Tip & How-To about Computers & Internet
Enabling boot defrag in windows XP for faster boot up
  • Go to Windows XP Start>> Run>> Type in: regedit [Enter]
  • Drill down to:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Dfrg\BootOptimizeFunction
  • Single click on BootOptimizeFunction to empty its contents into the right pane
  • Right click “Enable” from the list in the right pane
  • Select Modify from the resulting menu
  • Change the value to Y to enable and N to disable
  • Reboot your computer for the change to take effect
Computers & Internet Logo
MY WINDOW 7 IS NOT GENUINE
Go to run.type in regedit. go to hkey local machine.expand that. scroll down untill you find Windows NT expand that. click current version.expand that. go to winlogon.expand that. go to notify and delete that folder.say yes to the warning.go to computer click on your hard drive. search for wga tray. delete the wga tray.restart your computer for changes t take effect
Sep 09, 2012 | Microsoft Office Professional 2007 Full...
How can I get rid of The Weather Channel and Ebay Countdown when I open my Window?
Weather Channel and Ebay Countdown are usually on the startup..If you pertaining when you log on to windows then Weather Channel and Ebay Countdown pops up I have the solution for your problem..
You can edit the start up by clicking on start then run, then type msconfig..System Configuration utility will pops up..Search the entries responsible for the Weather Channel and Ebay Countdown..Uncheck those two entries and click on apply then restart the computer..
Another way is by deleting the start up entries of the two items.. Click on start, then click on run, then type regedit.. Registry editor will appear after doin so..Expand computer then 5 hives will appear..expand HKEY Local Machine look for Software..Expand Software and look for Microsoft..Expand Microsoft then look for Windows..Expand Windows and look for CurrentVersion..Expand CurrentVersion and look for RUN..Highlight RUN and check the entries on the left pane..Look for the entries of weather channel and ebay countdown..delete the two and restart pc..
Feb 01, 2010 | Microsoft Windows Vista Home Premium...
I picked up this program called personal antivirus and I can't get rid of it.i looked in my programs and it's not even there.Any ideas?
go to start menu, then go to "run", then type regedit and hit enter.
Now you are in registry.
Find the HKEY LOCAL MACHINE and expand it, then find Software, and expand it. You should see your program here, right click and delete file.
Do the same with HKEY LOCAL USER
Also go to start menu, search , type program name. When found, right click and delete all files.
Oct 01, 2009 | HP Compaq Presario SR2180NX (RK548AA#ABA)...
genuine microsoft solve problem
Activate Windows XP Without Registration "
1. Type Regedit on the Run Menu
2. Go to Hkey-Local_Machine/Software/ Microsoft/WindowsNT/CurrentVersion/
WPAEvents
3. Select OOBETimer (Reg-Binary) and Press Enter. Now You will See a Set of 12 Keys.
4. FF D5 71 D6 8B 6A 8D 6F D5 33 93 FD
{just delete D6 (4th entry) and replace it with C4}
5. Exit Regedit.
6. Type "%systemroot%\system32\oobe\msoobe.exe /a" on the Run Menu (without quotes)
7. Select "Yes I want to telephone a customer service representative to activate windows".
8. Click Next
9. Select "Change Product Key"
10. Put these keys
QMDGV-QRC2B-XF6JB-GRGHK-W9DRC
11. Select Update
Dont worry about asking again to register , close that
Restart the system and repeat steps 6 to 11, now the process will tell you that Windows XP is already activated.
rate me
it will work for you 100%
don't forget to reply
Jan 07, 2009 | Microsoft Windows XP Professional With...
188 people viewed this tip
David Payne
David Payne
