Tip & How-To about Computers & Internet
How to configure Netgear WGT624 v3 router with Globe Broadband Huawei B200 modem.
1. You have to reset your router to its original factory configuration by using the reset button at the back of the router (WGT624 v3) near the antenna. 2. Connect the cable from the Globe Broadband Huawei B200 modem to the wan port of the router. 3. Connect another cable (RJ45) from the router (any Lan port on the router) to the laptop or desktop. 4. Switch on both device (modem and router). 5. Wait till both device boot up and the modem flash a blue, green and yellow color on its led and solid green to all router indicator led except the test led indicator flashing for a few seconds only.
6. Open your browser (e.g. Mozilla Firefox, Safari...) 7. Type http://192.168.1.1 at the address bar. 8. Netgear setup website will open. 9. Go to advance settings. 10. Go to back up menu and click erase to reset your router to its original factory settings. 11. Logout. 12. Switch off the device (modem and router). 13. Remove the cable connecting the computer and the Lan port of the router. 14. Connect the modem directly to the laptop using the cable. 15. Open a browser. 16. Go to the netgear website. 17. Go to the Support menu on the Netgear Website. 18. Type the model of the modem (WGT624 v3) on the blank space provided (Find your product). 19. Go to Downloads. 20. Download WGT624v3 Firmware Version 2.0.26_1.01 NA. 21. Read the instruction how to download the firmware and how to upgrade your router to the new firmware. 22. Save the downloaded firmware. 23. Exit the Netgear Website. 24. Switch off the modem. 25. Now follow the instructions #2 to #8. 26. Go to "Upgrade the Router" menu. 27. Upload the downloaded firmware to the router. 28. After uploading the firmware go to the Basic Settings Menu or use the Smart Wizard Menu to configure your Router.(Important Updates: Lan IP Address will be changed automatically to 10.0.0.1). Automatic internet connections will be tested by the network. 29. Configure your wireless settings. Logout. 30. Reboot all the devices and the laptop/desktop. 31. Follow the sequence when rebooting. (modem-router-laptop/desktop). 32. Open a browser and browse any website. 33. Enjoy.
Computers & Internet Logo
HOW TO RESET THE ROUTER
You can reset your Netgear router/wireless WGT624 router to the factory settings from within the router manager. The reset procedure removes all user-configured settings and returns the router to the original factory settings.
For this reason, only reset the router if you encounter problems that can't be solved with other methods.
Step 1: Check that your Netgear router/wireless WGT624 router is properly connected with your system or not. If it is OK, then press reset button on Netgear router for at least 10 seconds. The 'test' light should flash during this process.
Step 2: Now open browser and enter Netgear's IP address into the address bar. Generally, '192.168.0.1' is the Netgear router IP address but you can find specific IP address in Netgear router manual.
Step 3: Now enter your default username and password to log in to router.
Step 4: Click 'Erase' button under the 'Revert to Factory Default Settings'. This process will erase all your previous changes that have been made to the router and restore the configuration settings to factory setting. Don't interrupt the process until the process is finished.
Once the router's 'test' light has stopped blinking and the configuration page you are on has refreshed, the router has been reset.
Feel free to get instant online Netgear router support at http://www.vtechsquad.com/netgear-router-support/ to fix Netgear router/wireless router issues.
Feb 06, 2012 | NetGear : WGT624 108 Mbps Wireless...
PURCHASED A SECOND LAPTOP TODAY AND THERE IS A SECURITY CODE(PASSWORD) REQUIRED TO ALLOW THIS COMPUTER ACCESS TO THE SYSTEM I HAVE ...HOW DO RETREIVE THIS OR SET UP NEW ..I HAVE A 108 MBPS WIRESLESS FIREWALL ROUTER WGT624 v3
it sounds like you are trying to access a computer from another computer.
you need to:
1. configure a home network so both computers can see each other:
vista
xp
7
2. now you need to share folders
vista
xp
7
now if by ACCESS TO THE SYSTEM I HAVE you mean your network, you need to know what passcode or key code your router was set up with. if you didn't setup security for your password talk to the person that did and find out what the password is. if you can't reach this person you may need to reset your password to defaults which should automatically allow access to any computer your bring into your wireless network (not recommended without security) and then you should reconfigure security and make a note or remember the new password or keycode so you can configure the new and any other computer you want to allow to connect to your network.. this is how you can set to router back to defaults:
To restore the factory default configuration settings without knowing the administration password
or IP address, you must use the Default Reset button on the rear panel of the router.
1. Press and hold the Default Reset button until the Test LED turns on (about 5 seconds).
2. Release the Default Reset button and wait for the router to reboot.
for more info on how to reconfigure your router and security for it here's your router's manual
good luck
Dec 26, 2009 | NetGear WGT624 Wireless Router
my pc has locked me out of the internet and i unfortunately didnt save the WEP key, the router is a NetgearWGT624 v3
The WEP encryption key is stored in the wireless setting in the Netgear wireless router.
Connect a LAN cable from the computer to the Netgear router and open IE browser and enter the Netgear configuration IP address (http://192.168.0.1) default login = admin default PW = password (type in the login password if you had changed it).
In the wireless encryption setting note down the encryption key. Use this key to configure the wireless card in the computer.
If you forgotten the PW then you can reset the router back to the factory configuration by using a sharp point and pressing the reset button at the back of the router until the LEDs flash, then release the Reset button.
Then login as previously stated. You can then create a new encryption key. I suggest you use WPA2 or WPA encryption key because it is much stronger than WEP.
I also suggest :-
Change the default password
Change the default SSID
For additional wireless security - enable MAC address filtering (this allows only listed MAC addresses of wireless cards to connect to this router - add the MAC address of your wireless card to the MAC address table in the wireless router).
Don't forget to configure the wireless card in the computer with the router's SSID and encryption key.
Oct 25, 2009 | NetGear WGT624 Wireless Router
We have a sucessful wireless network to one lap top, however we do not know or remember our wpa to enable us to open our secure network to other select users.
If you don't have the password to log into the router's configuration using a wired PC, you'll need to reset the router using the little button located on the back or bottom of the router. This will reset it to the default factory settings and clear all configuration.
Mar 05, 2009 | NetGear WGT624 Wireless Router
WGT624 v3 transmits no wireless signal.
You have to set up your router again. The id will be "admin" the password "password".
See manual" http://kbserver.netgear.com/pdf/wgt624v3_ref_manual_25Apr05.pdf
Feb 19, 2009 | NetGear WGT624 Wireless Router
845 people viewed this tip
David Payne
David Payne
