Tip & How-To about Grilling
Smoked meat secrets. Fall off the bone fantastic!
Here's the secret. You want to get a digital thermometer with a remote you can keep in the house that reads the air temp and meat temp of the inside of the grill so you can monitor the temps. All you care about is getting the meat's internal temp to 175F and keeping it exactly on that number. When the meat first goes in you can have the air temp around 400f but over the next 2 hours gradually lower it. You can do this in 2 steps to save yourself too much effort. As the meat's internal temp reaches 150F you need to get the air temp in the smoker to 225-250 and keep it there until the meat reaches 175. That is the temp at which the connective tissue in the meat breaks down and gives it that "falling off the bone" quality we all love. Keep the meat's internal temp at 175F until it reaches the desired tenderness. If you do that you're friends will all envy you're smoker skills. Trust me you will be amazed. Now for the vents. It's very simple, Once the coals are good and hot (they should be ash colored) then add a chunk of hickory or applewood. You can buy it at the grocery store in chunks where they sell charcoal. The set the intake vent on the bottom of the fire box to about one and a quarter inches open. Then set the chimney vent so it's only open about the width of a standard pencil. The wood will start to smoke almost immediately. Once it stops add about 8-9 more lumps of charcoal and one more lump of hardwood and just keep an eye on it. After the meat reaches the desired color and looks really savory and covered in smoke then wrap it in foil and finish it in the oven at the temps I mentioned earlier. That way you can really regulate the temp evenly and get perfectly tender smoked meat. Good Luck!
Grilling Logo
probe reads to high compared to my other meat thermometers
Thanks for the great question. While I am a avid smoker and outdoors men I can tell you that most of these gauges are not real accurate and only measure ambient air temp. Also the placement of the gauges in the upper portion of the smokers will give a higher reading because heat rises. My best suggestion is that you use a stand alone meat thermometer for guaranteed great smoked meats. You can also measure the temp inside the smoker using a stand alone thermometer and read your guage at the same time. Than you can use adjust the door thermometer by turning the center of the probe on the back with a pair of plier. You should see a nut head or a locking nut that allows you to hold while you turn the face of the thermometer to recalculate it. Some of these may not be adjustable and you can purchase a adjustable replacement online.
I hope this has given you a better perscpective on these gauges and will help solve you problem.
Oct 06, 2013 | Sportsman Elite 40" Vertical Gas Smoker
I've misplaced the operating instructions for my williams sonoma remote meat thermometer. I can't get the probe unit/base to sync with the remote transmitter or to show a temp on the base unit and find a temperature. HELP
This is for a model ET-903WS: Turn the base unit on first. This is the unit with the larger display & buttons. Hold the power/mode button (upper left) down until you hear 3 beeps and the display lights up. Mine then displays "BEEF" and shows 160, with 3 blinking spaces. Next, plug the probe into the smaller remote unit. You should get 1 beep, the remote will display the temperature and the base will now display the same temp where the blinking spaces were. The first couple of times I tried, the base would not display. Unplug the probe, turn the base off holding down the same power/mode button and start over. I've had to do this as many as 4 times but it has worked perfectly while I wrote this!?! I really like this thermometer because I can put the meat on the grill go inside and have a drink while watching the game and then a friendly voice comes on when the internal temp is within 10 degrees of your target and says: Your food is almost done...your food is almost done." If you sleep through that, she comes back on at temp and says "Your food I'd done...your food is done". I take most meat off at the first warning and wrap it in foil. Watch the probe and it will continue to rise for about 20 mins. Enjoy.
Aug 08, 2010 | Microwave Ovens
I have a Sunbeam digital meat probe thermometer used once. Now the display for thermo/temp comes up H instead of the temperature of the meat. What is wrong? Sunbeam digital meat probe thermometer has quit working after two uses. Need a replacement.
I left mine in a hot tub for well over an hour. It started reading room temp at about 125 degrees. It worked for me to put the thermometer in the freezer until the readings were correct. hope this works for you.
Feb 22, 2009 | Sunbeam 2370 MixMaster Series Stand Mixer
High idle on my 1999 Saturn SL1. The mechanical screw on the idle cam is at its minimum. The car idles at 13-1500 rpms .
Clean the Idle Air Control Valve. It's on the throttle body below the Throttle Position Sensor. Worked for me! Good luck.
Sep 11, 2008 | 1999 Saturn SL
I have the same problem. The problem is the probe went bad. I had a friend with another sumbeam digital probe (the mavrick) put that probe into mine and the temperature reading was working properly. So, now I am looking for a replacement probe. but looks like I will have to just buy another digital meat probe.
Aug 16, 2008 | Sunbeam 4214 Iron
1,681 people viewed this tip
Top Grilling Experts
paulcarew
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
