Tip & How-To about Heating & Cooling
Refrigeration is actually a fairly straight forward easy to understand process. Although there are several ways that refrigeration can be achieved in a system, the most common is vapor compression, in which the compressor is the heart of the system. The temperature of the refrigerant is related to its pressure. For example R134 is roughly -15 degrees Fahrenheit at no pressure. (Thats gauge pressure and not absolute). When compressed to 250 psi R134 is about 148 degrees.   Starting from the compressor, the refrigerant vapor is compressed. In the process it will heat up hotter than the surrounding air. As the refrigerant passes through the condenser, heat is given off since it is hotter than the surrounding air and as a result it condense and turns liquid.(thats why it is called a condenser). The liquid refrigerant then passes through an expansion valve or a capillary tube where it turns into low pressure liquid and as it passes through the evaporator  absorbs heat from its surrounding since it is much colder. This makes the refrigerant turn into gas and evaporates (again it is why it is called the evaporator) absorbing tremendous amount of heat. Then refrigerant vapor  passes through the accumulator in which  moisture accumulates ( why it is called the accumulator) before it is sucked into the compressor to be compressed again. (Why do you think the compressor is called compressor? you know the answer by now)   The whole system is really a means for heat transfer for removing heat from one place and expelling it outside  in which the refrigerant is the vehicle.  Heat always travel from hot to cold. If something is hotter than the surrounding, it gives off heat and if it is colder, it absorbs heat. Simple as that. There is a thing called latent heat of vaporization or in thermodynamic term it is called enthalpy of vaporization. This simply means when liquid reach its boiling temperature at a constant pressure it will no longer get any hotter. . For example when you boil water at sea level it stay 212 degrees no matter how much heat you put under the pot. You can also think of it as putting heat into it but it is not doing anymore work. since the water is not getting any hotter. If there was meat in there it would not get soft any faster by adding more heat. The water will just absorb all that heat without getting any hotter. That is just one of those wierd law in physics and it is the underlying principle in theory of refrigeration. It is the fact that when liquid evaporates, it absorbs tremendous amount of heat and carries it away. Rub alcohol on your skin and the skin feels cold as the alcohol  evaporates. Thats a simple form of refrigeration at its very basic.   There are other types of refrigeration for example another one is called "absorption system". This kind uses heat to vaporize liquid (usually ammonia and water solution) mixed in an absorbing material. as the subtance evaporates it accumulates on the other end as liquid. When heat is taken away, the whole thing cools down and the pressure drops to a point so that the liquid that has accumulated will evaporate and be collected back on the absorbing material. This produce refrigeration. It has no moving parts no compressor and just uses heat. In fact it can be used as ice maker which is ironic since it works by heat. The last one would be thermoelectric. If current is passed through two dissimilar metals one of the metal will get cold at the junction, and it is called the peltier effect. Coolers that plugs into cigarrete lighter are example of these type of device. They are not really very efficient but have some advantages such as it can be used as food warmer when the current is reversed.
Heating & Cooling Logo
I am too stupid to be able to program my new oven and I cant find
Do you have an owner's manual? Procedures on how to use the Electronic Oven Control (EOC) begin on Page 8.
If the model number is correct, and you need a copy of your manual, complete with instructions, go to managemylife.com.
Enter your model number under the "Manuals" link and you will find the manual listed in a .pdf (Adobe) format that you can download or print for FREE.
The steps all appear to be fairly straight forward and easy to understand.
If you have any questions, or if your model number differs, please post back with your correct information and let me know. I hop this help you.
May 22, 2010 | Whirlpool GS445LELS Gas Kitchen Range
How to add Freon to a Air Conditioner or Refrigeration System
I disagree with your stament "Heat Pumps are very sensitive to either under or over charging. The only correct way to charge a heat pump is to evacuate the system and weigh in the correct charge." weighing it in is not the best way to make it perfect on a heat pump system (weighing in method is for sealed small refrigeration), superheat and subcooling with a manufacturers charging chart displaying wetbulb or drybulb relationship to charge, some manufactures even specify the use of the approach method. Charging should always be done in cooling and line sets must be dead on right size and never exceed 50 ft in length. Charging mainly just needs to be done by a professional never ever anyone without experience or knowledge, its a dangerous chemical (any of them) that can cause injury, also important is making sure you have the correct metering device and that all heat pump systems are an ahri match.
Aug 18, 2010 | Refrigerators
Refrigeration is actually a fairly straight forward easy to understand process. Although there are several ways that refrigeration can be achieved in a system, the most common is vapor compression, in which the compressor is the heart of the system. The temperature of the refrigerant is related to its pressure. For example R134 is roughly -15 degrees Fahrenheit at no pressure. (Thats gauge pressure and not absolute). When compressed to 250 psi R134 is about 148 degrees.   Starting from the compressor, the refrigerant vapor is compressed. In the process it will heat up hotter than the surrounding air. As the refrigerant passes through the condenser, heat is given off since it is hotter than the surrounding air and as a result it condense and turns liquid.(thats why it is called a condenser). The liquid refrigerant then passes through an expansion valve or a capillary tube where it turns into low pressure liquid and as it passes through the evaporator  absorbs heat from its surrounding since it is much colder. This makes the refrigerant turn into gas and evaporates (again it is why it is called the evaporator) absorbing tremendous amount of heat. Then refrigerant vapor  passes through the accumulator in which  moisture accumulates ( why it is called the accumulator) before it is sucked into the compressor to be compressed again. (Why do you think the compressor is called compressor? you know the answer by now)   The whole system is really a means for heat transfer for removing heat from one place and expelling it outside  in which the refrigerant is the vehicle.  Heat always travel from hot to cold. If something is hotter than the surrounding, it gives off heat and if it is colder, it absorbs heat. Simple as that. There is a thing called latent heat of vaporization or in thermodynamic term it is called enthalpy of vaporization. This simply means when liquid reach its boiling temperature at a constant pressure it will no longer get any hotter. . For example when you boil water at sea level it stay 212 degrees no matter how much heat you put under the pot. You can also think of it as putting heat into it but it is not doing anymore work. since the water is not getting any hotter. If there was meat in there it would not get soft any faster by adding more heat. The water will just absorb all that heat without getting any hotter. That is just one of those wierd law in physics and it is the underlying principle in theory of refrigeration. It is the fact that when liquid evaporates, it absorbs tremendous amount of heat and carries it away. Rub alcohol on your skin and the skin feels cold as the alcohol  evaporates. Thats a simple form of refrigeration at its very basic.   There are other types of refrigeration for example another one is called "absorption system". This kind uses heat to vaporize liquid (usually ammonia and water solution) mixed in an absorbing material. as the substance evaporates it accumulates on the other end as liquid. When heat is taken away, the whole thing cools down and the pressure drops to a point so that the liquid that has accumulated will evaporate and be collected back on the absorbing material. This produce refrigeration. It has no moving parts no compressor and just uses heat. An example of this is the propane refrigerators. . The last one would be thermoelectric. If current is passed through two dissimilar metals one of the metal will get cold at the junction, and it is called the peltier effect. Coolers that plugs into cigarrete lighter are example of these type of device. They are not really very efficient but have some advantages such as it can be used as food warmer when the current is reversed, and they are lightweight and portable.
Jul 10, 2010 | Cycling
Samsung STK392-010 ICs Convergence Issue.
Its a fairly straight forward repair. i would recomend getting your replacement Ics at the following link, as they provide free instaltion instructions with pictures, free shipping and free online instant messageing when you do the repair in case you need assistance. Heres the link.
http://servicemanuals.vstore.ca/
Jul 17, 2008 | Samsung HC-P4752W 47" Rear Projection...
145 people viewed this tip
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
