Tip & How-To about Watches
HOW TO SET DAY / DATE ON AN ANALOG (STEM) WATCH
Mcdevito75 here, Over Forty (40) years ago, watch manufactures added, to some of their ANALOG (wind up) and almost all of their DIGITAL (button display) watches the FEATURE of the, MONTH or DAY of the WEEK and the DATE, not only was the time of day available but also the DATE which you no longer had to go searching for, it was readily available on your wrist. The PROBLEM came with SETTING the CORRECT MONTH or DAY of the week and the DATE as some MONTHS HAD 31 DAYS rather than 30 DAYS, this meant you had to CYCLE your watch at least 62 times to get to the CORRECT DATE and mant times, when you finally did reach the CORRECT DATE, the day of the week was off, meaning more CYCLES thru the 24 hours.-------- HERE is the EASY way to SET the MONTH or DAY / DATE on your QUARTZ / MECHANICAL (STEM) watch without haveing to go thru the 24 hour cycle so many, many times. Not only is this, WEAR on your fingers, you can also damage your watch with some many cycles of the 24 hours to SET the correct MONTH or DAY / DATE. ------ HERE ARE THE BASICS,---------- Your ANALOG or STEM watch either QUARTZ or MECHANICAL should have a TWO (2) position STEM we are only familiar with the ONE (1) position we use to set the TIME, there should be TWO (2) positions to the STEM. First pull out the STEM to adjust the MONTH or DAY depending on your watches display, if your watch DISPLAYs the DAY of the week, set the DAY to one (1) DAY before the DAY you want, don"t worry about the DATE (number) yet. Once you have the MONTH or DAY set, push the STEM back into the watch, NOW with a finger nail just under the STEM (usually from the back of the stem as there is more room) gently lift the STEM to it"s first position, It may take some practice so be patient, once the STEM is in it"s first position you should be able to turn the STEM to adjust the DATE (number), if so Adust the DATE (number) to ONE (1) DATE before the DATE you want, This way your watch will be adjusted to change the DAY / DATE at the correct time. Once you have the DATE (number) adjusted to ONE (1) DATE before the DATE you want, push the STEM back into the watch, NOW pull the STEM out to adjust the time, go thru the 24 hour cycle to adjust to the correct DAY DATE (number) and time of day.------------ Your QUARTZ or MECHANICAL (stem) watch is now adjusted to the correct DAY / DATE and will change at the correct hour which is generally 12--1 AM.
Watches Logo
Cannot get the digital settings and the analog hands to match.
mcdevito75 here, Most likely the digital part of your watch is for thetime in your time zone while the analog (hands) time is for a different time zone, (Lodon / New York) visit a small watch repair shop in your area for details.
Jun 26, 2010 | Watches
clean an analog watch movement
mcdevito75 here, Unless you have the equipment and knowledge, you could wind up destrying your watch, Refer to repair and service here at fixya, bottom of the page, Repair Service then click on watches.
Jun 21, 2010 | Watches
I have no idea how to set the time. Please help?
mcdevito75 here, generally on a digital watch, (buttons no winding stem) you have a few buttons that are pressed, 1 of these buttons says MODE, press that button once and you should see the face of your watch flashing, if so pess the set button to adjust the function. Also visit a small watch repair shop in your area, they can help.
Jun 13, 2010 | Watches
671 people viewed this tip
Top Watches Experts
Jimmy Accardi
Are you a Watch Expert? Answer questions, earn points and help others
