Tip & How-To about Computers & Internet
PLAY HD CONTENT IN YOUR LOW PROCESSOR SPEED PC TOO.
Playing HD content in your pc which got low processing speed with lots of lagging and poor synchronization of audio and video, has become a great issue. Here is the solution for that problem.
Step 1 : Download Media Player Classic - Home Cinema from : http://mpc-hc.sourceforge.net/.
Step 2 : Download Core AVC Video Decoder from http://hotfile.com/dl/47202507/bb451dd/CoreAVC_H264_Video_Codec_Pro_v2.0.0.rar.html
Or
http://rapidshare.com/files/396874926/CoreAVC_H264_Video_Codec_Pro_v2.0.0.rar
Step 3 : Install Media Player Classic Home Cinema. And now install CoreAVC Video decoder.
Step 4 : Open Media Player Classic Home Cinema. And click VIEW->OPTION.
Step 5 : OPTION windows appears. Select "External Filters " and click "Add Filter" and then select "CoreAVC Video Decoder" from the list and click OK.
Step 6 : In that same "External Filters" window choose "prefer" radio button visible under " add filter" button. Click OK.
Step 7 : You are DONE. Now your Laptop/PC will play HD content easily. Sometimes this Decoder is supported by Windows Media Player and it will also play the HD content easily after you follow the above steps properly.
Note : In some cases, when you install the Core AVC Video Decoder, even Windows Media Player and other media player make use of it and you can run any kind of video files, even you can run FULL HD Videos in Windows Media Player Itself.
The Media Player Home Classic is preferred because, it buffers the whole video first (very fastly) and then it plays. Hence there is no lag in playing Videos.
Thank You.
Computers & Internet Logo
p191w lags when playing videos on full screen
the video card is too low on speed and memory. The lower end cards slow down the pc performance on videos and games.
Try to get a gig memory vid card at least
Jul 20, 2009 | Acer P191WBD LCD Monitor
Captured Audio / Video Synchronization
Change the video format. What format are you making the new video?
May 08, 2009 | Computers & Internet
while wathing movie by acer 3260 laptop video & audio slow
Hello sanjeev_vada,
This procedure is from the windows media player help file.I hope it's useful:
*To play content at variable speeds*
You can change the speed at which content plays in the Player. For example, you can slow down the playback speed if you are taking notes while watching a training video, or you can speed up the slow sections of a presentation.
•Begin playing a file.
•Click the arrow below the Now Playing tab, point to Enhancements, and then click Play Speed Settings.
•Move the Play Speed slider to the speed at which you want to play the content, or click the Slow, Normal, or Fast link.
•To select speeds between the labeled play speeds, in the Enhancements pane, clear the Snap slider to common speeds check box.
•To hide the settings, click the Close button in the Enhancements pane.
If this solution is helpful please click 'YES' by 'Was this helpful?' below.
Have a great day,
martyshaw152
Jan 05, 2009 | Microsoft Windows Media Player
video cards
The 260 gtx is a nice card but ATI just came out with their new cards and the Radeon HD 4850 is faster for about $100 less than the 260GTX.
But WOW uses an older graphics engine and low poly count models with that cartoony look. WOW will run great on some fairly old hardware so if he is using that computer for WOW only and is running SLI then there is no reason to upgrade. He probably has the resolution maxed out and the detail settings maxed out. If he is playing on a 32" 720p widescreen TV then the resolution should be set to a maximum of 1280X768. The rest of the settings should be adjusted to maximize the experience to your liking.
Some LCD TVs to add lag because of the image processing that is hapenning behind the scenes, some TVs have a gaming mode that minimizes this lag. Also your internet connection could be the culprit causing your lag.
In the end you do not need an new video card to play WOW. If he wanted to play Crysis with high detail then that would be a different story.
Jul 08, 2008 | Computers & Internet
1,144 people viewed this tip
David Payne
David Payne
