Tip & How-To about Kitchen Appliances - Others
I listed some of the things you should check if the internet on your desktop or laptop is not working. Computer connected to the modem 1. Check the cables if its properly connected to the modem 2. check the lights on the modem, if they are all ok. 3. Check if the modem is set on standby mode. MOdem should not be on standby. 4.Power cycle your modem. power off your modem for 3mins, and then turn it on. Wait for the lights to get steady and then check your computer if it has internet access. 5. Call your Internet service provider , it can be a problem with their line. Computer connecting thru the router 1. If its wired check cables. Some user plug the computers to the INTERNET or WAN port. Computers should be on the LAN port . Modem should be plug into the WAN or internet port. 2. Check the lights where you connected the computer. See if the port light is lit up 3. Check your computers ip address. HOw? If your using windows Click start - run - cmd - enter ipconfig - look for ip address. If the ip address is 169.xxx , this is an invalid ip. If your using mac Click apple icon Click on system preferences Go to network and then look for tcp ip address If you get an invalid ip address the solution is either you need to plug the computer to another ethernet port or your router needs to be reset. If its wireless and your getting 169.xxx Theres a possibility that the wireless security on your router and your laptop dont match. Check your wireless security and make sure you enter it correctly. 4. Your router might not be communicating well with the modem. YOu can do the steps above to check if the modem is working properly. 5. if the modem is working. That only means you need to setup your router again to the internet. You can do it using the setup cd that came with your product or you can do it manually by calling your router tech support.
Kitchen Appliances - Others Logo
Network Connection Issue
Go to Control Panel, System, Hardware to Device Manager, and unistall
broadcom netxtream gigabit controller, and restart your computer
after restart broadcom netxtream gigabit controller will install automatically. once intallation finish, check your internet is getting in your PC
Tahank you
Jan 16, 2013 | Dell Computers & Internet
internet connection
if you are use a modem to connect internet then check list of things like---
1) first check your modem are work properly or not. If all lights are blink then ok or check the modem light and pc light carefuly
2) if modem are work properly then install driver which is provided by the ISP.
3) after that right click on your computer icon and goto manage , goto device manager from the left side list where you can see your new device are connected which will be show as "yellow question marks" then right clik on it get update driver.
4) update driver nd restart the computer.
your internet will be connected otherwise conatct with your intenet provider.
May 04, 2011 | Computers & Internet
can not connect to the internet
Verify that the modem is working by using another computer to connect to the Internet. You can also check the lights on the modem for proper operation. They normally should be all green and one may be flashing. Once you've verified the modem is working and can connect to the Internet from another computer, check the network settings of the computer - you can locate this in the control panel. If a network is not listed, then check the Device Manager and verify the Network Adapter is installed with its' driver installed correctly.
Oct 28, 2010 | Computers & Internet
I purchased the AT&T Motorola modem if I connect my desktop directly it works, but my laptops do not - if I connect my Netgear router my laptops then work but my desktop does not...help...
>in order for you not to have more problems at all
>first, ask AT&T to set your motorola modem to BRIDGED MODE first
>then, connect your Netgear router to the modem
>connect the desktop computer to the router and check you connection
>after you got the desktop computer connected to the internet
>try to establish connection to your wireless network using your laptops (Laptops cannot connect to Motorola modem since it doesn't have wireless capability like routers)
>comments suggestions ratings and violent reactions will greatly be appreciated thank you...
Sep 26, 2010 | NetGear RangeMax WPN824 Router
596 people viewed this tip
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
