use a Windows boot disk (with an external USB DVD drive) and perform a CheckDisk on it or take the hard drive out of the computer and attach it to another Windows computer and perform a CheckDisk on it.
The second most common reason this occurs is due to a failing hard drive. Hopefully you have your data backed up somewhere. You will need a new 2.5" SATA hard drive and the Recovery Disk Set for your computer from Acer if this is the case.
I hope this has been helpful. Good luck and remember - always back up your stuff (pictures, music, documents, etc) - the more important your stuff is, the more places you want to have it.
Dave
Jun 12, 2014 | Acer Aspire One Netbook 8.9" Notebook
I'm getting disk boot failure insert system disk and press enter please help
sometimes this occurs when the damage in the windows or hard disk
please put the windows cd and try to re-install the windows ,then the problem again displays you must change your hard drive.
Oct 13, 2010 | Computers & Internet
my computer wont load windows a problem has been detected and windows has been shut down to prevent damage to your computer. unmountable boot volume if this is the first time you seen this stop error screen and restart if appears again follow these steps check to make sure any new hardware or software is installed. I tried all of these things and nothing works I tried safe mode and it only lets me shut off and restart and always goes back to this notice. i did not install anything new. I shut my comp down and then when i restarted it has been doing this. Thank you
Your Operating System probably corrupted due to unexpected power failure or any other reason. You may have to setup widows again.
Before reinstallation take backup of all necessary file in a separate Hard Disk from your (C: ) Drive , existing desktop , my documents , share folder, etc. to do this you have to connect you Hard Disk with another workable PC.
After taking all necessary backup, setup Windows freshly and it is recommended to format C drive during fresh setup.
Jul 12, 2009 | Averatec Laptop Keyboard for 3200 Series
Break down of 160GB hard disk
Very old hdd. They have not produced a hdd smaller than 640GB for over 10 years.
Sep 27, 2017 | Compaq tc4200 Tablet PC
201 people viewed this tip
David Payne
David Payne
