Tip & How-To about Computers & Internet
"Aero features are'nt running in window's 7"
Solution: Check that your computer meets the minimum hardware requirements for running Aero:
1-gigahertz (GHz) 32-bit (x86) or 64-bit (x64) processor
1 gigabyte (GB) of random access memory (RAM)
128-megabyte (MB) graphics card
Aero also requires a DirectX 9 class graphics processor that supports a Windows Display Driver Model Driver, Pixel Shader 2.0 in hardware, and 32 bits per pixel.
For best results, you might also want to follow these graphics processor recommendations:
64 MB of graphics memory to support a single monitor with a resolution that is less than 1,310,720 pixels (for example, a 17–inch flat panel LCD monitor that has a 1280 × 1024 resolution)
128 MB of graphics memory to support a single monitor with a resolution from 1,310,720 to 2,304,000 pixels (for example, a 21.1–inch flat panel LCD monitor that has up to a 1600 × 1200 resolution)
256 MB of graphics memory to support a single monitor with a resolution greater than 2,304,000 pixels (for example, a 30–inch wide-screen flat panel LCD monitor that has up to a 2560 × 1600 resolution)
To turn on window frame transparency, the color scheme must first be set to Windows Aero.
1.Open Personalization by clicking the Start button Picture of the Start button, clicking Control Panel, clicking Appearance and Personalization, and then clicking Personalization.
2.Click Window Color and Appearance.
3.Select the Enable transparency check box.
To change the color scheme to Windows Aero
1.Open Appearance Settings by clicking the Start button Picture of the Start button, clicking Control Panel, clicking Appearance and Personalization, clicking Personalization, and then clicking Window Color and Appearance. If the Appearance Settings dialog box is not displayed, at the bottom of the page, click Open classic appearance properties.
2.In the Color scheme list, click Windows Aero, and then click OK.
Check that your theme is an aero theme and not a normal theme. Themes are available in normal and aero and can be confusing. Set your theme as an aero theme and you should get the aero window working.
These steps will help us to have AERO running.
Thank's and Regard's:
Pcs365.8
Computers & Internet Logo
can travelmate 2428awxci run windows 7?
Without any hardware upgrades, I'd say no. Below are the minimum requirements to run Win 7. A stock model of your laptop doesn't meet the minimum.
If you want to run Windows 7 on your PC, here's what it takes:
  • 1 gigahertz (GHz) or faster 32-bit (x86) or 64-bit (x64) processor
  • 1 gigabyte (GB) RAM (32-bit) or 2 GB RAM (64-bit)
  • 16 GB available hard disk space (32-bit) or 20 GB (64-bit)
  • DirectX 9 graphics device with WDDM 1.0 or higher driver
Windows 7 system requirements Microsoft Windows
Sep 29, 2014 | Computers & Internet
can i install windows 7 on acer veriton 7500g
Your Pc should meet the following hardware requirements in order to run Windows 7
  • DirectX 9 graphics device with WDDM 1.0 or higher drivers
I googled your pc model and found that you just need to install extra RAM (if your PC have less than 1 GB RAM).
May 05, 2012 | Acer Computers & Internet
is windows 7 compatible with acer travelmate 4150 laptop
    So if your Acer TM4150 meets this minimum requirements, then you can install the windows 7 OS
Oct 27, 2010 | Acer TravelMate 4150LCi Notebook
Will the Aspire 5100 run Windows 7?
if your laptop meet the requirements of windows 7 it is good>>. it can run the windows 7>>> i will give you the system requirements of windows 7>>>>
  • Processor: 1 GHz 32-bit or 64-bit processor
  • Memory: 1 GB of system memory
  • Hard drive: 16 GB of available disk space
  • Video card: Support for DirectX 9 graphics with 128MB memory (in order to enable Aero theme)
  • Drive: DVD-R/W drive
Dec 14, 2009 | Acer Aspire 5100-3357 Notebook
vista on my toshiba laptop not updating,
Check your processor, hard disk, and memory / graphics
against this list.
Recommended minimum hardware requirements for Windows Vista loadTOCNode(2, 'summary'); The following list describes the recommended minimum hardware requirements for basic functionality of the different editions of Windows Vista. Actual hardware requirements will vary, depending on system configuration and on the programs and the features that you install. If you install Windows Vista over a network, additional hard disk space may be required. Windows Vista Home Basic
  • 800-megahertz (MHz) 32-bit (x86) processor or 800-MHz 64-bit (x64) processor
  • 512 megabytes (MB) of system memory
    Note On system configurations that use system memory as graphics memory, at least 448 MB of system memory must be available to the operating system after some memory is allocated for graphics.
  • DirectX 9-class graphics card
  • 32 MB of graphics memory
  • 20-gigabyte (GB) hard disk that has 15 GB of free hard disk space
  • Internal or external DVD drive
  • Internet access capability
  • Audio output capability
Windows Vista Home Premium, Windows Vista Business, Windows Vista Enterprise, and Windows Vista Ultimate
  • 1-gigahertz (GHz) 32-bit (x86) processor or 1-GHz 64-bit (x64) processor
  • 1 GB of system memory
  • Windows Aero-capable graphics card
    Note This includes a DirectX 9-class graphics card that supports the following:
    • A WDDM driver
    • Pixel Shader 2.0 in hardware
    • 32 bits per pixel
  • 128 MB of graphics memory (minimum)
  • 40-GB hard disk that has 15 GB of free hard disk space (the 15GB of free space provides room for temporary file storage during the install or upgrade.)
You can download a free and updated virus scanner here.
You can also acquire a free trial (recommended) of asquared
anti-malware here. Run a "DEEP" scan with a2 free.
Nate P.
Jan 25, 2009 | Microsoft Windows Vista Ultimate Edition
166 people viewed this tip
David Payne
David Payne
