Tip & How-To about Computers & Internet
Lost your File Menu in IE (Internet Explorer)? PC's/Laptops
Do the following to retrieve your File Menu. Lock the ToolBar instructions as well, and how to minimize and maximize (restore) your IE screen.
Alt - F. This will bring up the file menu.
Use the arrow keys to scroll over to the "View" tab.
Select Toolbars, (do not click) and move the mouse over to "Menu Bar" and click if there is not a check mark.
Once this is checked, the File Menu should stay. Close out IE and re-open to save the changes. The file menu should then remain at place. You can also "lock" the tool bar as well: Follow these same steps: this time at the bottom of the list under Toolbars: make sure the Lock ToolBar is checked. If not, if desired, click this.
Also, if this does not work, you may have accidentally hit the F11 button which maximizes the screen to "Full View". If this is the case, simply push the F11 buttom to minimize back to original size. If the screen minimizes to it's smallest view setting, simply click the box in the middle (next to X close out button), and it will Maximise the screen, but to normal size, and the file menu will remain as well. If the file menu is not there, hit F11 again, and then if still not there (making sure screen is at normal view). Follow the instructions above to retrieve the file menu.
carsandcomps,
Guru, Premium Expert @ Fixya.com
Computers & Internet Logo
IE command bar missing customize on View/Toolbar menu
Create the menu tab on your homepage right click in the top toolbar you should see a number of toolbar options select the menu tab which will add File Edit View Favorites Tools and Help Click on the tools at the bottom of the drop down list Managed add ons Toolbar extensions Search providers and Accelerators you have if don't need any of them you can disable or remove them. Right click in the bottom toolbar (Bottom of Screen) select the toolbars option then Desktop this will add >> arrows in the bottom toolbar select the arrows you will see a list with control panel which has another list of all control panel items
Create Menu tab right click in the top of screen (toolbar) you will see a number of toolbar options select the menu bar. This will add to your screen toolbar File Edit View Favorites Tools and Help select the view from the drop down list will be a Zoom with percentages %
and text s largest to smallest b> b> Right click the toolbar at the bottom of your screen. Click "Properties." Check the "Auto-Hide" option. Click "Apply." This will minimize your toolbar. To reveal your toolbar again, move your mouse down to the bottom of your screen. This will reveal the toolbar for as long as your mouse is in this location.
Apr 01, 2013 | Microsoft Internet Explorer 9
While trying to change settings on my computer I lost the Browser bar ie. file, edit, bookmark, icon for home forward and back feature, address bar
Most probably you pressed the F11 key in the upper key row on your keyboard, and it entered "full screen" mode.
Press F11 to exit full screen mode, this should do the trick.
If this is not the case, please come back and write a comment to that effect, we'll try to assist you further.
Good luck :)
Jul 10, 2010 | Gateway MT3705 Notebook
on screen keyboard
Making on screen keyboard active, and then press Alt+Space you will get menu to restore.
And if it does not work then also u can use Sensiva software to minimize or restore, It is the good option
Sep 18, 2008 | Computers & Internet
143 people viewed this tip
David Payne
David Payne
