Tip & How-To about Baby Gear
COLLAPSIBLE STROLLERS - SAFETY
Kindly ensure and double check that your Stroller is fully locked or snapped correctly before you put your child into it :)
Baby Gear Logo
instructions on how to fold
Kindly follow the steps to below to fold the stroller:
  • Use the ball of your foot to push down on the brake lever, located near the rear wheels of the stroller. Gently push on the stroller to confirm that the brakes are set. Grip the front edge of the stroller's canopy, if present; pull the canopy back towards the rear of the stroller.
  • Push the tabs securing the ends of the harness straps to the harness buckle. Pull the straps aside and remove the child from the stroller.
  • Kneel down next to the stroller's front wheels. Locate the locking mechanism set in between both pairs of front wheels. Use the locking mechanism to disable the swivel feature on the front wheels.
  • Pull the stroller's seat back down to the lowest position; some models may feature locking mechanisms located on the sides of the stroller or built into the handlebar. Lift any latches securing the sides of the stroller in place.
  • Push the handles of the stroller downward. Push the rear section towards the front of the stroller until the device is fully folded. Clip the storage latch located on the side of the stroller to the side of the handlebar.
Apr 24, 2016 | Baby Gear
how can I fold?
Kindly follow the steps below on how to fold the stroller:
Apr 16, 2016 | Baby Gear
how do I let the stroller down?
    Kindly follow the steps below to fold the stroller:
Sep 09, 2014 | Evenflo Aura Traditions Travel System...
How do you attach a Graco Car seat to a Baby Trend 1304 tw Snap and Go Double stroller?
Depends on which type of Graco it is, check compatibility. Make sure the babies are facing you, they should SNAP right in just as it says and then buckle them in.
May 10, 2010 | Baby Trend Snap-N-Go LX Double Stroller
877 people viewed this tip
Top Baby Gear Experts
Dorel UK
Dorel UK
Are you a Baby Gear Expert? Answer questions, earn points and help others
