Tip & How-To about Audio Players & Recorders
How To Reboot An iPod Touch
If Your iPod Isn't Frozen
  1. Hold the Power button until you see the "Slide To Power Off" slider.
  2. Let go of the Power button, and slide the slider.
  3. Wait until it turns off completely, press the Power button again to turn it back on.
If Your iPod Is Frozen
  1. Press and hold the power button and the square home button at the same time.
  2. Wait some time it will reset eventually.
ipod frozen on safari
Apps are programs too,and sometimes software gets stuck.To make an app shutdown without restarting,press and hold the sleep/wake button until you see the power off slider but don't slide to off.Press and hold the home button until the app quits .
May 03, 2012 | Apple iPod Touch 8GB 32GB 64GB 3rd...
My ipod touch screen is frozen on "slide to unlock" so I can't slide it.
Restarting the ipod after it has frozen is a simple 5 step process.
  1. Hold down the hold button at the top left of the touch and the home button at the center front of the device.
  2. Continue holding them even after the slider to turn off the touch appears. Do not let go at this point.
  3. A few seconds after this, the screen will flash and go black. At this point, the touch has been rebooted.
  4. Hold down the hold button at the top left until the screen lights up again and the Apple logo appears.
  5. Release the button and let the iPod touch finish booting up and you’ll be ready to rock again
Sources: http://ipod.about.com/od/troubleshootingyouripod/qt/ipod-touch-reboot.htm
I hope that information above has helped is some way.
If possible please rate this solution.
Sep 01, 2010 | Apple iPod touch
how to restart an ipod touch....it has a password lock on it
hi just a tip hope it would work!
1.hold on the power button until you see the "slide to power off" slider
2.let go off the power button and slide the slider
3.wait until it turns off completely. press the power button again to turn it on
Jun 03, 2010 | Apple iPod touch
How do you restart an Ipod?? I was trying to
IF IPOD ISN'T FROZEN.
IF IPOD IS FROZEN.
  3. Be patient.
Hope this helps - good luck!
Sep 17, 2009 | Apple iPod touch
frozen screen
First, make sure the lock slider is in the proper position.  I know, obvious, but you'd be surprised how often this happens.
Next, slide the lock slider to locked and then back.  Then press and hold the Menu and Select (center) button for 6-8 seconds.  Try a couple times if it doesn't work the first time.  The ipod should reset and work.
If that didn't work, you can reset your ipod.  But first, try connecting the ipod to your computer and see if it goes into sync mode. If so, wait for iTunes to load and then eject your ipod in iTunes and see if it works again.
To reset your ipod, slide the lock slider to locked and then back.  Next hold the Play/Pause Button and the Menu button for 6-8 seconds.  You may have to try this a couple times.  The ipod should reset.
The last thing to do is to let your ipod discharge completely by leaving it at the frozen screen.  Once your ipod is out of battery, reconnect it to you computer or a power adapter and let it charge.  Then try to access it again or repeat the steps above.
Nick
Jan 22, 2009 | Apple iPod nano
677 people viewed this tip
 Grubhead
Grubhead
