Tip & How-To about Video Game Consoles & Games
Xbox Controller to USB Conversion
Did you know the Xbox controller has a USB interface built-in? How would you feel about playing your favorite PC games, with an Xbox controller?
Here is what you will need to get the job done:
  • Xbox Game Controller
  • Male USB Connector
  • Wire Strippers
  • Electrical Tape
1. Using a Male-Female USB extension cable, cut off the male USB adapter, along with a foot or more of cable.
2. You will need to cut off the connector on the Xbox cable, too.
3. Cut the Xbox connector off right at the base, leaving you some room to splice on the USB Male connector.
4. Now strip off about an inch of casing from the end of each exposed cable that we’ll be connecting. There will be a lot of thin silver wires and foil wrapped around a few smaller, colored wires. The silver casing is the shielding, just trim it back enough to expose the colored wires.
5. Using your wire strippers, pull away the casing on each of the colored wires to expose the bare wire.
6. Splice together each wire of the USB adapter to its matching colored wire on the Xbox controller. The Xbox controller has an additional yellow wire, which you can ignore. Use electrical tape to cover up the bare leads, or heat shrink tubing.
7. You should now be able to set up the device and start using it. The first thing to do is to download the XBCD drivers (download here), and run the installer file.
8. Once the drivers are installed, plug in the controller and it should detect and install the drivers for “XBCD XBox Gamepad”. Now go to Programs -> XBCD -> Setup Utility and set up your new gamepad!
Video Game Consoles & Games Logo
how to on the lights on the ball of broom
E74 Error! You Can Fix It!
Did Your Xbox 360 Stop Working Right In The Middle Of An Exciting Game? Do You Feel Hopeless That You Can't Finish Or Even Begin A Game That You Have Been Looking Forward To Playing? Discover The Secret To Getting Your Broken Xbox 360 Back To Playing Your Favorite Video Game in 1 Hour Without Having To Open Up Your Xbox 360 & Void Your Warranty! www.xbox360e74errorfix.com
Jun 29, 2012 | Sony Playstation 3 (PS3) Console
"HOW TO" use xbox 360 controller on pc games
Most games support the gamepad by default. You should not need any software or setup. But you might need the Drivers for it... Check this out, hope it helps:
http://www.microsoft.com/hardware/download/download.aspx?category=Gaming&type=Gaming&sku=JR9-00001
Mar 31, 2010 | Microsoft Xbox 360 Controller
my x box will play cd's and dvd's but not games. do you know what i can do to fix that. when i put in a game it says to put disc in an x box 360 console.
Here's how:
1. Carefully open the Xbox by removing the torx screws and then releasing the clips that hold the case together. The clips and molding pieces all come off easily; pry them open carefully.
2. Load the flash firmware disc into the DVD drive and power off the Xbox.
3. Disconnect the DVD drive from the SATA cable and note the brand of drive used in your Xbox. Currently Microsoft uses Hitachi, Phillips and Toshiba DVD drives in the Xbox 360. Only the Toshiba and Hitachi drives have firmware updates.
4. Connect the DVD drive to your PC with a cross-wired SATA cable interfaced to a compatible SATA port. Confirm that the video cable is connected to the Xbox so that it won't turn off during the flash process.
5. Hold the two loose wires of the cross-wired cable together and press the "Start" button on the Xbox. Separate the wires immediately when the green light begins to flash on the front of the Xbox. The light will begin to flash quickly and the drive will begin to spin as it enters mode "B."
6. Turn the PC on and allow it to fully boot from the DVD drive. If Windows appears to fail the boot, eject the DVD and it will finish booting. You've successfully flashed the drive.
7. Reassemble the Xbox and enjoy playing the backup of your favorite game. Sources: http://www.ehow.com/how_2316522_flash-xbox-dvd-drive.html
Mar 10, 2010 | Buck Legendary: The Box for Xbox 360
I have just been offered a logtech wingman/rumble controller/FS2004 concord ect,what is it and how does it work,what kind of equipment do i need?pc,console if so what type
  • This item is a game playing device for PC.....desgined for window 95/98. It boasts:
  • Sophisticated dual motor technology provides maximum vibration feedback
  • 2 ultra-accurate and responsive analog sticks for precise 360 movement
  • Easy-to-reach throttle control
  • Convenient USB interface
Also manufacturers description states: Just try and hold on to the new WingMan RumblePad gamepad. Boasting nine programmable buttons, the RumblePad offers a sliding throttle for precise speed control, plus two analogue sticks to let you quickly rotate a full 360 degrees. But it's the vibration feedback that will truly rock your world! Two motors housed in the RumblePad grips let you feel every turn, bump and dip in flying, driving, adventure, SIM games and more. No batteries are required as it draws power from the USB port on your PC.
Please leave me a positive rating if you feel the description was helpful. Thank you!
Sep 03, 2008 | Video Game Consoles & Games
NEED CONFIGURATION TO PLAY HALO
keyboard= forward=W left=A right=D back=S
jump=space fire weapon=left click gernade=right click switch weapon/get in vehicle=E melee=F
R=reload Q=flashlight Z=zoom V=switch to 2nd weapon
controler=
A=jump B=melee X=switch weapon/enter vehicle
Y=switch to 2nd weapon leftstick=move rightstick=move camera RT=fire LT=gernade
hope this helped
Mar 30, 2008 | Logitech Dual Action for Pc (963292-0403:)...
959 people viewed this tip
Top Video Game Consoles & Games Experts
James Wishart
Josh Whitehead
Josh Whitehead
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
