Tip & How-To about Computers & Internet
How To Reset Your Linksys Router Password
If you have forgotten your Linksys router password, the easiest thing to do is to reset your router to the factory default settings and then go through the router setup process.
  1. To restore the router configuration to factory defaults, hold the reset button on the unit for 30 seconds.
  2. Once your router is hard reset, you will need to login and go through the router setup process.
  3. To reconfigure your Linksys, connect a PC to one of it's Ethernet ports, load a web browser, and go to http://192.168.1.1/. This will take you to a popup box which asks you to enter a username and password to login to your router.
  4. On older Linksys routers, the default username is blank and the default password is "admin."
  5. On newer Linksys routers, both the default username and the default password are set to "admin."
  6. Once you are past the login screen, you are able to reconfigure the Linksys router.
  7. Go to the management tab and change the administrator password to keep others from accessing your router.
Computers & Internet Logo
i have no wepkey to network the problem is anyone can browse connecting to my network using wi-fi
  • If you have forgotten your LinkSys router password, the easiest thing to do is to reset your router to the factory default settings.
    Once your router is hard reset, you will need to login and reconfigure it again.
    To reconfigure your LinkSys, connect a PC to one of it's Ethernet ports, load a web browser, and go to the URL http://192.168.1.1/. This will take you to a popup box which asks you to enter a username and password to login to your router.
    LinkSys Default Password
    On older LinkSys routers, the default username is blank and the default password is "admin." On newer Linksys routers, both the default username and the default password are set to "admin."
    Once you are past the login screen, you are able to reconfigure the LinkSys router.
    You want to go to the management tab and change the administrator password to something else to keep others from accessing your router.
  • 3
    After changing the administrator password then you will need to enable WEP or WAP security so your nosy neighbors aren't tapping into your wireless network. I am picking up 4 networks with my pc antenna.
    Good luck
  • Mar 12, 2011 | Linksys Wireless-G Broadband Router
    i need to secure the network from my router ....how do i do this?
  • To reconfigure your LinkSys, connect a PC to one of it's Ethernet ports, load a web browser, and go to the URL http://192.168.1.1/. This will take you to a popup box which asks you to enter a username and password to login to your router.
  • After changing the administrator password then you will need to enable WEP or WAP security so your nosy neighbors aren't tapping into your wireless network. I am picking up 4 networks with my pc antenna.
  • Oct 11, 2010 | Linksys Wireless-G Broadband Router
    lost my password and cannot connect new netbook
    hi
  • Step 2reset-password-linksys-router-1.2-120x120.jpg jQuery(document).ready(function(){ jQuery('#jsArticleStep2 span.image a:first').attr('href','http://i.ehow.com/images/a02/2p/6m/reset-password-linksys-router-1.2-800X800.jpg'); }); Once your router is hard reset, you will need to login and reconfigure it again.
  • Step 3 After changing the administrator password then you will need to enable WEP or WAP security so your nosy neighbors aren't tapping into your wireless network. I am picking up 4 networks with my pc antenna.
  • Jul 21, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
    How can I reset an unknown admin pw on Linksys RV042 VPN Router? I'm the new IT guy here, and I don't have the admin pw for our VPN router (and I need to provide remote access to a colleage working remotely. Thanks!!!
    To reconfigure your LinkSys, connect a PC to one of it's Ethernet ports, load a web browser, and go to the URL http://192.168.1.1/. This will take you to a popup box which asks you to enter a username and password to login to your router Password: Admin
    Apr 16, 2009 | Linksys RV042 VPN Router
    how do I login to my linksys
    If you have forgotten your LinkSys router password, the easiest thing to do is to reset your router to the factory default settings. To restore the router configuration to factory defaults, hold the reset button on the unit for 30 seconds.Once your router is hard reset, you will need to login and reconfigure it again.To reconfigure your LinkSys, connect a PC to one of it's Ethernet ports, load a web browser, and go to the URL http://192.168.1.1/. This will take you to a popup box which asks you to enter a username and password to login to your router.the default username is blank and the default password is "admin." On newer Linksys routers, both the default username and the default password are set to "admin."
    Apr 09, 2009 | Linksys Wireless-G WRT54G Router
    861 people viewed this tip
    David Payne
    David Payne
