Tip & How-To about Washing Machines
Whirlpool kenmore direct drive washers no spin or drain. Lid switch replacement instructions
Here are some step by step instructions, They seem daunting, but what do you have to loose by trying yourself?
Depending on your model there are a couple different varieties, but the most common one was a switch activated by a plunger on the side of the lid. See if you can see the plunger and look for the corresponding hole that it would go into on the top, and there is your lid switch. The purpose of the switch is to stop the tub from spinning when you open the lid during spin cycle. Broken switch equates to no spin or drain however even with the lid closed.
Here are some basic instructions:
Accessing this part requires you to first flip up the control panel by: Removing two phillips head screws in the front bottom corners of the control panel, or the rear lower corners of the control panel.
*NOTE for some Kenmore models it may be necessary to remove the endcap covers to expose the screws on the front of the console*
The most recent designs have spring clips under the left and right sides of the control panel that need to be depressed with a putty knife to release them. Pull the panel forward and lift to disengage the tabs at the bottom. Flip the panel upwards and it will swing back out of the way.
Next you will see one wire connector going into the top of the machine, this is actually your lid switch connector, disconnect it (all the rest of the wires will route behind the top of the machine, between the top and the rear panel).
Now using a flat blade screwdriver pry the front of the two brass colored clips towards the rear of the washer (put tip of screwdriver into front most part of clip and press handle of screwdriver towards rear of machine). The clips should pop off the top pretty easily.
Now you can open the lid and place a hand on the front of the opening and pull the cabinet forward. The entire front and side wrapper will come off the base platform and you can set it on the floor to gain access to the inside of the cabinet where the lid switch is mounted and the wires are routed.
Good luck to you!!
Washing Machines Logo
The heater coil
Depending on the make and model this can be a very difficult job, with possible air bag issues. If you really want to do this yourself, but a shop manual from auto parts store to get step by step instructions.
Oct 04, 2016 | Cars & Trucks
fixing the egr
Depending on the make and model of your vehicle, yes you can if you want to do it yourself. Of course, if it is a newer car or truck, and under any waranty, if you do any work to it you may run the risk of loosing that waranty.
There are some great video's on you tube that can show you how and give step by step instructions. In this case I looked up "e g r replacement videos you tube" and lead me to a couple good clips. You can also go straight to the car manufacturer and they to can help maybe with videos or manuals. In our small town, we have 4 auto parts stores, so they are all willing to go an extra mile to help us figure some problems out.
Good Luck, and hope this helps a little
Jun 05, 2012 | Cars & Trucks
i overloaded my washing machine, now the spin cycle will not work any thing i can do to fix it myself?
Sounds like your lid switch is broken if it will not spin or drain out..
Good luck to you!!
Aug 14, 2010 | Kenmore 23822 Top Load Washer
Canon Digital EOS camera black spot in images
This is dirt on the sensor. You can clean this yourself but first, get some knowledge. Google the words...cleaning a digital slr sensor. You will find sites that will show you step by step what to do and what supplies you will need. It may seem daunting at first, but believe me, it is incredibly easy once you start.
Jan 08, 2010 | Canon Rebel XT / EOS 350D Digital Camera
i want to install a unit into my work truck
go to a reputable stereo store and buy the wire harness connector for your truck to universal and one from universal to your stereo; also buy an installation kit for your model truck, (this will contain all the plastics necessary to fit the stereo to your dashboard),these usually contain several configurations for different vehicles so follow the instructions carefully. these may seem rather daunting at first, but if you fermiliarise yourself with all parts/instructions before starting it shouldn't be too hard or take too long; good luck
Nov 14, 2009 | Phase Linear PCD120U CD Player
184 people viewed this tip
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
