Tip & How-To about Computers & Internet
How to Recover Passwords Using Ophcrack LiveCD
1. Download Ophcrack LiveCD
2. Burn to a CD
3.Boot from Ophcrack LiveCD
4. Ophcrack will attempt to recover the passwords for all of the user accounts that it can find on your computer. This password cracking process is completely automated. The important things to look for here are the accounts listed in the User column and the passwords listed in the NT Pwd column. If the user account you're looking for isn't listed, Ophcrack didn't find that user on your computer. If the NT Pwd field is blank for a particular user, the password has not been recovered yet.
As you can see in the example above, the passwords for the Administrator and Guest accounts are listed as empty. If you were cracking a password for a user that Ophcrack shows as empty, you now know that you can log on to the account without a password at all, assuming that the user account is enabled.
Look toward the bottom of the user list - see the Tim user account? In under one minute, Ophcrack recovered the password to this account - applesauce. You can ignore any other accounts you're not interested in recovering the passwords for.
After Ophcrack recovers your password, write it down, remove the Ophcrack LiveCD disc from your optical drive and restart your computer. You don't need to exit the Ophcrack software - it won't harm your computer to power it off or restart it while it's running.
In the next step, you'll finally get to log on to Windows with your new password!
Note: If you do not remove the Ophcrack LiveCD disc before you restart, your computer will likely boot from the Ophcrack disc instead of your hard drive.
. ow that your password has been recovered using Ophcrack LiveCD, simply enter your password when prompted after booting your computer normally.
To avoid needing to hack your own password again someday, I recommend creating a password reset disk. As long as you can keep the disk safe and also avoid losing it, you'll be protected from any future forgetfulness when it comes to your Windows password:
Computers & Internet Logo
master password
Call the manufacturer they may be able to help you get past that. If not, at worse, you'll have to reboot it. To do that, as it is booting continuously press the F10 key (it may be a different key on your model) then follow the onscreen instructions.
There are also some programs you can boot from a flash drive that will help hack your own computer.
May 02, 2013 | Dell Latitude E6410 Laptop Computer (Intel...
can't access my old account
Step 1. Download the password cracking utility OPHCrack at the site below
http://ophcrack.sourceforge.net/download.php?type=livecd
Step 2: Burn the software to a CD
Step 3: Insert the CD into your CD drive
Step 4: Boot From CD (Learn How to boot from CD)
Step 5: The Software works you through the remaining steps.
Step 6: Recover your password!
Step 7: Enjoy...
May 01, 2011 | Computers & Internet
forget my password
This solutionwill work if you have forgotten your Windows password. It will not work if youhave forgotten your boot password or hard drive password etc.
Read on if you want to use a USB flash drive. Scroll down if you would ratherburn a CD/DVD.
USB Flash Drive Method
You need to download a Windows passwordcracker, put it on a flash drive, and boot it outside of the Windowsenvironment. This solution will show you how to do that.
1. Download the Ophcrack Windows password cracker from here. For Windows7, click on the ophcrack Vista LiveCD.Ophcrack is one of the best free Windows password recovery tools available.It's fast and easy even for a first time Windows password cracker. Save file toDesktop.
2. Download Xboot 1.0.0.0 Beta 6 here. Savefile to Desktop. Unzip file and extract to Desktop.
3. Plug a USB flash drive into your PC and format it with a FAT32 filesystem. This can be done by opening "My Computer" and right clickingon the USB flash drive and selecting Format. Select FAT32 and click OK. (Note:this will erase all data on your flash drive.)
4. Open Xboot.exe. Select the Ophcrack ISO file you downloaded and drag it ontothe Xboot screen.
5. Click on "Create USB" found in the bottom right hand corner of theXboot window.
6. Select your USB drive and click OK. Wait for your USB flash drive to becreated.
7. Restart computer and press F10 or appropriate function key for your computerto enter the temporary boot menu. It may be F12 or F9 etc. Look at the firstscreen that appears when you turn on the computer and you will see which key topress. You also could enter the BIOS and change the boot order if you wouldprefer that method.
8. Select USB Flash Drivefrom the boot menu.
9. The Ophcrack LiveCD will now boot. Hit enter to select the Graphic Modeoption when it appears.
10. Ophcrack will automatically begin cracking your passwords. The longer andmore complicated the password is the longer it will take to crack. 99% ofpasswords are crackable. Any password over 14 characters cannot be cracked.This program found my 8 character password which contains letters and numbersin less than 10 minutes.
11. Write down your password when it's cracked. Remove the USB drive andrestart computer.
Good luck and thanks for using FixYa.
Burn a CD/DVD Method
You need to download a Windows password cracker, burn it to a CD/DVD,and boot it outside of the Windows environment. This solution will show you howto do that.
1. Download the Ophcrack Windows password cracker from here. For Windows 7, click on the ophcrack Vista LiveCD. Ophcrack is one of the best free Windowspassword recovery tools available. It's fast and easy even for a first time Windowspassword cracker. Save file to Desktop.
2. Burn the Ophcrack LiveCD ISO file to a CD/DVD using the Windows 7Disk Image Burner or another burning program. For Windows 7 users, pleasefollow steps 2a and 2b. If you are using Vistaor XP you will need to use a CD/DVD burning program already installed ordownload and install a free program such as the one here.
2a. Right click on the ISO file and select "Open with" and thenselect Windows Disk Image Burner or another CD/DVD burning program.
2b. Put a CD-R or DVD-R into the DVD/CD drive and select Burn. Wait for theburning process to finish.
3. Restart computer and press F10 or appropriate function key for your computerto enter the temporary boot menu. It may be F12 or F9 etc. Look at the firstscreen that appears when you turn on the computer and you will see which key topress. You also could enter the BIOS and change the boot order if you wouldprefer that method. Many computersalready have the CD/DVD drive as the first boot drive so you may not have to dothis step.
4. Select CD/DVD from the boot menu.
5. The Ophcrack LiveCD will now boot. Hit enter to select the Graphic Modeoption when it appears.
6. Ophcrack will automatically begin cracking your passwords. The longer andmore complicated the password is the longer it will take to crack. 99% ofpasswords are crackable. Any password over 14 characters cannot be cracked.This program found my 8 character password which contains letters and numbersin less than 10 minutes.
7. Write down your password when it's cracked. Remove the CD/DVD and restartcomputer.
Mar 24, 2011 | Computers & Internet
I lost my password my screen is locked how can I reset or bypass?
This is about topic bypass Windows logon screen. Command Prompt or recovery utility is effective ways for reset or bypass lost Windows password.
First, run command prompt with administrator. And you can reset Windows lost password with this command. Net user <new user> <new password>
Second, take recovery utility to burn a password reset disk. And this reset disk is the key to remove or reset Windows password, applied for standard or admin account. When your computer is installed with Windows 8/7/Vista, forgotten user password would be removed. If it is Windows server 2012/2008 etc, password would be reset as "iSunshare@2012".
Mar 18, 2011 | Sylvania G-Netbook
I have an IBM thinkpad x41 and it comes to the Windows xp screen needing a password and I dont know the password can someone help me?
You can use Ophcrack, an open source software. You don't need any access to Windows to be able to recover your lost passwords. Simply visit the site, download the free ISO image, burn it to a CD and boot from the CD. The Ophcrack program starts, locates the Windows user accounts, and proceeds to recover (crack) the passwords - all automatically.
Here is the link to download you ISO file to burn to a cd.
http://downloads.sourceforge.net/ophcrack/ophcrack-xp-livecd-2.3.1.iso
Or use Another computer by installing the exe file and make a cd for your recovery:
http://downloads.sourceforge.net/ophcrack/ophcrack-win32-installer-3.3.1.exe
Nov 30, 2010 | IBM ThinkPad X41 Tablet PC
871 people viewed this tip
David Payne
David Payne
