Tip & How-To about Cell Phones
NOKIA 3310 damaged LCD...
Some 3310 LCD's have 2 capacitors at the back of the LCD, try to resolder that 2 capacitors, for me it will help back the 3310 to normal.
galanronan@yahoo.com
Cell Phones Logo
lcd monitor automatic on off
There are 4 bad capacitors involved. It may not seem bulging but one or two are leaking. These are the 4 capacitors. 2 pcs. 470 microfarads - 25v 1 pc 1000 microfarads - 25v 1 pc 1000 microfarads - 10v I replaced them all. Next is to clean the board at the back. I got 91% alcohol and toothbrush and scrub. Concetrate on the 8-pin IC which has colored yellowish paste. Scrub or use a Q-tips buds soak with alcohol and clean it. Next resolder all 4 trasformers. Two on the primary and 2 from the inverter side. Also resolder the 2 transistor/mosfet (3 legs) which is attached to the metal (heat sink). After resoldering, again clean with alcohol by scrubbing or Q-tip buds for sensitive part.
Mine is working fine now. Good luck
Roan
Feb 02, 2011 | Samsung SyncMaster 920NW Monitor
HP Pavilion F1703 goes black after 2 - 3 seconds
Resolder the leads of the four TOROID inductors, make sure to remove the old solder, clean the leads real well and resolder. Also check caps for leaking/bulging tops and bottom seals, check the transistors (c5706/5707) for shorts.
See my pictures here:
http://s807.photobucket.com/albums/yy352/budm/HP%20F1703/
Basic LCD monitor and LCD TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV, Monitors, Caps : http://s807.photobucket.com/home/budm/allalbums
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitor kits: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find
Nov 14, 2010 | HP Pavilion F1703 17" LCD Monitor
How to open the back cover of the LCD monitor
Hi..there,
It's seems you got a backling inverter busted. Need to replaced a new one or repaired it. To repaired you need to replaced a bad capacitors with a bulged on top of each caps. Not sure...just replaced all the caps...:) Ok! to open the back cover, there are 2 types to open it. First unscrew the 4 corner screws. If there are some... First type it from the back. After you had removed all the screws. Get a good grip on the bottom R/H side with both hands pulling as hard as you can on the 2 joints. 2nd type from the front bezel. Laid your monitor screen upward and placed a piece of clothes to proctect the screen from smudged. Used 2 hands to lifted up the edged of a bezel...do the same on the other side... After that just removed the screws...and that's how to open the front and back cover... Have a nice day!
Oct 13, 2008 | AOC LM729 17" LCD Monitor
help on PDR-3310 can not power on and no displace on LCD
Push lens assembly back into camera gently yet firmly with your thumbs until you hear a click.
May 14, 2008 | Toshiba PDR-3310 Digital Camera
LCD monitor image blinking
There are two coils in the circuit board that normally causes this problem due to dry solder. try to desoder clean and resolder these coils.
Hope this helps.
If it does, please vote. Thanks!
Apr 28, 2008 | Gateway FPD2275W LCD Monitor
164 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
