Google Chrome Logo
Tip & How To about Google Chrome
How to edit / remove the Attribution Widget from a blogger page
Posted by Owen Stephen DawsonOwen Stephen Dawson on Monday, July 12, 2010
Most if not all blogger templates come with a attribution widget that you are unable to remove however you can edit it although this is limited and you need to know where to look on the HTML template.
When you have completed this simple edit you will be able to remove the widget like all the others.
First search for these lines of code about 3/4 way down the template.
With the older templates all you need to do is to Comment-out the code that displays the Attribution gadget, by putting it inside these characters so it ends up looking like this you must also make sure that you have checked the Expand Widgets Box. Accept it then save the widget.
Then save the template and that is.
In the newer XML all you need to do is to change the locked='true' to read locked='false' this will allow you to remove it should you choose to.
Read more tips from Owen Stephen Dawson
