Tip & How-To about Computers & Internet
Little trick help you to reset Windows Password!
Method one: Login with the default administrator account
Step 1: Start Windows PC
Step 2: When you can see the Windows login screen, press ctrl+alt+del keys Twice and it’ll show Classic Login box
Step 3: Type Administrator as Username and leave the Password field blank
Step 4: Press the Enter Key and then you can be able to login the default windows administrator account which is it created by default when install windows.
Note: When you input the key combination Please don’t put the cursor on any account. And if you change the name or password before, you cannot login by this way.
Method two: TRY command prompt about password reset trick
1. Log in with any valid account.
2. Bring up the command prompt.
Type: net user
You get a list of accounts
Type: net user Administrator *
Type: net user (any account on that list) *
3. It prompts for a password. Enter one, then enter it again when prompted to confirm.
Now, try to log on as ‘Administrator’ with your new password. *
Please note that this might not work on a LIMITED account .
Method three : use a Windows Password Recovery cd
1. Visit the windows Password Recovery tool official site: http://www.windowspasswordsrecovery.com
2. Download the tool and run it
3. Burn the password reset cd to a blank CD/DVD or USB flash drive
4. Turn to the computer which you lost password, reboot it, insert the nearly created recovery disk.
5. Click Del key to load bios setting, set the system load from cd/dvd or usb, save the change
6. reboot the computer, load the password recovery software
7. select the windows os installation folder, select the user accout , reset the password
8. finish. you can login windows with a blank password now.
Computers & Internet Logo
My daughter passed away on the 9th 0f April before she went into hospital she closed her computer down. have you got a solution to reset the password so I can do what she wants
Step 2: When you can see the Windows login screen, press ctrl+alt+del keys Twice and it'll show Classic Login box
Note: When you input the key combination Please don't put the cursor on any account. And if you change the name or password before, you cannot login by this way.
Apr 17, 2015 | Acer Aspire Computers & Internet
when l log on l put in my username it starts to log on then it just logs stright off again?
It would help if I knew what OS you were using. But...you can try this:
If that doesn't work you can go to another pc and burn a Trinity Rescue cd. You can get the ISO and burner at the following links. Both have good instructions for use.
http://download.imgburn.com/SetupImgBurn_2.5
.2.0.exe
http://trinityhome.org/Home/index.php?
wpid=1&front_id=12
Good luck
Oct 18, 2010 | Acer Aspire One PC Notebook
Lost my administrator password, how do i remove it? i now have only bio scan access.
are you using windows XP if you are log into safe mode tap f8 upon powering the system till you get windows advance menu select safemode, in safemode log in try logging in as admiistrator leave password field blank if it logs in go to control panel and click user accounts change or manage user accounts select you log in with the lost password change the password or better remove the password then restart system log in using the user name u normaly use if it log directly that is good then ccreat a new password under that account profile ^_^ this should work but for vist and win7 it might be imoissuble to log into an administrator account you must at least know the password if you created one if not then reinstalling vista and win7 is the final option ^_^
Jun 05, 2010 | Alienware PC Systems Alienware M17...
forgot my password
Hi, guy
Dont't worry,we often forget the passwords like windows, office,access,adobe PDF,winRAR/RAR and so on. What should we do when we locked out? How to unlock the passwords quickly and safely? Today, I recommend a very good Password Recovery software for you.That is: Password Recovery Bundle which can recover the password whatever it is.
you can download the product form Password Recovery Official site http://www.recoverlostpassword.com/
Apr 29, 2010 | AccessData Password Recovery Tool Kit (ftk...
206 people viewed this tip
David Payne
David Payne
