Tip & How-To about Computers & Internet
Laptop or Monitor Cleaning
LCD and plasma screens have a anti-glare coating or anti-reflective coating. This is so any bright light doesn't reflect and wash out the picture. It does help but it also makes cleaning the screen a bit of a problem.
As this is a coating on glass it is actually possible to clean t off by using the wrong cleaner. There are great glass cleaners out there but most are chemically based and too aggressive. In other words they attack the coating.
So what do you use? Paper towels, a drop of dish washing or liquid soap and water. And you need to use a bit of a technique or you will see smears or smudges on the screen.
You need to get two sheets of paper towels. One is your dry wipe. Wet one with water. Then add a drop of liquid soap or detergent. Give it a couple of gentle squeezes to distribute the soap. Then give it a bit harder one to get rid of excess water. Depending on the coating you may want a second piece that has only water and just damp not wet.
Now we clean the screen. First take the soapy towel and wipe down the screen getting it wet. You don't want running water just enough to wet the screen. If you have the soap right you will just see the odd bubble. Once you have the screen wet, wait about 30 seconds and now scrub it using the soapy towel with a circular motion. If there is anything on the screen it should come off. If something is stubborn just keep scrubbing it or use a fingernail to scratch it off and wipe with the soapy after.
Now we need to get the soap off. If the screen dries and has streaks you may need to use the wet un-soaped towel to wipe/rinse of the soap before drying. To dry the screen we want to use the dry towel and use large circular motions. Go over it once and turn it over so the dry side is being used. Keep using those big round motions and at the same time ease up of how hard you push the towel. The idea is to have little pressure on the towel as you finish. That's the trick to getting it streak free.
This takes a minute to do but lets you safely clean your display without damaging the coatings. It also works on any glass surface.
Computers & Internet Logo
reflection off of screen
Plasma TV's are known for their glare and reflection issues, you can still fix it by buying a third party anti-glare filter and applying it on your television. For example, "ViewGuard" makes filters that goes up to 65" in size. It is not cheap though, depending on the size of your television.
Of course, the best solution is to adapt your room accordingly. If the glare is caused by the sun light coming from the windows, installing curtains on your windows or moving your television to a better spot is a very effective way to reduce the glare and the reflections on your television.
If the glare is caused by the room's lights, the best solution is to install ceiling spot lights with a dimmer.
Hope that helps!
Mar 19, 2014 | Samsung 51 Class Plasma 1080p 600Hz Smart...
i have a CQ56 compaq and do not know which type of screen to order a matte or a glossy screen.
The Two Kinds of LCD Monitors lens1946174_1208282041macbook-matte-screen1.jpg There are two kinds of modern LCD screens: matte (anti-glare) and glossy. Both have their pros and cons and are a subject of many discussions.
Matte screens don't get glare or reflections on them; however, the same rough surface (polarizer) that reduces the intensity of reflected light results in less contrast and brightness since the light from the LCD screen passes through it. Matte screens diffuse light instead of reflecting it so they might be easier to read outdoors, if the backlight provides enough brightness. You don't have to worry as much about reflections as with a glossy screen.
Glossy screens have vibrant colors and the highest contrast and brightness because they have a smooth, high-gloss surface. As a result, it is often the choice for movies or gaming. However, strong lighting causes glare on these screens which is very annoying and may tire your eyes if you have to stare at it all the time. You can also see reflections on the screen. Some graphics designers may also find the colors inaccurate. Glossy will work great for you if the lighting in your room doesn't create any glare on the screen.
http://www.squidoo.com/matte-vs-glossy-screens
Jun 28, 2011 | Compaq Presario CQ56-115DX Laptop
Glare on lcd screen
it's pretty normal.. try wearing a brimmed hat to create shade, turning the brightness up on the screen, the lcd's tend to get washed out in the bright sun.
Jul 01, 2009 | Polaroid i835 Digital Camera
203 people viewed this tip
David Payne
David Payne
