Tip & How-To about Garden
How to take out the seed of a pomegranate quick & easy
Cut the pomegranate in half not the from the top to bottom the other way put one half in a storage bag and make a small knot. Then hold it softly in your palm and take a spoon and start from the bottom of the outside to knock on the pomegranate. move the spoon all the while knocking on the outside till you reach the center top and knock on all sides all around. you will have a juicy pomegranate seeds to eat.
Garden Logo
What spray can I use to protect my pomegranates from fruit fly?
traps and baits
and or net bag the individual fruit clusters
Nov 03, 2016 | Cooking
recoil spring is broken how to replace this, The rope is ok. Victor mower
take your rope off pulley then start winding pullet by hand till ti wont wind anymore line the pulley hole with the hole in the top cap slip the rope threw both holes knot the end threw the pulley hole slowly let the spring rewind the rope into houseing until it stops pull 1 foot out cut hold on to it slip threw your handle and knot it all done
Jul 02, 2012 | Briggs & Stratton Garden
I have a broken pull cord and cannot figure out how to fix it.
Easiest way is to remove the complete blower housing assembly, remove the old rope, then twist the rope pulley around and around until the spring is tight, ease it back until the hole in the pulley for the rope lines up with the hole in the recoil housing and stick a small screwdriver through the pulley and the housing to hold tension on the spring. Next, take your new rope and feed it first through the recoil housing, then through the hole in the pulley, tie a good solid knot right at the end of the rope and pull it back out until you feel it pulling on the pulley. Now holding tension on the rope, remove the screwdriver and let the spring tension slowly pull the rope back into the the pulley until it is full, pull it back out about a half turn on the pulley and tie a slip knot against the outside of the housing to hold it in place and reassemble everything. Hook the end of your rope through the rope guide on your handle if it has one, slip the handle on and tie a knot to hold it. Cut off the excess, pop out the slip knot and it will pull up tight and you are ready to go
Sep 16, 2009 | Toro Lawn Mower With Toro Power Tools
pomegranate
Well ya can juice 'em but it's a bit labour intensive .. lol 'cause ya gotta skin 'em, and get ALL the "Seeds" out, they taste bad... then put the pulp in.. and juice away... yield is low also .. but tastes real nice in the end.. I usually do it in a plastic bag,and tip the pulp into the juicer. Ya can make great "leathers" too..
Aug 04, 2007 | Jack Lalanne Power Juicer 250 Watts
547 people viewed this tip
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
